Question about Microsoft Xbox 360 Controller
Have taken the controller apart once before since my buttons were a bit loose (that was fixed) and now my analog sticks squeak and are a bit rough to use. Even when not touching them they are also off centered. Any ideas?
  • killer_insti Oct 07, 2009
    I've tried WD-40 (even if it messes it up, its already a bit messed up lol) but eh, trying something is all i can think of. It got the sticks moving around again though. (not just my buttons are bit pushed down so theyre not as elevated.
  • 733 Answers
That's normal wear and tear. best off buying a new one. usually the left goes out first. it's a pain trying to unsolder and resolder new analog sticks. trust me i've tried and i;m a pro at soldering. if the leads don't come out right away after a few tries, everithing starts to fall apart. like i said. you're better off with a new one. sorry
Posted on Oct 06, 2009
Left analog stick My Xbox left analog stick does
Analog stick might be bad and may need replaced. If you don't feel comfortable tearing it apart, you may want to look into a new / used one.
Oct 12, 2013 | Microsoft Xbox 360 Controller
I got mad and threw my xbox 360 controller and my right analog stick fell out.........how do i fix it
the best way to fix it is to take it apart and try to glue it back on, the tab that holds the stick on may have broke off
Aug 07, 2011 | Microsoft Xbox 360 Controller
When playing any shooter game my right analog stick always looks up but the stick isnt upward and i took it apart the resembled it and it worked fine but after a few minutes it went back to looking upward...
This is coud be a result of the metal stick underneath the analog being loose and there is no real solution to this. You can try to take it apart and trying to secure the metal rod that comes out where the analog is by hitting it down more but this usually happens after wear and some good beatings but is not a major problem.
Jul 11, 2011 | Microsoft Xbox 360 Controller
Xbox 360 Controller "sticky" analog sticks.
Open up your controller with a screw driver and disassemble it a little bit look for the butons and take them out and give it a wash then dry the buttons and put them back into the controller and screw up the controller.da.da....
Jul 24, 2010 | Microsoft Xbox 360 Controller
Issue with right analog stick - Xbox 360 Controller
I'm afraid I've had the same problem and I can shed a little light on it.
I've tried to fix this but to no avail. I have even transplanted the whole analog stick unit with one from a working controller to see if it will work but I have the same problem.
So, my conclusion the problem is not with the stick itself, but with the microcontroller inside the pad which takes the info from the stick.
I took the analog unit out, and plugged the pad into the computer without it , but STILL the vertical axis on the right stick was pushing up even though there was no input from a stick. It seems to be a fault with the pad, not the analog stick.
Aug 21, 2009 | Microsoft Xbox 360 Wireless Controller
The both of my controller the rigth stick quit working.
I've had this problem, too. I tried taking it apart, but to no avail. I was very lucky to get it back together in a semi-working fashion.
It seems that the right analog stick gets used a lot more than the left. I play NHL 09... ALOT! And to shoot the puck, you need to slam the right stick back, then forward. So my controllers burn out rather quickly.
When I took it apart, I found that the analog sticks are sealed up units unto themselves. So if something burns out, it just gets replaced.
My recommendation is that you go to Wal Mart & buy a couple of new controllers, & try not to be so rough on them. ;)
May 12, 2009 | Microsoft Xbox 360 Console
Xbox 360 Controller right trigger doesnt work
Your controller is most likely exhibiting a hardware failure. Taking apart the device voids your warranty. When a button does not work anymore, it is safe to say that you will need to buy a new controller.
The Logitech Chillstream Gamepad is only $20 and works in the same fashion as the XBOX 360 Controller (uses the same xb360 XInput controller driver too!)
Give that a look.
Aug 24, 2008 | Microsoft Xbox 360 Controller
Controller Problem
most probably the controller's carbon button inside the controller is already worn out and is sticking on the controller's printed circuit board (PCB) there are some replacement carbon button that can be bought for a cheap price
or
if you are using an analog controller, check if the analog stick is loose in feeling, this might affect the controls as well because good working analog sticks are a little stiff when pushed
Jun 30, 2008 | Sony PlayStation 2 (PS2) Console
My playstation 3 analog sticks are becoming more stiff and are sticking in every position except the centre, which causes major problems when trying to stay still in games.
Yeah my controller started sticking up and not centering properly when released. I tried everything to clean it up but nothing worked untill I went to the local electronics store and got some contact cleaner with lubricating oil. (MG Chemicals - Nu-trol contact cleaner with special lubrication oils) Open the controller ( see youtube) the analog sticks cannot be taken apart but if you push the stick up you can squirt the base and work the cleaner/lube into the base. I squirted a bit on all 4 sides (left, right, up , down) working it in making a circular motion with the stick. Worked quite well and is the only thing so far that works at all. These seem to be sealed units (the sticks) with no way to open the business end to clean up the contacts. I put a toothpick under the tracing sheet to help with evaporation of the cleaner. Hope this helps.
Regards, Mike in Victoria
May 20, 2008 | Video Game Consoles & Games
Analog stuck up
Provided you havent taken you PSP apart and moved the analogue stick try calibrating it before starting the game.
Go to Settings/System Settings,
Select system information,
Once the MAC address is displayed rotate the analogue stick in a circular motion.
Exit the screen and Voila one calibrated stick.
Apr 01, 2008 | Sony PlayStation Portable (PSP) Console
Microsoft Xbox 360 Controller Logo
207 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
