Question about Palm m515 Handheld
How do I dispose of a Palm m515?
I've used my Palm m515 for several years now and it seems to be dying. Also, I used it with an old computer, and I recently bought a new one. When I connected my Palm, all the data disappeared. Also my new computer stated that it cannot support this Palm.
I think I need to dispose of it. If so, what is the safest way to do so?
Thank you in advance for your assistance.
  • 736 Answers
Its likely the battery has just gone bad .. a new battery is not expensive but you need a small torx tool to get it open .. the m515 is still a nice machine for some, so donating it to Goodwill or other charity will do a lot of good for several people .. you can just drop it off at most places.. put everything in a box so it doesnt get seperated ..
Posted on Oct 06, 2009
Testimonial: "I still want to know if the data that was originally on the Palm is still there or not. If I give the Palm to someone, will they get to the data?"
  • hmlee390 Oct 07, 2009
    the data is only retained if the battery is charged unless you have an SD card inserted ... take out any SD cards .. you can probably fire the m515 up on its charger stand even if it has a bad battery ... that will allow you to check for anything left over ... if it doesnt fire up then you can do a reset ... a hard reset erases everything and restores the machine to normal operation .. on the m515 the stylus (pen) comes apart .. the end opposite the point unscrews .. that gives you a narrow probe that can be used to reset the unit .. the reset button is at the center top on the back of the unit inside a little hole .... its marked "reset" ... that should get it working if its on a charger or even the battery if its charged and thats all thats wrong .. just pushing the reset button will reboot your palm .. if you hold the power button when you do a reset then it gives you a choise to "erase everything ?" if you select that then thats a hard reset and everything will be gone .
A friend had given me his old palm m515 but i dont know how to work it i would like to print off an owner manual is that possible
I did a google search....this is what I found.
[PDF] Handbook for Palm m500 Series Handhelds File Format: PDF/Adobe Acrobat
Welcome to the Palmm500 series handheld. This handbook is ... One USB port or available serial port (serial cradle sold separately) ...
www.palm.com/us/support/handbooks/m500series_ug.pdf
Jan 28, 2011 | Palm m515 Handheld
How do you turn on the Palm m515
the palm m515 has a button at the top right corner .. hitting the button quickly will turn the unit on or off ... holding the button for 2 seconds will turn the display backlight on or off ... if the unit fails to start then you can do a reset .. thats like a reboot .. the top of the stylus unscrews ... that gives you a little probe that you can use to push the reset button on the back top center ... if the battery is bad you can still run the machine with the charger hooked up ..
Sep 29, 2009 | Palm m515 Handheld
Do I need software to sync my new palm m515 with my laptop pc?
HI,
Yes you will need to install the Palm Desktop software on your computer or your laptop. Here is a link to the Palm Support site where you can download the software that you need. If you need any other help please let me know. Best wishes.
http://kb.palm.com/wps/portal/kb/na/m-series/m515/unlocked/downloads/page_en.html
Aug 09, 2009 | Palm m515 Handheld
Softwares required
Sorry, but Palm is not providing an upgrade (at least for the M515 model) to a newer Palm OS (from the 4.1 that you already have). Palm is not known for supporting older products (yours dates back to about 2002).
As for bluetooth - the unit does have an SD card slot, and there are SD Bluetooth adapters made, but I don't know if they would work with OS 4.1 (and neither does Palm). Additionally, the cheapest I found after a quick search was $117 bucks. For a little more money than that, you can buy a new Palm, with OS 5.0, and bluetooth built-in. Wish I had better news for you...
Cheers
Nick
Dec 18, 2008 | Palm m500, m505 & m515 Install CD (pa1456)
Instruction manual
http://www.palm.com/us/support/m515/
Follow this link. On the right-hand side of the page,near the bottom of the page, you'll see the handbook and setup guides for your palm pilot m515.
Feb 08, 2008 | RIM BlackBerry Pearl 8100
Palm M515 hot sync problem
I have a similar problem with my m515. I have 3 palms and 2 sync fine but the 3rd isn't even getting to the computer. There is no recognition from the computer that the palm is trying to sync even though I use the same cradle for all palms. The ensuing message is, "the connection between your handeld computer and the desktop could not be established. Please check your setup and try again". My settings are set Local and Cradle/Cable.
Dec 20, 2007 | Palm m515 Handheld
Palm M515 and compatibility with Vista Home Premium
I was having a similar problem with my M515.  I had originally installed the Palm Desktop from my CD, which was an older version.  When I totally uninstalled the old version and installed the newer version from the Palm website I was able to do a successful sync.  I'm using Windows Vista Ultimate and Palm Desktop version 4.1.4
Oct 24, 2007 | Palm m515 Handheld
M515, re installing basic software
Hy floody, this may sound like something you already checked, but you will notice in the top right corner of palm desktop there is an drop down arrow, is it set to System? If so , set it to all. Let me know how you go.
Sep 25, 2007 | Palm m515 Handheld
M515 green light on and dead screen
Hey, i had the same problem. My m515 stayed with the green light on for 3 days until the battery died out (and lost all my data). I keep the m515 off and without recharge for 2 more days. Then I recharge it in its craddle and it seems to be ok. Good luck
Sep 19, 2005 | Palm m515 Handheld
Palm m515 Handheld Logo
254 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Raj Patel
Andrew Taylor
Andrew Taylor
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
