We have the simplicity phd 3 in 1 unit, when we have it on the humidify mode the water leaks out of the bottom of the unit. Where and why is this happening? any solutions?
Comments:
Oct 15, 2009
- My husband took off the panels and took a look at everything inside and couldn't find anything????
- Interesting. Who installed the unit? Not looking to blame or put anyone down. All dehumidifiers cause moisture in the air to condensate, so the fact of a need to dispose of the water is a given. The unit can be equiped with the incovenient catch pan or bicket, but, This unit doesn't sound that cheap. Yet it does condensate and water disposal issues still exist. Ok, At the point of leakage is there a Knock out like hole where a fitting could be installed? Walk around the housa and look for a pvc pipe sticking out of thr foundation at or near ground level. Is this jome equiped with central Air Conditioning? Is it a slab floor?
I'm waiting for an andwer. In fact, call me @ 909-630-3192
Was this helpful?
Yes
No
Popular Solutions for Danby 60Pint Dehumidifier with
I got this from my neighbor, i want to use it as dehumidifier, worked well but then the intenral...
(More)
I got this from my neighbor, i want to use it as dehumidifier, worked well but then the intenral tank got filled and I do not seem to be able to find anyway to empty the tank. I am using it in my 1st floor so drain option is not there for me. How do I empty the internal tank? thanks
i lost the user manual and i have always `e7' flashing and not working just use it as a...
(More)
i lost the user manual and i have always `e7' flashing and not working just use it as a deshumidifires
Ice is building up and coming through tth efront of unit at the bottom where the filter is. What is...
(More)
Ice is building up and coming through tth efront of unit at the bottom where the filter is. What is causing this?
When the top bucket is filled for humidifying, the reservoir below it fills and starts leaking out...
(More)
When the top bucket is filled for humidifying, the reservoir below it fills and starts leaking out the bottom of the unit.
