Question about Philips Televison & Video
Philips 51PP9303H17 lsb board, hi I need the part number of that board to purchase a new one.
  • 115 Answers
313503710991
Posted on Oct 06, 2009
What does an ssm board for a philips 51pp9303h17
The ssm is very exspensive at least 250-350 but it sounds like you only need the convergence repair kit. You can get the DPTV305-DPTV345 convergence repair kit from www.tvrepairworld.com which also contains the Cd with instructions.
Jan 13, 2010 | Philips 51PP9303H Rear Projection...
Philips Projection 60PP90200D/37 NO PIC NO SND 6X/1QF
I had the same problem. It is error code 61 which is a power supply fault. Had a bad LSB board (pn: 313926719011 from MCM Electronics) which blew out on of my CRT. If you have any observed arcing in your CRT's, they are bad and will need to be replaced. I went to Ebay and found a used compatible Philips brand to replaced the CRT. Do not isolate the high voltage lines of the bad CRT to troubleshoot with a bad LSB. The LSB will short out another CRT (it did on mine). I bought the service manual an learned the set does not tolerant of power line surges. If you fix it, invest is a good surge protector.
Aug 27, 2009 | Philips 60PP9200D Television
Comes in small and green, fills out after warm-up
The lasge signal board or "LSB" is going out. The problem comes from the power regulator not operating properly. The circuit board is no longer available as a new part, but tou can purchase a refubished one or send yours in to have it refurbished. Contact PTS corp at 1 800844 7871 and have your FULL model number. There are additional digits beyond the model number you have listed here.
Jun 03, 2009 | Philips 9P5040C TV
Magnavox Philips 60" 9p6031 c103
deflection problem very common on that model. You can get a new LSB board at the following link, leave them a email and they will respond quickly with a price quote for the LSB if they dont have it listed already, they are cheaper than anywhere else for replacement boards for phillips, RCA and GE. Heres the link.
http://servicemanuals.vstore.ca/
Jan 24, 2009 | Philips Magnavox 9P6034C 60" Rear...
Philip magnavox model # 9p6440c105
you most likely need a LSB board. If you go to the following link and leave them a email with your model number and the symptoms they will confirm which board you need , They have some good sales on Circuit boards for the remainder of the month.
Heres the link.
Jan 14, 2009 | Philips Magnavox 9P6034C 60" Rear...
Philips Projection HDTV 51pp9303h/17
Number is on your STKs in TV Two big black ICs STK392-110s 150s, use 180s For Parts Electronix 1-800-223-3205 As for sound replace microboard has #P on it.
Jan 01, 2009 | Philips 55PW9363 55" Rear Projection...
I have a 60 '' philips tv model # 60pp9363/h17
I have worked on dozens of the DPTVXXX models recently all with audio but no video. In every set the HVG was the problem.
If you are not sure how to find/repair/replace the HVG youself goto http://www.TvRepairKits.com to get their how to guide.
 Its an easy do-it-yourself fix.
Also, if you call in a repair tech - they will almost certainly want to sell you a new LSB board for $500.00+. The LSB board is where the HVG is located. Average cost for a replacement HVG is around 140.00 from vancebaldwin, partstore, etc.
Nov 18, 2008 | Philips 60PP9363 60" Rear Projection...
My 60" philips tv
sounds like the LSB board, which is a common fault with your model. You can get a new DPTV 300 series LSB at the following link.
Sep 27, 2008 | Philips 60PP9202 60" Rear Projection...
Philips 50P8341 50 in
Board location 7550 on the LSB ( Large board on the right) Its a TDA4861 its not like the convergence IC its mounted to a black aluminum heat sink with a metal spring clip
Aug 21, 2008 | Philips 50P8341 50" Rear Projection...
Tv fix
that is usually related to the LSB large signal board will eventually need replacement. Most repair shops will not troubleshoot the LSB at component level, they will opt for replacing the entire circuit board. If you need more info or help to locate a LSB board. please let me know.
Jul 14, 2008 | Philips 60P8341 60" Rear Projection...
Televison & Video Logo
49 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
