Question about Samsung HCN436W 43" Rear Projection Television
Samsung sp43w6hpx/xeu hi when watching my tv there is a shadow around things in green. i was told it was ghoting can you tell me more please. brian
  • 137 Answers
Convergence is out. Go to service menu and set it.
Posted on Jan 24, 2008
Having trouble with samsung projection tv / sp43w6hpx/xeu. done manual convergence and got the picture and colour nearly right but across the top half the tv the picture is bend upward/ what kinda part...
Look for 2 big black ICs they will have the Part number on them,example STK392-110
Mats Electronics has them replace Both ICs. 1-800-628-1118 also in front of ICs is 2 resistors low ohm 2.7 or 3.9 replace them.
Mar 01, 2011 | Samsung Televison & Video
When my samsung LNT5271F is turned it has a DELAYED DISTORTION on the right side half of the tv ,, after about 30 minutes the distortion will get a little clearer but not completely, then a DARK SHADOW...
I have the same TV and it's doing the same thing but on the left side. We had a local repair shop come out to diagnose and he told us this is the result of a loose ribbon cable on the LCD panel that would require replacement of the LCD panel - cost would be about the same as a new TV.
Aug 31, 2010 | Samsung LN-T5271F 52 in. LCD Television
Have a samsung plasma tv and hav lost some channels on the digital switch over, could you tell us how to retune please. The model number of our plasma is PS50Q97HDX/XEU. Thankyou
Just start from the beginning as if you just bought it. Start with Install and let the set do the rest. Watch the screen for any questions that may require an answer or an Enter command and that should do it.
Take in consideration that some cable companies moved some digital stations to a pay plan and you might not get them in HD. The digital stations you get after programming wil be it, unless you upgrade to a different plan.
Nov 23, 2009 | Samsung LE37S71 37 in. HD-Ready LCD TV
Circuit diagram Samsung LE23R88BDX - LCD TV
when I turn off and then Turn on after 10 minutes the TV notwork(by using remote or touch button). I try to disconnect power supply andthen reconnect and waiting a couple of minutes and turn on but no work (nosound and black desktop) .I repeat this procedure many times so some timework and sometimes not work. please help me to solve this problem
Feb 24, 2009 | Samsung Televison & Video
Red a green shadows on most objects!
use manual convergence to re align the colors. the owners manual tells you how to do this. No manual go to samsung. com in the FAQ section
Oct 11, 2008 | Samsung HCL4715W 47" Rear Projection...
Green dots on screen
Green dots on a LCD screen are burnt out pixels and unfortunately are incurable other than having the TV serviced at a high price. One of the reasons it is a good idea to get a warranty on these types of TVs is primarily due to this very problem....burnt out pixels.
Dec 26, 2007 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Samsung SP43W6HPX\XEU Rear projection
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Oct 25, 2007 | Samsung HCN4226W 42" Rear Projection...
Green shadow
it is due to degaussing circuit. it has developed due to changing the side or turning tv or any thing is lying near tv which has got magnetic effect. solution 1 put of tv for 15 minutes 2 do not change direction while watching tv . 3 remove magnetic thing like speaker if is near tv. still if you donot get the result call degauss it with degaussing coil. it is 2 minutes job. good luck.
Sep 24, 2007 | JVC AV-32750 32" TV
Yes you must go to menu and set the convergenge. It is easy. If it doesnt tune in or set to be ok you must get somebody to set convertions manualy thru service menu.
Hope it help
Aug 10, 2007 | Samsung HCN436W 43" Rear Projection...
Samsung HCN436W 43" Rear Projection Television Logo
137 people viewed this question
Jerry Greenberg
Jerry Greenberg
