Question about Arris DCT6200 DTV Receiver
I have a Motorlao DCT6412 III through Comcast, and it won't switch tuners. When I do try to switch tuners, it says, "this program will be available shortly." In essence, I can only record with one tuner, and I cannot watch another channel with the other tuner...
  • coghlanwriti Oct 16, 2009
    How do you do that??
Turn the loopthrough ON
Posted on Oct 16, 2009
DCT6412 III DVR Box has inputs but how do I switch to them?
Who is your cable provider? Several providers indicate that the inputs (USB, ethernet and composite video in) are not currently enabled on all DCT6412 set-top boxes.
I wish that I had better news for you.
(note: the component video is only video out to TV or other component.)
Jan 22, 2018 | Motorola Televison & Video
How do I figure out my ir code for my Motorola dvr box (dct6412 III) remote control?
you may find-it on electronics stores on ir programed remote control, they have a table for all remotes control codes
Nov 22, 2009 | Motorola Televison & Video
Motorola DCT6412 III and Vizio VW32L HDMI
After troubleshooting over the weekend, this ended up being the HDMI ports on my Vizio TV. Going to have to take it and get them fixed.
Aug 21, 2009 | Arris DCT6200 DTV Receiver
How use Tivo on Motorola DCT6412 III?
this works to record progam you watching
1. press menu key
2. highlight DVR button by using either < or > key then press OK button
3. answer prompts
Do this to set up a recording in advance or a series recording
1. Hit the guide button
2. scroll thru channels until you find program you want to record
3. scrool over to red dot press OK button
4.you can the highlight red dot for one time recording or go down one to record every episode. make sure you check the settings for this program.
Hope this Helps.
Mar 19, 2009 | Motorola Televison & Video
Motorola Dual Tuner PVR - DCT 6412-III --- HELP
I was just reading another blog on this problem and it seems you must clear any recording setup you have for the program the go to the settings and in the history file delete all listings of it. This can take a while as you must delete them one at a time. Then you can reset the series or single recordings. Seems to work for some people. I am having the same problem and programs are disapearing one at a time. Good Luck
Smalltown
Feb 24, 2009 | Arris DCT6200 DTV Receiver
Hi.
The information provided shows that tuner 2 isn't working at all on at least the selected channel. This could be a problem on just some channels with this tuner or possibly all channels. You can verify this by hitting the "SWAP" button on the remote to switch tuners while viewing a live program on a problem channel. If you choose the same channel for each tuner, I expect you will see program on one and "one moment please" or freezing or pixelation on the other. The confusion about recording comes about because of how the DCT6412 chooses which tuner to use for recording versus viewing. If you activate record on a channel you are watching, it will use that tuner. If you see it, it will record. For future or series recordings though it will automatically choose to use the alternate tuner so that it won't have to change your channel selection. Since there is no input signal detected on the other tuner, it will actually record but there will be nothing to see on play back. What causes this? It is probably that tuner 2 has failed. There is a slim chance that your cable signal coming in is either too strong or too weak but this is unlikely since the DCT6412 splits and then amplifies the cable input signal before distributing essentially equal signals to both tuners (the plug on coax adapter on the back feeds the cable signal to an AGC amplifier within the DCT6412 and then splits and distributes that output to both tuner inputs). You could check the OOB AGC level as described here http://www.cable-help.com/ but I think your problem is more likely that tuner 2 has gone bad. JM Belleville Ontario
Dec 12, 2008 | Arris DCT6200 DTV Receiver
Motorola Dual Tuner PVR 6412-III ( HD )
If you cannot get it repaired, note that it has a 120GB disk-drive -- very small when compared to the latest model (500GB), and note that the disk-drive probably is approaching 10 years old -- doomed to "fail" soon. Replace it, and add an external-SATA "Expander" to add another 1000GB of storage of recordings.
Dec 11, 2008 | Dell Inspiron 6000 Notebook
Can't tape tv program on VCR while watching another show on digital cable.
If you set it up right per Comcast instructions:
Your VCR will record a show off of its built in tuner while you are watching another show from the cable box.
Make sure that the AB switch is set into the correct position and that you are only recording a show that that isn't digital. I believe you can only record shows up to channel 150 off the VCR tuner. Anything higher than that won't work.
If your Comcast Cable Tuner has two AV outputs in the back of it, you can skip the AB switch altogether and plug the one of the cable tuner output lines into the back of the VCR input lines. That way it can record that show you are watching on the cable tuner at that same time.
Jul 19, 2008 | Televison & Video
Motorola dvr: model dct6412
YOU WERE RIGHT I GUESS IT WAS DOWNLOADING SOFTWARE, JUST LET IT RUN IT DOES TAKE A WHILE SO BE PATIENT.
Feb 20, 2008 | Arris DCT6200 DTV Receiver
Cannot record thru line 1
If you could but now you cannot then this is a circuit break down- although check your set up , but I feel it is the machine beginning to die
Jun 15, 2006 | Sony RDR-GX315 DVD Recorder
Arris DCT6200 DTV Receiver Logo
459 people viewed this question
Top Arris Televison & Video Experts
Are you an Arris Televison and Video Expert? Answer questions, earn points and help others
