Question about Denon S-102 Theater System
Denon s-102 wont load cds... dvds are no problem. Any one know why? Its under 2 years old and like new. When I load a CD the interface shows LOADING but rarely gets past this stage.. Maybe 1 in 10 attempts works
  • Matchap01 Aug 08, 2010
    Hi there!
    Got the same issue here, just started yesterday. I wonder whether you found out any obvious thing to do to solve that or if you know anymore on the subject?
    Any input will be welcome, as I think mine is not under warranty anymore :(
    Cheers
    Matt
  • 3 Answers
SOURCE: Player does not recognize or play CDs
Thats how some manufacturers sell there replacement parts as they come into the country assembled. it cost let to import but more for us. i once needed a spindle motor for a unit, no replacement except the manufacturer part. Had to buy entire laser assy and thats what they bare selling you too. If you already tryed to manualy clean the lens, look on the side of the laser pick-up. it might be made by sony or a popular manufacturer go by the number printed on the label on the side or bottom of the laser assy unit itself. Good Luck
Posted on Aug 17, 2006
mjap
  • 107 Answers
SOURCE: denon df101 cd player problem
can't read now? with any cd's? if that happens try to adjust the trimpot/variable resistor beside the optical lens(its still part of optical lens) I just dont know if it turns clockwise or counterclockwise, well turn it on the other side then turn again to the other side. little by little. then if it still not working, you need to change your optical lens though.
you can do this if you are a pro..
note:
stay away at the power supply, never touch any part.
hope I helped you..^^
Posted on Feb 02, 2008
  • 395 Answers
SOURCE: Denon DHT-500SD - DVDs wont load
the problem may be two fold
1 the optical pickup assembly's lens may be dirty and needs to be cleaned (donot use any liquid to clean the lens just a soft cotton swab will do)
2 the optical pickup assembly has failed and can no longer read discs (if the laser or sensors inside the optic fail it is "blind" and can not "see" the disc)
start with the cleaning.
Posted on May 26, 2008
  • 3 Answers
SOURCE: Dvd doesnt play but cds do
Hi
The problem might be due to hardened greasing. Did You replace the drive or only the laser? The mechanism is named VED-0378, which is also the name of the laser. It is a Panasonic/matsushita thing. Try to google the name and find a dealer near your area, if you can't find it this polish electronic pusher is able to deliver both laser or mechanism: www.impelshop.com
Best regards and good luck! The Denon thing is worth a try.
Niels Peter from Denmark
Posted on Jun 15, 2008
SOURCE: Denon 3910 won't load some dvds/cds and vibrates while trying.."disc error"!
I have the Denon 2900 (about 4 years of use) and until recently, suffered from the same (growing) problem. CD's were very difficult to start/read. I recently found advice which I tried and was succesful with. It was manually cleaning the laserlens. I took away the outer housing by unscrewing all off the on top (6), side (4) and the back (2) bolts. After that I took out the top plate of the laserunit which took two very little screws taking out. Now you are looking at the cd-tray with the lens. Take a very soft and clean cloth and moisten it a little bit with clean water (be very carefull with the moistening, don't allow any waterdrop to come out of the cloth into the laserlens while cleaning! Carefully clean the lens and dry it with a dry part of the same cloth. Replace the top plate and the outer housing and the player will recognize the discs like it's new again. Good luck! Robert Jan, The Hague the Netherlands
Posted on Jun 25, 2008
DVD CD player will not work. Door will not open to play DVDs or CDs or MP3 player
Disc loading mechanism fault. A broken loading belt or a gear wheel can cause this. Contact any service technician. The loading mechanism have to taken our from the device, for repair. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Jan 19, 2016 | RCA RTD209 System
Denon 700 wont accept cds
The CD loading mechanism has the fault. Check its loading belt. If it is OK, replace the loading mechanism.
Jun 03, 2012 | Audio Players & Recorders
We can't get the factory 6 disc cd player to load more than 1 disc. What is the sequence for loading additional discs?
The following is the owner's manual for your 2004 Dodge Neon:
http://www.dodge.com/en/owners/manuals/index.html?year=2004&nameplate=Neon
P.99 describes how to load discs:
1. Select and press any numbered button without an illuminated light above it.
2. Insert the CD while the light above the chosen button is flashing and the two lights on either side of the slot are illuminated.
3. Upon insertion, the CD will begin to play, and both the button light and the lights in the corner of the loading slot will illuminate.
4. Repeat the process for loading any additional CDs. The CD playe rwill stop while additional CDs are loaded.
Playing Discs
The radio will show the CD number, the CD track number, and the Track Time Elapsed while the radio is in the CD mode. IF more than one CD is loaded in the changer, the changer will automatically play the next disc after playing the last track of the current disc.
Wow, that's a lot of typing.
I didn't know the 2004 Dodge Neon had such a nice changer.
Good luck.
Jul 04, 2010 | 2004 Dodge Neon
Ps3 will only play dvds and cds
Your laser is bad and must be replaced. They are real expensive since the chinese new years. Email me and I can give you detailed instructions to change it.
Mar 22, 2009 | Sony Playstation 3 (PS3) Console
Philips HTS6510 dvd player useless ..
This is because you DVD player's lense got too old. Try to clean that with a good Lense Cleaner. If the problem persists, change the Lense for the same.
Feb 04, 2008 | Audio Players & Recorders
Dec 25, 2007 | Denon DVD-3910 DVD Player
Neither dvds or cds are loading,
How to or can't boot from a CD or DVD. If the computer is loading to an error message when attempting to boot to ... Not all CDs and DVDs are bootable; in order to boot from a CD .
Read and follow instructions, Good Luck please dont for get to Vote/Thank You.
Dec 22, 2007 | HP Compaq Evo n610c Notebook
Cd or dvd
DVD'S - are for down loading movies to the DVD'S
CD'S - Are for down loading music files and pictures to
Yes buy cd's for music.
Nov 27, 2007 | Lands Phones
Denon S-102 Theater System Logo
432 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
