Computer does not fire up. I do have steady green light on power supply. All motherboard connections appear to be tight.I have come home before to a beeping noise in the past. After resetting the machine it started fine. This happened approx. 3 various times.
    Sergeant:
  • 233 Answers
That beeping noise may be due to over heating.
Most machines today have a temperature setting that will turn the machine off once the temperature reaches a certain point.
Safety feature to avoid damaging your cpu and components.
The shut down and restarting allows the CPU to cool down briefly.
Thus allowing you to start the machine again. Usually it will shut down again once the temperature threshold is again reached.
Good test is let the machine sit for 30 min. If it immediately starts up and shuts down a few minutes later. Heat build is usually the problem.
Typically this is due to heat sink or Fan on the computer CPU.
Check to be sure both are connected to the CPU and functioning.
If you have a fan on top of the heat sink above the CPU. Make sure it is working correctly. Dust build up over time will eventually kill the fan bearings or reduce airflow. Heat sink can and will become clogged with dust also. Replacement fans are easy to find. Heat sinks are even easier to clean.
Depending on your machine and CPU position replacing the fan can be a challenge. But can be done in a few minutes with minimum tools.
Each bios has different post codes and it is difficult to tell what is happening with out knowing the bios of your particular machine. Listen for the beeps and check your computer manual.
You can also google for this. Here is a web site that lists a few bios P.O.S.T codes.
http://www.computerhope.com/beep.htm
Once you know the beep sequence you can look it up. Usually points to the problem and you can go from there.
Posted on Oct 07, 2009
Testimonial: "This is all good information...Thank-you. I will be using this to help me look a bit further for my problem."
  • 138 Answers
First be sure,, check the power connectors all are intact and tightly connected, and power is going on to your cpu, next check you monitor display connection from your cpu to monitor is intact,, if still nothing happens,, there may be problem in display card or mother board
Posted on Oct 06, 2009
Power Problem with 2Wire 2701HG-B
Sounds like a startup self test. All wireless devices go through a power on self test. Does it connect? You can connect to it and go online? I rarely turn mine off, only in a electrical storm.
Nov 22, 2012 | 2wire (2701HG-B) Wireless Router
Green blinking light on power supply. Computer will not power on. Power supply appears to be good because I connected black and green leads from motherboard connector with a small piece of wire, and the...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
don
Feb 12, 2011 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
Green light on power supply flashes rapidly when I plug the computer in. Computer will not power up at all (no cooling fans start, no lights illuminate and no beeps come from the unit). When the power...
if the cooling fan on your PSU power supply unit does'nt spin when you start your PSU is faulty if it does then
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Oct 21, 2010 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
Cant get computer to
Disconnect everything from the motherboard except the power supply, CPU and power switch.
Turn on the computer. You should hear 3 beeps because you removed the memory.
If you don't hear any beeps, check the power supply. Check all the connections. Did you connect the 4 pin power? Did you skimp on it? A common mistake is to get a cheap, high-power supply. Just because the box says it's 1000 WATTs doesn't mean that will carry a steady load.
Still nothing...
It's either a bad motherboard or processor. If you have another processor that is supported on that board and you know it works, try it. If it boots return your CPU for a good one.
Unfortunatly, if it doesn't boot with a known-good processor that just proves the board is bad; it doesn't prove your CPU is good. You may have more issues.
Mar 08, 2010 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Blingking light on my motherboard, no power.
Chances are your power supply and computer is fine! From other forums on this problem (which I also had), I've learned the following:
1. If you unplug the computer for a half hour or so (the blinking green light will gradually slow down and quit) and plug it back in, the situation will correct itself and the green light will be steady; however if this does not work,
2. a reset that works for a lot of people with the blinking light problem involves leaving the power supply plugged in and unplugging the power supply connection at the motherboard (it usually also has a blinking green LED) and plugging it back in. To read up on how to do this, Google "blinking green light on computer power supply" and read through some of the forums and you'll come on more specific instructions. Usually, you have to wade through everybody telling you to replace the power supply or your motherboard is fried. It's worth a try for a quick fix, just in case those situations don't apply!
May 30, 2009 | Sony VAIO VGC-RB42G PC Desktop
Windows problem
The green light on the motherboard is not uncommon to be ON when the computer is not, my asus motherboard is the same way.
First i would check all my power connections to the motherboard , it's easy to miss something like the 4-pin molex that also attaches to the motherboard OR the power connector that goes to the hard drive. check these and all other powersupply connects INSIDE the case , fire it up and post here again if that doesnt clear the issue...
Regards..
Apr 07, 2009 | Dell Dimension 4400 PC Desktop
Computer will not turn on. Power supply shows flashing green.
depending on the make of computer, a power supply cost's around $20.
Mar 12, 2009 | HP Media Center m1080n (PC099A#ABA) PC...
Flashing Green Light on Power BESTEC Power Supply
This is an easy fix so here you go nice and simple:
Problem: Your motherboard circuit has been cut.
Causes: Power disconnected during operation. Power outage or short in the surge protector.
Symptoms: Flashing green light on both motherboard and power supply. System will not power on.
Solution:
Step 1: Ensure that both the power supply and the motherboard lights are flashing green, not solid or off.
Step 2: While the power is on, disconnect the power supply from the motherboard. This connection is the largest of the connections and should be listed as the 'P1' or 'Primary' power connection.
Step 3: Wait until the green light on the motherboard stops flashing and check to ensure that the green light on the power supply is now solid. If it is not solid, disconnect the power to the power supply and wait until the light turns off completely. Then reconnect, it should be solid now.
Step 4: While the power is on, reconnect the P1 connection to the motherboard and you should now see that the light on the motherboard is solid.
Step 5: Power on your PC. The problem should not persist.
Warnings: If the power supply light remains flashing after you have restored power to it while it is disconnected from the motherboard, it may be a system failure in the power supply itself requiring replacement. Always be careful when working with an active or live power machine.
I hope this helped! Good luck!
Jun 23, 2008 | Bestec (ATX-250-12E) 250-Watt Power Supply
Comp won't start
Your MotherBoard has 2 LEDs in the lower right corner, each designating a power condition. They are labeled LED14 and LED21. LED14 lights when there is a power source connected. If this is the one blinking it likely indicates a failed power supply. If you have an alternate power supply available that is comparable in power supply capabilities I would try that. LED21 lights when the system is powered on. Replace the power supply.
Dec 03, 2006 | Abit IS7-E2G Motherboard
Computers & Internet Logo
258 people viewed this question
David Payne
David Payne
