Question about JVC Televison & Video
How do i change my tv to channel 3? It is skipping this channel and goes from 2 to 4?
    President:
  • 2,049 Answers
Instead of pushing the channel up or down button, manually input either 3 or 03 or 003 to get to ch. 3.
Posted on Oct 06, 2009
I have a Symphonic model ST420FF along with a Phillips Universal remote. The tv used to work oerfectly but then the channel changed (we have a charter cable box hooked up). Now when I try to change the...
Can you use the menu buttons on the TV to navigate to the control panel to automatically or manually add channels? That would be a start to make channel 3 exist again.
Sep 20, 2014 | Televison & Video
We have no remote. Is there a way that I can get my tv to stop on channel 3? It just goes from channel 2 to channel 4 and does not allow 3 to come on -- skips right over it . I just need to use it for a...
it simply means that channel3 has been set to skip/go to the tuning menu and select manual search.select channel position3 and cancel channel skip function.
Oct 05, 2013 | JVC AV-32F703 32" TV
Getting a specific channel on the TV without using a remote
Usually if you go into the setup menu, there is an option to allow you to either "scan" for a channel, or "input" a channel. In this case, select "input" and see if the TV will allow you to press the up and down channel buttons and go to a specific channel. If so, when you get to channel 4, press the "add this channel" option (or whatever the menu option says) and you should then be able to go to channel 4 using the buttons on the front without skipping over it.
Jan 24, 2010 | Televison & Video
I do not have a remote control for my Symphonic tv and I am trying to put the tv on channel 3 or 4 but I can't. It goes from channel 2 to 8. Please help.
Below are some places where you can purchase a symphonic remote control. But if you don't fancy buying one why not tune channel 8 and upwards to the station's that your are after and just forget about the 3,4,5,6,7. My quess is that the tv system is set to skip these channels. If you go to Menu > tv settings, check out the channels that you are skipping, it should be in the installation part of the tv setting's menu. Make sure that where it say's SKIP > OFF on all of the missing channel's.
Hope this is of some help. Bit long winded but hey! :-)
Hughie.
www.remotecontrolscenter.com/symphonic/ -
www.tootoomart.com/buy-symphonic+remote+control/ -
Jun 17, 2009 | Televison & Video
I need to manually turn the TV to ch 3 and cannot because it skips it from 4 to 2.
Enter "3" or "03" on the remote and press OK/Enter.  If the channel-skip feature is set on for Channel 3 you cannot get to it using the up/down buttons.  Go to the setup menu to disable the channel-skip for Channel 3 if you want to tune it with up/down buttons.  If you have no remote you should be able to access the menu from buttons on the front of the TV. (They may be inside a door or panel.)
May 20, 2009 | Televison & Video
Cant turn the tv to channel 3
Go to the Menu setting, and do a auto channel scan, it will automatically program it to NOT skip 3.
Nov 25, 2008 | RCA Universal Remote 3 Device Remote...
#4 & #5 buttons do not work on my remote. Channel 55 wont come in either on my tv
I had that problem 2 my channels disapeared one by one and some will skip yes...
I always use on my remote controll :
1 menu
2 Ch tuning
3 auto
and then wait untill it has found all the channels
Oct 02, 2008 | Orion1934 19" TV
Program channels
TV SETTING
1. Press the MENU button.
2. Use or button to select the TV setting menu, then press or button.
3. Use or button to select the Channel no. setting and use the or button
to change from AIR (over-the-air broadcasts) to CABLE (cable/satellite broadcasts).
4. Use or button to select the Tuning mode and use the or button.
5. Use or button to select the Auto tune and press or button to
confirm the selection. The unit will immediately search through all possible TV
channels and store those channels with signals in memory. After this is complete,
the unit will switch to the first channel found.
6. To exit the MAIN MENU and return to the normal screen, press the EXIT button.
Note : In DVD mode, this option is not available.
Remarks:
1. Channel no. : 2-69 channel for Air mode, 1-125 channel for Cable mode.
2. Tuning mode : Air or Cable mode are available.
3. Auto tune : Searches for usable stations and stores them in memory.
4. Skip : ON - Skip weak channels. OFF - No channel skip.
5. Fine tune : The frequency changes to allow fine tuning.
6. AFC : Auto frequency control.
7. MTS : Select the Mono sound/Stereo sound/Secondary Audio Program (SAP).
21
TV SETUP
MTS (Multi-channel Television Sound) SETTING
This feature allows reception of sound other than the main audio for the program.
3. Use or button to select MTS menu, and press or button to select the
options (Mono, Stereo, SAP)
4. To exit the MAIN MENU and return to the normal screen, press the EXIT button
on remote control.
Note:
• MTS only operates while in TV mode.
• The SAP (Secondary Audio Programs) feature allows a TV station to broadcast
other information, which could be audio in another language.
RESTORE SETTING
If you reset the TV to the factory settings, all your present settings on picture &
sound will be erased and replaced by the factory’s default settings. However, picture
setting in PC mode and parental setting will not be erased.
Jul 15, 2008 | TruTech PLV1615T 15 in. LCD Television
Magnavox with pic tube tv skips over channel 3..goes from 2 to 4
You are right about the auto-programming, but Magnavox no longer has the original remote.
For my answer to be right, you must have posted this question to the EXACT CORRECT model # of your Magnavox TV - 27ms343s:
Press TV on your Verizon remote, and then press "0" and "3"
If that fails:
Press MENU to see the TV’s on-screen
menu. In the menu, use VOL.+/_ and
CH.+/_ to make adjustments or selections.
You can press MENU on either the
remote control or the front of the TV to
access or remove the menu.
Jun 14, 2008 | Philips Magnavox 27MS343S 27" TV
Remote control codes
how do activate sharp tv to a comcast remote to change the regular channel on he tv im trying to turn to channel 3 but when i turn from the tv it skip from 2 to 5 then so on.
Feb 19, 2008 | Televison & Video
Televison & Video Logo
130 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
