I actually solved it by passing thick card through (with a little) help a few times in copy mode. After a few passes it seems to have cleaned itself.I actually solved it by passing thick card through (with a little) help a few times in copy mode. After a few passes it seems to have cleaned itself.
You can't post conmments that contain an email address.
Some small piece of paper or something stuck in the printer path, remove the paper feed tray and clean it completely , open the printer cover and clean any particles, try cleaning the printer head path also... if nothing is visible try using a torch light and then clean it from inside.... once done with all cleaning switch on the printer, things should be fine now... if not
Please get in touch with canon service center, if the printer is still in warranty, or try to contact local serive center....
Hope this answers your post, please let me know by providing your valuable feedback....
SOMETHING MOST LIKELY FELL DOWN IN BACK PAPER PATH OR TORN PAPER THAT HAS PAPER SENSOR STUCK. HARD TO SEE SOMETIMES. MIGHT WHAT TO TURN MACH UPSIDE DOWN AND SHAKE BE VERY CAREFULL
Says I have paper jam but I don't have paper in there also I went and bought ink and put it in the light went out of paper jam but when I went ot use it it came back on.
Try this...With te printer off line, press the paper feed button making sure thre is paper in both feed trays. Once it print, a blank page go in and change back t your desired papper source. Hope that helps, please let me know.
When the print head temperature falls, the error is
automatically cleared.
Note:
If the print head temperature exceeds the specified limit
when the scanning unit (printer cover) is opened, the
carriage does not move to the ink tank replacement
position.
PLEASE REMOVE THE POWER CABLE AND REINSERT IT IT SHOUL BE OK AND IF STILL PERSIST JUST RESTART THE PC IF STILL RESIST PLEASE LET SOME TECHNICIAN TO CHECK FOR THE SENSOR FOR THE PAPER JAM ...
GOOD LUCK
I cannot receive faxes or print anything.
The message says that "there is no paper in the machine". There us plenty of paper in the machine and I push "OK" and get the same message
