Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Flames will not start even though igniter glows
Weathermaker 8000 model number 58WAV075. cycle starts up fine. first the bottom blower then the top and then the igniter but now flames will start
  • 34 Answers
I am not very familiar with this particular model but something must tell the gas valve to open.there must be a thermocouple or optical scanner that creates a signal to open the gas valve. if there is a signal to the gas valve then the gaas valve will need to be replaced
Posted on Oct 10, 2009
Model number 3627361192 oven wont work but broiler does the oven starts but then flame goes out
replace the igniter. Even though you see it glowing, it's failing.
Jul 17, 2014 | Kenmore Ovens
My York furnace sometimes doesn't completely ignite
A noisy inducer probably is headed for replacement.
The igniter can produce a healthy glow and still be defective. Mine had to be replaced with a new, improved one.
The thermocouple could be defective even though it seems to open the gas valve when it should.
The heat sensor in the bonnet could be defective. That controls main blower operation.
The heat exchanger could be cracked.
Jan 10, 2014 | Heating & Cooling
Weathermaker 8000 not enough heat
Are the tips of the flame blue? You might need to adjust the air mixture sleeve on the burner.
Feb 05, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
I have a weathermaker 8000 model 58TUA and it wont heat I replaced the hot surface ignitor because it wasnt glowing but the new one isnt either. The blower seems to be working I have no fire
Check your pressure switch after inducer starts jump wires to pressure switch if igniter comes on you may have ablocked vent or bad switch
Nov 05, 2012 | Heating & Cooling
Carrier weathermaker 8000 cycle problems
When the furnace fires and then 1 second later the flame quits, that's your flame sensor/flame rod. Its the lil metal rod at the burner section, that the flame passes across/comes in contact with. Has 1 wire connected to it. Clean it gently with a pc of sand paper, but don't make it shine, just a light cleanind will do. Here is a link that has answered the trouble codes.
http://www.fixya.com/support/t6287232-carrier_8000ts
Mar 06, 2017 | Heating & Cooling
My gas dryer starts fine than the flame goes out
replace the coils. i promise you. and here is a guide to most gas dryer problems that even a kid can see.
starts fine, cycles off, igniter comes on, hear a click, and no flame.-coils.
(can also be intermintent)
igniter stays on, no flame.-flame sensor
no glow from igniter.-igniter
remember, always allow about one minute for ignition.
Oct 06, 2009 | Frigidaire GLGR331A Gas Dryer
Carrier Weathermaker gas 8000 will not ignite
Your hot surface igniter may be bad. It may be cracked which would prevent it from starting the burner flame.
May 21, 2008 | Heating & Cooling
Carrier furnace weathermaker 8000
. Several times of recyling power normally brings the furnance up. Though the failure code has always been 31, there are several different behaviour when the blower starts after reset :
a. blower simply creases.
b. there is an attempt to start the heating unit (I hear the high pitch noises), then everything stops.
c. there is an attempt to start the heating unit (I hear the high pitch noises), once I see the orange glow from the coil, normally the gas is lit up and the unit starts working.
Nov 23, 2007 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
185 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
