Old Solidtek ACK-595 keyboard needs maintenance
I have an old, used Solidtek ACK-595 keyboard that has a 5-pin DIN connector, with a PS2 adapter. It is very stiff. Many keys do not depress when struck anywhere but directly down. Can the keyboard action be lubricated? I need a small PS2 mini-keyboard, and they are scarce, so I'd like to utilize this one, but it's almost unusable as is.
  • 2,841 Answers
You may be able to pry the keys off one at a time and clean them. If that does not work I would buy a new keyboard. Here is one for $20.95. http://www.axiontech.com/prdt.php?item=8918 I found plenty more by searching Google with the term, Solidtek ACK-595
Posted on Oct 06, 2009
  • 416 Answers
Yes you can lubricate the buttons by simply popping them off and using some sort of gear grease, white Lithium grease works great. just apply a small bead on the bottom tip of the key and reinsert it.......those older keyboards are set up a little different so they do need cleaning too. While you have all the buttons off, take the time to clean the entire keyboard as thoroughly as possible with an old toothbrush and some isopropol alcohol. when u get it all back together you will prolly still have to depress the buttons a little harder than you would expect, thats just how they are.
Good Luck and pls rate this post.....
Hello, Is there a print screen on the Mini keyboard ack-595u ?
if you have it and can't see it then perhaps it doesn't but ctrl and p does the same thing
Feb 27, 2015 | Solidtek ACK-595U USB Mini Keyboard with...
How to hook up keyboard to my dell Inspiron 530
Keyboard come with two different connection options these days. The old PS2-style (circular with ~5 pins) port are less common on current machines these days. The Dell Inspiron 530 is one of them; you need a USB keyboard or a PS2 to USB adapter. This adapter, http://www.amazon.com/Adesso-Adapter-connects-connectors-ADP-PU21/dp/B00008ZPED , is an example of how you would connect your old keyboard to your new computer. There are USB ports on the front and back of the tower.
If you bought the computer new, it should have come with a USB keyboard.
I hope this helps.
Feb 24, 2013 | Dell Inspiron 530 Desktop Computer
When I hit any key, it throws in a bunch of asterisks
Could be either a short in the Keyboard or it is not USB adapter compatible, some mice are like this. Plug it into a computer with PS2 port and see if it still malfunctions, if it does then the keyboard has a short, if not, it is incompatible with a USB adapter. Keyboards send two codes whenever a key is pressed, one for the key itself and one to let the computer know it the Shift/Ctrl/Alt keys are being pressed.
May 16, 2017 | Zippy WK-610PS2 (wk610 (ps2)) Keyboard
I have a BTC keyboard, Model #: 9000A. A wire became broken in the PS/2 male plug. I need a Schematic so I can solder on a new plug. I know this is a very old keyboard, but I like it and do not have the...
Unfortunately there is no color code for the cables in the PS2 connector. All the details that I can give you is that if this is the PS2
The pin #1 moves DATA.
The pin #2 is not connected or DATA2 (usually not connected)
The pin #3 is GND
The pin #4 is VCC for power (+5 VDC)
The pin #5 is CLK for Clock
The pin #6 is not connected or CLK2 (Usually not connected)
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Oct 18, 2010 | Computers & Internet
USB Keyboard and mouse wont work with PS2 KVM with adapter
Have you tried rebooting once it is connected? Not sure if it makes a difference, but I know you can not hook up PS2 peripherals without rebooting.
Nov 03, 2009 | Dell OptiPlex GX280 PC Desktop
My dell sk8110 keyboard has a round purple connector plug that fit my old computer. My new computer has only USB ports. How can I connect my keyboard to the new computer?
http://www.microcenter.com/search/search_results.phtml?keyword=usb+adapter+ps%2F2&category=
The round purple connector is refered to as "PS/2" type connector. You can find an adapter that converts PS/2 to USB connector. The above link was just to show what I was refering to. Hope this helps.
Aug 24, 2009 | Dell SK8110 Keyboard
USB k-595U solitek keyboard, switch to an AT (DIN5) connector
Hi there:
when you installed the keyboard was the computer off and did it show a new hardware found when you turned on the computer it should have and have you tried it on a nothere computer also cause it may be a compatiablity issue here
Feb 16, 2009 | Solidtek ACK-595 Keyboard, Keypad
Broken ps2 connector ACK-595 Keyboard
go to this webpage http://en.wikipedia.org/wiki/PS/2_connector there´s a list of different wire arrangements it could help you.
Nov 22, 2008 | Adesso ACK-595 Keyboard
Cmos checksum error - defaults loaded
Ports are usually labelled - look carefully.
Try manufacturers manual.
Could be that keyboard is the larger 5 pin DIN socket (old IBM AT keyboard).
Aug 10, 2008 | Computers & Internet
Ack-540
Open up the keyboard and disconnect the cable that connects the pad to the main board.
Dec 11, 2007 | Solidtek (KB-540BU) Keyboard
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
