Question about Kodak EasyShare C713 Digital Camera
TURRET IS STUCK OPEN i HAVE PUT IN NEW BATTERIES NO MOVEMENT
Changed the clutch drove good then got stuck in first gear
lol u gotta take it apart and line up the plate again use the lining up tool or go buy one at autozone and follow torque specs but also check gear selector and stick shift cables etc before taking it off again
Jan 05, 2014 | 2005 Hyundai Tiburon
Digimaster Happycam 5010 Problem: The shutter that protects the lens is stuck fully open. The camera is stuck with lens fully extended. ERROR 2 appears on the screen. The LED near the top left of the...
That is probably a lens error, or a problem with the main pcb inside the camera.
Only easy fix is checking if the problem disappears by removing batteries and putting them back.
Oct 12, 2008 | Cameras
Open battery compartment when camera was turned on, now the lens is stuck out and it wont turn on
Remove the batteries from the camera, wait for 10 minutes, then put them back in and turn the camera on. If this does not work then try the compressed air. With a fine tip blow off the gun, and dry compressed air set the tip between the lens turret and the camera body and turn on the air while moving the tip around a the lens. It should remove all dust and sand. Turn the camera on and it should function as fine.
Secondly give a gentle tap on the sides of the camera and then switch on your camera, you will not get this error message as the internal mechanism which is stuck and causing this problem gets working properly.
If you still face the problem, then the helical threads inside the camera probably got bent to the point that it won't work anymore.
You need to get repaired.
Hope this helps.
Shane
Apr 04, 2011 | Kodak Easyshare C813 Digital Camera
When camera is turned on no picture appears in the viewfinder or on the LCD screen, it remains black. The batteries are new. I can access the menu, change settings. Everything works but there is no image...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Sep 04, 2010 | Canon PowerShot S2 IS Digital Camera
Screen is absolute dark.Batteries o.k
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Dec 18, 2009 | Canon PowerShot S2 IS Digital Camera
My camera's lens is stuck open.
Double check you put in the batteries in the correct direction. This has happened to me before and usually when new batteries are put in, just push the on/off button again and it will close lens and go back to off position.
Nov 26, 2009 | Sony Cyber-Shot DSC-P72 Digital Camera
LCD monitor is black
Sep 07, 2009 | Canon PowerShot SD890 IS Digital Camera
My camera will not come on. and also the lens is opened out and will not go back in, i have put several new batteries in it, and if i put batteries in it and close the battery door, and push on, the light...
my camera will not turn on or off lense stuck open put new batteries still nothing my daughter took picture with it everything went blank its the samsung s630 worked fine till today!!
Jun 08, 2008 | Samsung Digimax S630 Digital Camera
Lens stuck open
i have just had the same problem. mine was stuck open, i gave the lens a slight twist and heard a bit of a crack. i switched it on again, now it is ok.
Apr 09, 2008 | Samsung Digimax S600 Digital Camera
Camera not working
This might be because you have to change your battery settings. Go to the options and change the battery settings to Nlmh for rechargeable batteries.
Dec 07, 2007 | Samsung S630 Digital Camera
Kodak EasyShare C713 Digital Camera Logo
24 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
