Question about Kodak EASYSHARE 5100 All-In-One Printer
I have changed the cartridges in my printer nd it
I have changed the cartridges in my printer and it prints very light
    Problem Solver:
  • 15 Answers
This is an issue with the printhead of the printer. Please follow the below mentioned steps:
  1. Reseat the ink cartridges and the printhead of the printer. If you need help in doing so please go to the link http://faqs.kodak.com/atg/faq/attachments/AUR1780-2.pdf
  2. After you are through with reseating the ink and the printhead, the printer would ask you to go through a calibration and the light on the printer would begin to flash.
  3. To calibrate the printer, put paper in the paper tray and press Start button on the printer. After you have printed the calibration, you will have to scan it so place it on the scanner glass and hit the start button.
  4. After calibrating the printer, try a deep clean by pressing the Cancel and Copy buttons at the same time for two seconds. Wait for a minute and the cleaning process would complete.
  5. Try printing a Demo sheet by pressing Copy and Cancel button.
If the problem still persists, you can get a free printhead replacement from Kodak.
Posted on Oct 15, 2009
Just changed cartridges to refills and clour and black lights flashinghowever we can still print ok. Why are the lights flashing?
The lights are flashing because you are using refilled cartridges. The printer "sees" those cartridges as empty, since it can not know that someone has refilled them. When you put in new cartridges, the lights will stop flashing.
Just ignore the lights and print!
Hope that helps!
May 19, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Printing with my Kodak easyshare 5300
it is necessary to install the colour cartridge.to use with black
Aug 14, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Light print problem in sumsung 2010
it is problem your cartridge unite toner powder not support toner supply brush
you change cartridge and buy a new one then solve it
Sep 05, 2009 | Samsung ML 2010 Laser Printer
I have a samsung ml 2851 nd that won't print, and says the toner cartridge is low - I replaced with cartridge 209 (which office max said would work) and it still flashes the red light and says there is...
The counter needs to be reset most likely. I can\t locate a reset code & steps for you. Try calling samsung and ask about the toner reset you replaced the cartridge and its still showing the count from the old cartridge.
Apr 23, 2009 | Samsung ML-2851ND Laser Printer
Flashing on/off light on hp deskjet 3520 printer
Introduction The printer lights indicate the printer status. These lights can be on, off, or blinking (flashing), depending on the status of the printer. The sections below describe the most common combinations of blinking lights, how to fix the issue, and how the issue is caused. NOTE: The light patterns included in this document are described as blinking or flashing lights. For the purpose of this document, "flashing" means the same as "blinking." Blinking lights Printer lights can can blink for more than one reason, so the solution can vary. These solutions need not be performed in a specific order, but solutions for the most common issues are presented first. Blinking lights are often accompanied by an error message on the computer screen, which might help determine the solution. Issue: Power light is blinking
c00374282.gif Solution
Close the cover.
Cause
Printer cover is open. Solution
Insert appropriate media in the In tray.
Cause
The printer is out of paper. Solution
  • Change the printer's print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
Cause
The printer has difficulty picking up label media. Solution
Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
Cause
There is a paper jam. Solution
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Cause
There is a problem with a print cartridge. Solution
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Cause
The print cartridge has partial loss of electrical interface with the carriage connections.
Mar 03, 2009 | HP DeskJet 3520 InkJet Printer
Hp lj 2500 flashing yellow light
The yellow-print-cartridge
light is blinking, and the
printer stops printing.
 The print cartridge is
empty or missing.
 The printer cannot
detect the print
cartridge correctly.
1. Reinsert or replace the print cartridge.
2. If the print-cartridge light is still blinking but the
Attention light is not on, turn the printer off and
then back on.
3. If the problem persists, repeat the above steps
with yellow print cartridges until the error is
resolved.
4. If the problem persists, replace the printcartridge
E-label reader, which is located on the
pressure assembly of the print-cartridge
carousel.
Jan 09, 2009 | HP LaserJet 2500L Printer
Dell 944 photo all in one printer
Set printer to print multiple copies. Put in less amount of paper. While printer is waiting for more paper, change cartridge.
May 21, 2008 | Dell 962 Photo All-In-One InkJet Printer
Canon BJC 85 printer
PRINTER BEEPS (5) TIMES, ERRORS
Nov 29, 2007 | Canon BJC-85 InkJet Printer
Printer prints lightly after changing a cartridge
i guess you have problem with the poor quality ink.
faced same problem.
i re-filled with best ink in the market and the problem was gone..
i hope that helps
Mar 21, 2007 | Samsung SCX-4100 All-In-One Laser Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
140 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
