Question about Konica Minolta magicolor 5430 DL Laser Printer
Color printer printing out 2 parellel stripes on the paper
The color printer has printed out 2 parellel stripes on each paper, the waste bottle is OK and not full. How to get rid of this 2 stripes?
    Sergeant:
  • 195 Answers
Clean your printer with a soft brush.....then wipe rollers with a damn cloth...
Posted on Oct 06, 2009
Lines on print. There's are three lines on picture print only. Can't see the line on document. It's about 1/4 inch wide and going throught top to bottom.
Have ou gone into your menus. Into troubleshooting, then image quality.
You will want to run both the eliminate light stripes and eliminate smears procedures. that will purge the print head, blow air through the jets and hopefully resolve the problem. I do believe the 8550 has a Jet Substitutin procedure where you can do a workaround and make other jets make up for the light areas.
here are some directions, Will forward more
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Print Quality Problems], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Troubleshooting Print Quality Page], and then press the [OK] button.
  4. Evaluate the 'Light Stripes Test' page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. The 'Light Stripes Test' page is the last page of the Troubleshooting Print Quality Page that printed.
    WARNING: To avoid injury, do not touch the sharp metal strip attached to the clear rubber wiper blade in the Maintenance Kit.
  5. Use a clean lint-free cloth or a new paper coffee filter to gently clean the maintenance unit's clear rubber wiper blade, use only a wiping motion across the entire length of the wiper blade, and then empty the waste tray. A dirty maintenance kit wiper blade can cause white lines and weak or missing printhead jets.
  7. Repeat step 3 to reprint the Troubleshooting Print Quality Pages. If there are no missing or partially missing color bars then the print quality problem has been resolved. If there are missing or partially missing color bars then the printhead cleaning procedure will need to be performed. Continue with the next section.
To clean the printhead using the basic eliminate light stripes procedure:
  3. Press the [Up] or [Down] arrow button to select [Eliminate Light Stripes], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Basic], and then press the [OK] button. The printer will perform a head cleaning, which will take about five minutes. The printer will then print a cleaning page and a light stripes test page.
  5. Repeat steps 1 - 4 one more time. If there are no weak or missing jets then the print quality problem has been resolved. If there are still weak or missing jets after two basic light stripe cleanings, continue with step 6.
    NOTE: Do not try the Advanced Eliminate Light Stripes Cleaning mode without performing two basic cleanings first.
    To clean the printhead using the advanced eliminate light stripes procedure:
  6. Press the [Up] or [Down] arrow button to select [Advanced], and then press the [OK] button.
  7. Select the missing jet color and number. If necessary, check the light stripes test page to determine the color and jet number of the missing jet.
    NOTE: Only perform the advanced light stripe cleaning once. If weak or missing jets still persist, continue with step 8.
  8. Print the Troubleshooting Print Quality Page. Evaluate the Light Stripes Test page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. If necessary, perform the basic eliminate light stripes procedure one more time. If the Advanced Eliminate Light Stripes procedure does not resolve the weak or missing jets, perform the Enable Jet Substitution Mode. See the Related Items below.
Feb 05, 2010 | Xerox Phaser 8550DP Printer
BW print OK Color print has 'smudge' as well as print.
Sounds like you have color toner contamination in the print engine, It could be the toner cartridges spilling toner, or cleaning modules, take them out carefully and clean them, it also could be the waste toner bottle needs emptying. Take care not to inhale toner particles.
Jan 11, 2010 | Lexmark C510n Laser Printer
Color ink for ip1000 does not flow..??
Now put out u color cartridge and take one tissue paper or toilet paper then put ink color head to paper(soft pressure).after that see u paper are inside show three color appear in paper????(red,yellow and blue).if all have means you cartridge ok if only same or no any coming out means u color ink problem need to replaced new unit.
if got all color out better u open u printer body and check are all cable u plug in back is correct or wrong position??.second u can try go to printer preferences go to find print out in color or in gray-color and change their setting to print out in color
Sep 01, 2009 | Canon PIXMA iP1600 Printer
Pale vertical stripe on black prints
It sounds like the black drum unit needs to be replaced.
Apr 23, 2009 | Ricoh Aficio CL3500N Laser Printer
Pages printing blank
Resolving white, light lines or streaks (eliminate light stripes)
From the printer, print the Troubleshooting Print Quality Pages.
With Troubleshooting highlighted, press the OK button.
Scroll to Print Quality Problems by pressing the Up or Down Arrow button. Press OK.
Scroll to Troubleshooting Print Quality Page. Press OK.
Evaluate the Light Stripes Test page for missing printhead jets (missing cyan, magenta, yellow or black color bars).
Clean the maintenance unit's wiper blade and empty the waste tray. A dirty maintenance drawer wiper blade can cause white lines and weak or missing printhead jets. Using a clean lint-free cloth or a paper coffee filter, gently clean the blade with a wiping motion across the entire length of the wiper blade.
Dec 20, 2008 | Xerox Phaser 8400 Laser Printer
Thought I would ask you, since u have answered Ricoh CL3500N
According to the maintenance manual, broken lines are caused by the "dithering" setting. Also there is an in depth color calibration process you can execute. Have you checked the PCU unit?
Here is the maintenance manual:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/cl3500/cl3500en.htm
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 16, 2008 | Ricoh Aficio CL3500N Laser Printer
Stripes down left margin
Hi, I have the same problem, which has just been diagnosed as a defective developer drum by a repair specialist. The new part is $120.00. Should have the serviced unit back
SR
MFC-9840 prints vertical stripe ~2" from right edge on all color printouts
The first thing i would try to do is clean the corona wire on the drum unit. It might also be a faulty magenta cartridge.
Dec 07, 2007 | Brother MFC-9420CN All-In-One Laser...
Konica Minolta magicolor 5430 DL Laser Printer Logo
326 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
