Question about Mr. Heater MHU45LP
MHU 75 Model Mr. Heater
I have just installed a Mr. Heater furnace in my garage. After I completed the installation I plugged the furnace in, set the thermostat and the furnace fired up and was running fine. I went into the house for about 30 minutes and when I came back out the blower was blowing cold air. When I checked the control board the LED was blinking 4 times which, according to the book means the high limit or roll out switch is open. The only information I can find in the book says that this normally closed switch opens on a temperature rise and to check for adequate combustion air before manually resetting switch. The switch is supposed to be located on the burner box top behind the ignition control board. I see what I believe is the switch they are talking about but I see no way to reset it. Can anyone help?
  • rich2154 Dec 26, 2007
    I just want to thank hotuna for helping with my problem with my Mr. Heater. The information you gave me led directly to having heat in my garage on Christmas day. The roll out switch is defective and by bypassing it I was able to get the furnace to work. I will be ordering a new a new roll out switch this morning. Thanks again for your helpful response.
  • corradoking Dec 30, 2008
    I have same problem, tried bypassing and heater just runs the cold fan on startup that is suppose to engage after the flame is present. The heater makes no attempt to call for heat.
  • 288 Answers
The roll out switch is a small disc shaped part about the size of a nickle. There may be more than one. anyway there is a button shaped like a small peg in the center if it, push it in and it should stay in. You may need to re examine the limit switch, because this is what it sounds like. they are rated for a set temperature, so your application may need a higher temp. A simple way to check parts like these is to by-pass them by taking the wires off the part and connecting them together. If this solves the problem, that it. My only concern is that this is a new installation, and maybe its not venting adequately or its burning up all the usable air in the room. That's why most of these parts are on the equipment.
Posted on Dec 24, 2007
  • rligus1 Feb 25, 2014
    I bought a L4064B Universal Combination Fan and Limit controller from our local Grainger store to replace the original controller on an old Tappan model SGUF140D48E7, s/n 77 19739 140,000 gas furnace. I'm having trouble finding the furnace high limit setting, and fan on/off settings. The range of the old high limit was 170-210 F, and the fan range was 80-120 F. Can you tell me what the correct high limit and fan on/off settings should be? The manufacturers plate indicates temperature rise is 70-100 F.
Mhu 75, only one burner lights
did you put a drip pocket on the line to the heater
Apr 05, 2012 | Mr. Heater MHU75NG
I have a mr heater 75 btu garage heater it lites and stays on for 5 seconds and gos out relites gos out than it locks out
Try cleaning the flame sencor , check pilot is clean , check the tubes on the pressure switch are not split and are tight , there are high and low limit switches on there try jumping them out one at a time , see if any of this helps .
Aug 22, 2011 | Mr. Heater Natural Gas Garage Heater -...
Mr heater 75000 btu thermostate turned up exhaust air turns on and ignitor doesnt ignite and times out
Probably your ignitor is bad...
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
Feb 23, 2011 | Mr. Heater Natural Gas Garage Heater -...
check to see if the gas line or gas valve is blocked
Jan 29, 2011 | Mr. Heater MHU45NG
Green light flashes when i try to start my TFO 75 garage furnace
Looked at Sterling garage heaters in general. 3 blinks read pressure switch. You should have code chart on furnace door. Pressure switch symptoms are blocked vent or moisture in small hoses connected to pressure switch or bad pressure switch. If small hoses have sags take off one end and dump or both ends and blow through.
Jan 23, 2011 | Sterling RF75 Propane Gas Garage Heater
I installed a Mr Heater 45,000btu heater in my garage, when I turn it on to fire, it fires for a moment, I get about a 3 inch flame for a moment and then it goes out. What do I need to do?
clean the flame sencor first check connections on flame sencor , check you have gas to heater check limits high and low jump then out one at a time see if it lights , or check pressure switch if fitted jump this out and check tubes to it
Jan 20, 2011 | Mr. Heater Natural Gas Garage Heater -...
My mhu 75 worked just fine until the regulator on the tank froze. Got the gas to flow, combustion air blower came on but no igniters. Control board LED is blinking the fast flash saying everything is fine....
check the flames sencor is clean and the igniter check connections to the board on both wires , check hoses to pressure switch are not cracked or , you could cut off abit off the end to get better connection on the tubes hope this helps
Jan 14, 2011 | Mr. Heater MHU45LP
Heater turns on and heats garage to set temperature, than shuts off. when the temperature drops, the unit kicks on again. everything starts working again but only for a few seconds and than shuts off. it...
Problem: Your furnace will not ignite the gas to produce heat for your home. When a furnace has a bad ignitor what I see most of the time is the following sequence of operation:
1. Thermostat calls for heat. 2. Draft inducer motor starts. 3. Pressure switch attached by a small plastic or rubber tube senses the negative pressure produced by the draft inducer and closes. 4. Draft inducer runs for 30 seconds to a minute before you hear a gas hissing sound. The ignitor did not glow, the flame sensor (a small metal probe about 1/8" in diameter, with a white porcelain base) does not sense the flame, so after 8 to 10 seconds the hissing sounds stops with no ignition of gas to heat your home. Your furnace shuts down and goes into a lock out condition until you turn your power switch back off and on again. Then the sequence starts all over again with no ignition of the gas. Solution:You probably need to purchase and install a new ignitor. I would suggest that you inspect your ignitor closely for cracks. Make sure you do not touch the ignitor with your bare hands. If you do not visually see a crack, then you could have a furnace control board problem or a limit, rollout switch problem. The furnace's control board might not be supplying the voltage to the ignitor.If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Dec 11, 2010 | Mr. Heater Natural Gas Garage Heater -...
Mr. Heater MHU45LP Logo
2,187 people viewed this question
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Mack Baxter
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
