A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
OK, guess that wasn't the problem. Could you provide a little more detail on your problem? Some questions that may help analyze the problem:
Are the pictures taken by the camera also black when downloaded to your computer?
Did you see any movement of the shutter when you looked down the lens and took the picture for the stuck shutter fix?
Have you tried pressing the DISP or DISPLAY button on the back of your camera to see if the screen was accidentally turned off?
