Question about Yamaha SW218V Speaker
I have a yamaha SW218v speaker cabinet. while playing it one night, they completely shut off. are the drivers blown or could there maybe be an overload inside that can be reset?
3 Suggested Answers
  • 4234 Answers
SOURCE: MACKIE SRM 450 IT IS FAR TOO BASSIE,IT SOUND
Contact mackie directly. They sell replacement drivers for these units.
Dan
Posted on Sep 05, 2009
PaulDF
  • 31 Answers
SOURCE: Removal of speaker from cabinet Yamaha SW118
Often there is a gasket seal at the speaker/cabinet interface to keep any air leaks from happening. That seal can get pretty stubborn after time, or perhaps it was glued in with some type of glue. I'd be real careful with the "claw hammer" technique, you will likely honk up the cabinet, the speaker, or both. Use a razor knife carefully around the edge of the speaker and cabinet. If that will go into the crack, work your way around until you've freed up the speaker. Good luck and be careful!
Posted on Apr 08, 2010
A replacement tweeter for Yamaha S215V speaker
I generally get replacements from Simply Speakers. Their site is-Replacement by Simply... Genuine Eminence Parts New
You can also just replace the diaphragm. The procedure is on YouTube here-
Speaker Repair Yamaha Eminence Horn Driver Diaphragm Replacement by Simply... Genuine Eminence Parts New
Be sure you check what impedence you need. If you look at the lable on the driver it will normally say, but if not ask them about your specific cabinet. For instance the 8 ohm single 15" Yamaha Club Series 4 uses a 16 ohm driver in their 8 ohm box.
Feb 17, 2015 | Yamaha S215V Main / Stereo Speaker
Where can I find a tweeter for Yamaha S215V speaker? Thanks
I generally get replacements from Simply Speakers. Their site is linked below.
You can also just replace the diaphragm. The procedure is on YouTube linked below.
Be sure you check what impedence you need. If you look at the lable on the driver it will normally say, but if not ask them about your specific cabinet. For instance the 8 ohm single 15" Yamaha Club Series 4 uses a 16 ohm driver in their 8 ohm box. Genuine Eminence Parts New Speaker Repair Yamaha Eminence Horn Driver Diaphragm Replacement by Simply...
I was playing my Yamaha RX-V995 last night and it got really hot and subsequently shut off. Now, when I press the Power/Standby button, it turns on for a second. And then turns off again. Is this an easy...
Well - you may have. BUT try this. Turn the volume all the way down, disconnect the speakers, and power it up. If it comes up OK, you've got a fried speaker (or bad wiring). If not - yep, you fried it.
Oct 23, 2010 | Yamaha RX-V995 Receiver
My Yamaha SW118 keeps cutting out (volume reduces to v low level) even when driven by 500W amp. Doesn't seem to be the amp but not sure if the speaker has it's own internal protection. Can anyone advise?
Poly Switch
All full-range loudspeakers are fitted with a self-resetting
poly switch that protects the high-frequency driver from
damage caused by excessive power.
If a loudspeaker cabinet loses high-frequency output, immediately
remove power from the unit and wait for two to three
minutes. They should allow the poly switch to reset. Reapply
power and check the performance of the high-frequency
driver before continuing with the power reduced to a
level that does not cause the poly switch to interrupt the signal.
On the SW115V/SW118V/SW218V sub woofer, the Poly
Switch protects the woofer and a similar routine should be
followed if its output is lost.
Aug 29, 2010 | Yamaha SW118-IV 18" Subwoofer Speaker
Can you tell me how to conect my yamaha espeaker sw218v,do i need two.1200.wat amps.one for each one ordo i need a 1400,wat amp in order to have them work perfect or close to perfect!!thankyou...
Power handling CAPACITY is not to be confused with power requirements. What they're getting at in the box "To protect your speakers" on Page 3 in the manual ...
When choosing a power amplifier to use with your speakers,
make sure that its power output matches the speakers’ power
capacity (refer to the Specifications on page 6). Even if the
amplifier’s power output is lower than the speakers’ PGM
(program) power capacity, the speakers may be damaged
when clipping of a high input signal occurs."
