Question about Goodman GMS90703BXA Heater
My heater works fine when its a little cold,when its freezing outside it heats for a couple of airs then it would come on and off fine but with cold air blowing.i looked at the codes it blinks 6 times which says something about the rollout switch what should i do
  • lilshortpr Oct 07, 2009
    i hear i should replace the whole furnance cause it costs alot to do a heat exchanger but my heater is only 4yrs old.what you think i should do? and should i try resetting the rollout switch myself?
    Sergeant:
    Champion:
  • 232 Answers
Do not adjust your gas pressure without an manometer or if you dont know what you are doing could be very dangerous. Roll out switches are manual reset if you have an open roll out on a Goodman furnace you probably have a cracked heatexchanger, get a qualified technician out there asap
Posted on Oct 07, 2009
Testimonial: "thanks for answering my question.your not the only one who told me that i was needing more than one persons opinion"
  • 92 Answers
It sounds like you need to tune down the gas valve a little.There is a Large flathead screw on the gas valve,unscrew it and there is a white plastic screw inside it.While the unit is on adjust it so the flame decreases.this should make it not trip the roll out switch.If it still trips the roll out you could need to replace the switch.
Posted on Oct 06, 2009
  • Nathan Ellsworth Oct 07, 2009
    You can adjust without a manometer if the valve is obviously putting out too much gas.I am talking about a quarter to half a turn no more.I my experience it don not change the water column on the manometer that significantly.
Our AF-15 is working right. Not sure what to do. The fan kicks on and instantly shuts off and it will keep doing this until we have to turn the circuit breaker off. It is freezing in this house and we...
We need a bit more information:
So-- you are using the AC unit as a 'heat pump'-- trying to get HEAT from it-- correct?
And is it REALLY COLD OUTSIDE?- (Much below 35 deg. F-- Heat pumps become ery inefficiet as heaters-- since there is so little HEAT to squeeze from the Cold air outside! )
And how long has it been since the unit was CLEANED? For it could be a plugged heat exchaner.
Give us some more answers, and we'll see what suggestions might help next-
Thanks,
Mack B
Feb 27, 2011 | Heating & Cooling
My upstairs heating is blowing cold air. The air handler in the attic is running but no heat. Down stairs is fine, I get heat
Question: Is your heat produced by a furnace? (If so-- what kind of fuel?)
Or is heat produced by Air Conditioning nits working in reverse-- called Heat Pumps?
If Heat Pumps, You realize that when it gets very cold outside, there is not much 'heat' out ther, to get the heat from outside temperature, right?
Sometimes the out-door coils will freeze up, and you get even less heat then--
Please tell us more-- so we can take the clues you give us, and we'll trouble shoot the problems as best we can remotely, like this-
Mack B
Jan 26, 2011 | American Standard Heating & Cooling
I have a Lennex heat pump unit which was installed in 2008. Our area (Savannah, GA) has experienced some abnormal cold temps lately. Yesterday, I noticed the outside of the unit had frost on the unit. ...
Heat pumps are the same as an A/C unit only it works in reverse. Instead of blowing cold air inside and hot air outside it blows hot air inside and cold air outside. The heat being blown inside is extracted form the cold air outside. Its called Latent heat Latin for hidden. Believe it or not even though its 20 degrees outside there is still heat in the air. Example if you want to drop the temperature of a freezer from 20 to 10 degrees you have to remove heat .I know your getting unusal weather and that is the problem. Heat pumps can only work no lower then around 20 degrees outside.Heat pumps are never used above the freeze line. With your unusal temperatures thats basically where you are now. Ride it out. When your temps rise a little your be fine. Im in Chicago.
Jan 15, 2011 | Heating & Cooling
Heat not rising above 62
It sounds like you have a 'heat pump'?-- and you are trying to heat in these cold snaps-- when the outside temperature is down near freezing?
If so-- Heat pumps do not work well that cold!-- so if your system was marginal at heating, when the outside air is 40 or 50 degrees F-- you quickly run out of 'heat' in the cold outside air, to move the refrigerant in the heat pump with any heat wrung out of the COLD-- to bring heat into your house!
Make sense?
Please tell us more-- like how your heat pump worked last year, etc.
Mack B
Jan 08, 2011 | Heating & Cooling
The heater in my 1994 Ford laser hatchback has died.Any clues please?
When you say your heater, do you mean the fan does not blow. or no heat fan blows fine. If it does not blow. The fan is located in the passenger side footwell, Turn fan to high and wack it a couple of times on center of cicular lookin thing, easily replaced by removal of screws around outside. If the fan works fine and it blows cold air make sure temperature adjustment knob is workin fine, you should hear it change when adjusting. One other thing, if someone just flushed your radiator or anything similir to do with coolant, check for a air bubble in the system, purge air out of heater core lines with a garden hose.
good luck
Oct 25, 2010 | Ford Laser Cars & Trucks
'02 Escape, heater cold when outside air below freezing
This could be a few different problems. I would recommend taking it in and having the antifreeze checked to see if it is of a sufficient mix to keep it from freezing. Sometimes the antifreeze will be to thin to keep it from freezing and it will start to freeze in the heater core. If this is the case, the vehicle may not run long enough to thaw out the antifreeze in the heater core to generate heat. Another possibility is that the thermostat is stuck in an open or partially open position not allowing the engine to reach a high enough temperature to generate heat through the heater core. The last possibility is that there is a blockage in the heater core not allowing the hot antifreeze to pass through the heater core thereby reducing the amount of heat drawn off of the heater core. These are but a few of the more simple problems but any of them should be treated by a licensed mechanic.
Dec 26, 2009 | 2006 Ford Escape
I have a goodman ac/heat pump....worked fine last season...now only blows cold air, even in heat setting....help! thanx
Heat Pumps are not famous for being fast heaters. Give it some time to act. Is yours extracting heat from the air or from a water source. If from the outside air, consideration must be given to the temp of the outside air. It takes longer to warm as the temp outside drops.
Yours could be a different problem of course, but let it have a chance to work before you call the repairman.
Dec 12, 2009 | Goodman CLQ36AR49 Air Conditioner
Central air unit two part system, inside and outside. Freezes
If coils are clean and blower is working properly,
then you're probably low on freon.
Jun 09, 2009 | Goodman GMS90703BXA Heater
Central heat and air freezing up
It is not freezing because it's cold outside,It is freezing due to a problem.
It needs to thawed before it will work,
1st:Check or change the filter if need be.
2nd:Make sure none of the vents are blocked off(especially the return)
3rd:The only way to thaw it when temps are low outside,without being out in the weather is to turn on the air conditioner,You will need to use other means to heat your home until it thaws.
and Please if you use the stove for heating,don't fall asleep with it on.
Jan 17, 2009 | Heating & Cooling
Very little heat from heater
the selector flap is not moving all the way to cold or hot position. Under the dashboard on the passenger side is a heat/ac box where all the duct work for the vents originates from. inside that box is the radiator for the heater and the cooling coil for the ac. the selector flap between them is stuck or not moving all the way.
Dec 29, 2008 | 1999 Ford Taurus
Goodman GMS90703BXA Heater Logo
187 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
