Question about HP LaserJet 4650 Color Printer
HP 4650 hangs at initializing
Just like the person who posted, my HP laser jet 4650 boots up, successfully tests the RAM and then gets hung up initializing.
  • treybillings Oct 14, 2009
    Thanks for the suggestion. I had heard that the network card could be an issue so I tried that already, and the printer still hangs when booting. So I found a used formatter on eBay for only $20, and I'm going to try to replace that by myself. The MidCom Data repair people wanted $290 minimum in labor charges and listed the part at $1000. Yikes.
  • 81 Answers
Remove the jetdirect network card. Then power it on and see if it goes ready. If it does then it could be a fault with the jetdirect card
Posted on Oct 13, 2009
New memory, the board just beeps
First of all that board supports DDR400 (PC3200) so why did you get PC2100 chips?
Anyway, do a bare minimum test (only MB, CPU, RAM & PSU connected, nothing else). Remove all the RAM and test each one individually. Properly insert one into the first RAM slot and test by booting until the POST RAM test is finished. Shutdown and repeat the test with the same RAM module in slot 2 and keep repeating this for every slot. If successful in every slot, mark that module as working then try the other RAM modules using the same procedure.
  • As soon as you find one that doesn't fully pass the POST test, mark it as faulty.
  • If some pass in one slot but not another, then mark it as faulty.
  • If they all fail to pass on a specific slot, mark that slot as faulty and don't use it (you can use electrical tape to cover the slot for future reference).
Once you've finished the bare minimum test, try 2 RAM modules this time (use only the modules that you found to be working from the above tests). Mix and match the RAM modules & then try 3 together and even 4 (if you found all of them to be working fine).
Finally once you're satisfied you've found the modules that work properly, boot with memtest and test the RAM for any problems. If they all seem to work fine individually, boot them individually and test with memtest to determine which ones are actually faulty.
Jul 13, 2012 | HP Compaq Presario SR1610NX (ED865AA) PC...
AT POST motherboard hang at INITIALIZING USB.....
Several things you can try:
  • Remove the CMOS battery leave for 10 minutes and re-insert and try to reboot
  • If this fails to solve the issue, check the BIOS (F2 on boot) and disable USB legacy support
  • Then if that fails, try swapping out the RAM modules until you manage to get a successful boot.
  • If you suceed in this, download memtest and check the integrity of the ram modules, it may be you have an intermittently faulty ram module.
  • If this fails, it is likely that the USB controllers on the motherboard are damaged
May 19, 2012 | ASUS P5GL-MX Motherboard
This is for a HP Laser Jet 4. I have had it for years and it has worked well. Now on an erratic basis, paper gets hung up sometimes only partially coming through (with wrinkles at the end) other times it...
Symptoms: Your HP LaserJet 4/4M is constantly jamming at the back of the printer. Sometimes the paper is folded like an accordion. Other times the paper has a big curl on the bottom
How to fix:
http://fyrskeppsvagen.com/tips/printers/hp_lj4/paperjam_accordion.html
Sep 28, 2009 | HP LaserJet 4 plus Printer
My motherboard have four leds in red light, d0 dled2,dled3 and don`t start up
Hi ntamayo,
Here is the description of what the four leds indicate:
d9c5d26.gifSystem Power ON-The D-LED will hang here if the processor is damaged or not installed properly.
1d08ad7.gifEarly Chipset Initialization
14ff182.gifMemory Detection Test
- Testing onboard memory size. The D-LED will hang if the memory module is damaged or not installed properly
1719312.gifDecompressing BIOS image to RAM for fast booting
1cab634.gifInitializing Keyboard Controller
3b994fe.gifTesting VGA BIOS
- This will start writing VGA sign-on message to the screen
2b36bf2.gifProcessor Initialization
- This will show information regarding the processor (like brand name, system bus, etc...)
f53faac.gifTesting RTC (Real Time Clock)
9ec1db5.gifInitializing Video Interface
- This will start detecting CPU clock, checking type of video onboard. Then, detect and initialize the video adapter
4f7c881.gifBIOS Sign On
- This will start showing information about logo, processor brand name, etc
6a25253.gifTesting Base and Extended Memory
- Testing base memory from 240K to 640K and extended memory above 1MB using various patterns
1bef2e1.gifAssign Resources to all ISA
e664b69.gifInitializing Hard Drive Controller
- This will initialize IDE drive and controller
c3b6c58.gifInitializing Floppy Drive Controller
- This will initializing Floppy Drive and controller
3afd28f.gifBoot Attempt
- This will set low stack and boot via INT 19h
24b95b0.gifOperating System Booting
When your motherboard is stuck on any of these signals, that's a clue that something is wrong with that particular device on the board. Replace it and try again.
Good Luck
And don't forget to leave a rating,
Thanks
Mark
Sep 16, 2009 | MSI MB INTEL E7520|E7520 Master-S2M RTL...
Message "card slot not initialized
The HP Color LaserJet 4650 printer also has three flash memory card slots for printer firmware, fonts, and other solutions. The HP Color LaserJet 4610n does not include any available flash memory card slots.
■ The first CompactFlash slot is reserved for printer firmware.
NOTE Use the first flash memory card slot for firmware only. The slot is marked “Firmware Slot.”
■ The two additional CompactFlash memory slots in the HP Color LaserJet 4650 printer enable the user to add fonts and third-party solutions, such as signatures and personalities. The slots are marked "Slot 2" and "Slot 3."
--- These card slots are located inside the Formater unit. Most likely you either are missing the firmware card or it's defective.
Hope this helps!
good luck!
Aug 31, 2009 | HP LaserJet 4650 Color Printer
Looking for a exploded diagram/parts list for a HP 4550
Here is a link to exploded diagrams for HP color Laser Jet printers:
http://www.printersupplies.com/c-HPCLJPRINTERPARTDIAGRAMS.html
Take note that the site does not have the 4550 model, but has a 4500 and 4650 which possibly has the same or similar internal parts.
Hope this helps you.
Regards,
Graemevm
Apr 25, 2009 | HP Color LaserJet 4550 Printer
HP 4650 stops at "initializing"
REMOVE THE BATEERY IN THE CARD AND DO COLD RESET
Apr 20, 2009 | HP LaserJet 4650 Color Printer
Help find installer softwareforhp laser jet 2300d
Pls start here. Click on the appropriate Operating System.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 02, 2008 | HP LaserJet 2300d Printer
HP LaserJet 4650 Color Printer Logo
508 people viewed this question
Seeker5211
Seeker5211