...is that any amplifier driven beyond it's non-distorting power limit will damage any speaker system, not with its raw power but with the artifacts of distortion (clipping). So they recommend amps spec'd at those high ratings in an attempt to keep them from distorting due to overdrive.
In practice, if you're cranking an amp to the stops you're either overdriving it or you're performing a concert and wishing you could crank it to '11'.
Being nominally 4-ohms, a pair of these speakers would likely have to be run in series or else their effective impedance may drop dangerously low. Two amps may be better for you, one amp per subwoofer.
If you need the manual, register with retrevo.com and download it free using "Yamaha SW218v" as the search.
Feb 05, 2010 | Yamaha SW218V Speaker
Only voice from tweeter is coming, nothing from the mid-range and woofers. on cerwin vega v10f
bhurajiv,
Well it's a good thing that you are getting sound from the tweeter from the speaker cabinet with the problem, that eliminates one of the possible problems; your wires are connected!
If your other speaker sounds fine, the first thing to try is to swap your speaker wires with the one that sounds fine. If the problem speaker cabinet still only produces sound from the tweeter, the problem is within the speaker. If the problem goes away, the problem is from your electronics.
If the problem is within your speaker and it is still under warranty, find a authorized repair location (http://www.cerwinvega.com/service_center.php).
Problems within the speaker can only be one or more of the following: 1) The drivers not producing sound have been blown; played with either too much power and/or distortion. Distortion is created when you play your music too loud with a amp not able to reproduce what you are looking for in sound, the speaker itself can hear it before you can.
2) The speaker cabinet has a crossover inside which directs the proper sounds to the proper driver. This crossover can have components that have been broken be either #1 or from exsessive vibration.
3) There are wires inside of the speaker cabinet that have been disconnected. This can happen over time or if someone reaches inside of the cabinet through the port and pulls on the wires; like a young child or pet such as cats.
If the drivers in question just one day stopped producing sound, start with the easiest solution, #3 then #1 if you can suspect anyone could have played your speakers other than you.
To diagnose the problem, you first start by removing the woofer and confirm that all of the wires are connected and in good condition. While the woofer is removed, to eliminate that there is a problem with the speakers, temporarily connect the mid-range and woofer, one at a time, directly to the wire coming from your electontics, if they produce sound the problem is within the crossover network, if they do not produce sound, the problem is with the driver itself. Replacement parts should only be purchased directly from Cerwin Vega directly (http://www.cerwinvega.com/contact_us.php)
-Chris
Jan 25, 2010 | Cerwin Vega Cerwin-Vega V-10F Floor...
I have yamaha v863 receiver. when i play movies on dvd. Any times
Check to make sure no wires are touching at the reciever. Next step is process of eleminaton. Unhook each speaker until it works or if you have a meter you could always check to see if you have a blown speaker or shorted wire. I would first disconnect all speakers and check to see if unit does it with no speakers connected.
Jul 06, 2009 | Yamaha RX-V863 Receiver
Wiring diagram
Blue should be positive
Aug 05, 2008 | Yamaha Music
Auto Shut Off After 3 Seconds...?
either your DSP output stage already damaged or maybe your speakers. have it both chekced for short. or worst both of them. DSP A1000 can drive as low a 4ohms on main channels but how is the power handling of your speakers? are you sure it has not exceeded the capacity of the speakers? or maybe you have over driven the speakers and they are still ok but your amp gut busted due to over drive. If the DSP amp is busted then it is due for replacement of power transistors and drivers. you can not disable the protection circuit. at least the design. it can be disabled by a tech person with a lot of modifications but i wont go for that or it can cause more damage to your equipments. i am from yamaha before and i have made conversions of protection circuits but it is too risky.
Jun 13, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
Knocking sound out of right side of yamaha sub
The speaker on the non-playing side is blown. Disconnect it or the amp will get fried as well. The coil has loosened from its form and is rattling against the speaker frame. If the insullation on the coil wires gets worn enough,it will short against the frame and possibly smoke that amp channel.
Dan
Mar 19, 2008 | Yamaha SW218V Speaker
Yamaha SW218V Speaker Logo
71 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
