Question about Logitech MX510 Performance Optical Mouse Red - Special Edition - limited series (9711790914)
I dropped my mouse. Now it's track wheel is jammed. How to I pop the mouse open to reseat the track wheel?
    Sergeant:
  • 195 Answers
Open the screw at the bottom of the mouse, set the wheel accordignly.
Posted on Oct 06, 2009
How do you delete books from your kindle?
To permanently delete books from the Kindle Cloud and your Amazon Kindle Library:
  1. On your computer, open Amazon.com in a web browser and log in to your account.
  2. Hover your mouse over Account & Lists at the top. This will show a drop down menu.
  3. From that menu, select Manage Your Content and Devices.
Jul 02, 2017 | Tablets & eReaders
Problems showing reply drop down box on Craigslist.
Do you have pop ups disabled? You get a box you have to check to say you are not a robot.
Jan 28, 2016 | Amazon Kindle Fire HD
How do I enlarge my face book page ?
If you have a mouse with a scroll wheel, hold the Ctrl button down on you keyboard and use the mouse's scroll wheel to increase or decrease the screen zoom. Another way is to use the web browser's zoom function normally located under Tools in the main menu.
Apr 03, 2015 | Tablets & eReaders
Nexus 7 screen broken and back slightly popped
It sounds like the device is completely broken after dropping it. You may find a local repair shop or a shop online to fix the device, but it may be cheaper to replace it with a new one.
Hope that helps!
Feb 24, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
How to perform actions on a tablet without a mouse
Click on windows explorer and find the file you want to move, once it is on the right hand side of the screen you can move the curser over the file name and hold down the left mouse button and move the mouse over to the file in the RIGHT side of the screen to the folder you want to drop the first file into and don't let go of the left mouse button untill you get to the file and wahh lahh!
Jan 08, 2013 | Samsung Tablets & eReaders
I have a Lenovo x60 Tablet Computer and when the computer screen moves the mouse starts stuttering and the t messes up when typing.. also a blue screen comes up sometimes.
sounds like a loose lcd connector, or pinched cable.
the lcd connector is under the keyboard. remove the panel that has the power button on it, it should just pop off from one side to the other. the remove the 2 to 3 screws located at topof keyboard, plus remove 2 to 3 screws under laptop located in holesmarked with a big K maybe even circled. with keyboard out of way you will see the lcd cable connector, it should have a "paperclip" handle, pull it up then reseat the connector, reassemble and test.
Aug 12, 2010 | IBM ThinkPad X60 Tablet PC
The stylus for my gateway m280e is unresponsive, it is able to track the cursor across the screen but it can not select anything when double tapped, or write in one note? What could be the issue?
You can change the way the cursor functions. Here is how. From the "Start Menu", select Control Panel in the (right pane), next select Hardware and Sound, select, the "Mouse". In the Mouse, "Properties" (window) change mouse functions. "I hope this "Fix it"
Jan 24, 2010 | Gateway M280E
My pen for my computer won't work
I think the pen has gone bad on you, since your screen can still detect your hand and the track pad. I would think the pen is faulty. Try another pen cause I think your original is bad, if it was the touch feature that wasn't working I would say its a driver problem but that feature still works with the exception of the pen. Get another pen.
May 31, 2009 | Dell Latitude XT Laptop Computer Tablet...
HP tablet PC tc4200 latch fixable?
In a pinch, you can pop the lid open on these by sliding a credit card between the screen and base chassis. Typically when the latch breaks on a tc4200/4400 it will need to be replaced unless it is simply jammed.
Aug 05, 2008 | Compaq tc4200 Tablet PC
Thinkpad does not respond - bizzare!
Hi, Based on your post/description that it was not the laptop that was dropped and that all the connections are snugly fitted to where they should be, the dropping of the moused caused the laptop to be dead, then it is likely that the +5VDC of the mouse cable has shorted to the ground wire. The short is reflected towards inside the motherboard of your laptop. This +5VDC is common to all the USB ports, PS2 ports, and many other parts of the laptop. The short would open up a fuse somewhere inside. I can only surmise that the power supply is involved. You may need to check that the powersupply/AC adaptor (if present) is giving juice to your laptop with the use of a VOM, since as I understand it, simply plugging in your laptop to the mains would lit an indicator that ACpower is available. Normally a surface mounted fuse is on the motherboard right after the jack where the AC adaptor plug comes in and right before a reverse protection diode. If you are uncomfortable opening your unit and would not be in a position to do component level repair, you are probably better off seeking the services of a qualified service professional. Hope this give you and idea. Good luck and kind regards.
Aug 20, 2007 | IBM ThinkPad X41 Tablet PC
Logitech MX510 Performance Optical Mouse Red - Special Edition - limited series (9711790914) Logo
99 people viewed this question
Top Logitech Tablets & eReaders Experts
Are you a Logitech Tablet and eReader Expert? Answer questions, earn points and help others
