Question about Zenith R57W46 57" Rear Projection Television
My zenith big screen started making some loud clicks tonight. Happens several times in a row and then nothing for awhile but will occasionally click from time to time.
2 Suggested Answers
  • 150 Answers
SOURCE: zenith E44W46LCD turning off
That would be the first thing I would try as it is probably flakey.
Posted on Jul 09, 2007
Solenoid clicking
If you mean a series of rapid clicks, like a machine gun, either the battery is low (but you stated the battery is fully charged), or a bad connection.
One loud click is usually the starter relay, about a $10-$15 part.
Nov 15, 2013 | 2008 Big Dog Pitbull
Electrolux Washer dryer EWW 1273 banging
I think a sensor is being faulty when you load and go to use the unit. Also might want someone to check out the timer on the unit just in case it is going out on you.
Aug 08, 2012 | Washing Machines
2000 Plymouth Breeze. Car would crank slow a couple of times then start. Replaced battery but still did it. Drove it tonight and when I tried to start it later, it now won't even turn. Is it starter or...
possibly your alternator. if you have a multimeter set it to volts dc and, without the car running, set the probes on the battery. then start the car and repeat the process. the multimeter reading should jump if the alternators good. you will need to charge the battery beforehand it sounds like, do not jump it. if all else fails disconnect a jumper lead befor starting to ensure nothing electrical gets damaged.
Feb 12, 2011 | 2000 Plymouth Breeze
When click bb button my options buttom doesn work
If you are at the home screen and the phone is unlocked, press the "blackberry" key, next to the green answer button. The on screen menu should show "options". If you click on this, nothing happens? If it does pop up with the next window, the row adjustments are in the middle of this screen under "Set Homescreen Layout". Once you have selected this, be sure to press the blackberry button again and save your selection.
Hope this helps!
May 27, 2009 | RIM BlackBerry Storm 9530 Smartphone
Weird clicking noise and computer freezes.
Laptops have very few moving parts. Your problem is more than likely either a fan or your hard drive. Remove the hard drive, start the computer up and just let it run for awhile. If the clicking noise never comes up then thats your problem. If it does, its probably a fan.
Disregard anything on the screen itself, just let the PC run. It sounds like after the hard drive has been spinning for a minute a motor starts to die.
Jan 29, 2009 | Acer Aspire 5100-3357 Notebook
Dryer makes a loud buzzing noise then quits working.
Sounds like the motor's done. That thing is probably the start-run switch. Not worth trying to fix on an old motor. I've found dryer motors to be fairly generic, you should be able to find a replacement. I use Repairclinic.com when I can't get parts locally.
Nov 26, 2008 | Magic Chef CYE4000AWW Electric Dryer
Tv making popping sound
Turn down the volume and see if you still hear it,a loud pop or snap could be high voltage call your servicer in your area ASAP
while its under warranty and have him check the high voltage circuits for a intermittenting pop or snap.And have the model # ready!! Good Luck!
Dec 08, 2007 | Hitachi 53UDX10B 53" Rear Projection...
System Error (OeO1)
With a system error there is actually no way to fix this problem at home, it will need to be sent in for service. A system error is internal in the camera and usually is a software issue. The service center's number for Casio is 1-800-706-2534, then option 1.
Jul 14, 2007 | Casio Exilim EX-Z57 Digital Camera
Zenith R57W46 57" Rear Projection Television Logo
18 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
