Question about Belkin Dual-Band Wireless A+G Desktop Network Card (F6D3000)
Very short range
Using the belkin dual band wireless a+g destop network card in the master bedroom for media pc and it has difficulty receiving a signal from the Verizon Router in the next room. Is this typical? Is there a way to extend the range?
    Sergeant:
  • 233 Answers
No this is not typical if the Network card and router are just one room away. However electrical interference and walls do impede the signal.
Try moving the Router around to see if the signal improves.
You can also adjust the antenna and pointing it in the direction of the Router.
1. Position your wireless router (or wireless access point) in a central location.
2. Move the router off the floor and away from walls and metal objects. (Such as Metal file cabinets)
3. Replace your router's antenna.
Antennas supplied with your router are designed to be omni-directional, meaning they broadcast in all directions around the router. Upgrade to a hi-gain antenna that focuses the wireless signals only one direction. You can aim the signal in the direction you need most.
4. You can add wireless repeaters. (just the room next door this would be a last resort if all else fails)
5. Change your wireless channel. You may find one that will transmit a stronger signal.
6. Reduce wireless interference
If you have cordless phones or other wireless electronics in your home, your computer might not be able to "hear" your router over the noise from the other devices.. To quite the noise, avoid wireless electronics that use the 2.4 GHz frequency. Instead, look for cordless phones that use the 5.8 Ghz or 900 MHz frequencies.
7. Update your firmware or your network adapter driver
Source:
http://www.microsoft.com/athome/setup/wirelesstips.aspx
Nice diagrams on this web page too.
(Couple items left off as these did not seem to fit your current situation)
Posted on Oct 06, 2009
Using my mobile phone won't accept my password
Prolly because out the box that router uses AES encryption. You can drop it down to say 64bit from the AES 256bit and most cell phones B network cards will understand 64bit. You will need to basically change the routers security and youtube has a ton videos show you how.
Oct 19, 2014 | Belkin N600 DB Wireless Dual Band N Router
I have a 2wire and a wireless router Belkin34e. I cannot get the preception I need to watch my movienite streaming media player. I have a tv upstairs and downstairs and the preception is poor for bothl.
The best is to use an Ethernet cable.But if you cant wire up you will need that one of your device be downstairs.In order to do it you need to configure one of them as an access point bridging one router to the other.Or get a Wireless Extender that is a hardware devices that act as either bridges, allowing you to connect a wired device to a Wi-Fi network without need for additional cabling or networking configuring, or they act as repeaters, extending a wireless signal beyond the normal bounds of range.
Apr 11, 2013 | Belkin Components Belkin N450 DB Wireless...
How do I get wireless internet from router to another desktop?
You will either have to put a wireless card into your desk top or you will have to run CAT 5 wire from the router to the device.
Mar 18, 2012 | NetGear WNDR3400 N600 Wireless Dual Band...
I need a driver to my desktop card
http://www.wardrive.net/drivers/belkin just look for this site
Jul 31, 2011 | Belkin Dual-Band Wireless A+G Desktop...
Hey, I have a Belkin Dual-Band Wireless A+G Desktop Network Card, but I can't find the correct driver to download. I tried the f63000 but it still is not recognizing the Internet source...any ideas?
You tried this one?
http://www.belkin.com/support/article/?lid=en&pid=F6D3000&aid=6033&scid=223
How about this one?
http://en-us-support.belkin.com/app/answers/detail/a_id/499/kw/f6d3000
I did notice that there is no specified support for 64-bit versions of ANY OS,
and doesn't specify compatibility with any version of Vista or 7.
Try uninstalling any software and drivers you tried so far, then also remove the entry from Device Manager... THEN install one of the above drivers.
May 05, 2011 | Belkin Dual-Band Wireless A+G Desktop...
Since I purchased a Belkin N600 my download speed is about 30k/bps. My ISP says it's the N600. Help!!!
If you are wirelessly connecting you need to use a wireless card that supports dual band.
and then changnig the settings on the wireless card helps.
if you are wired the issue is with the router settings.
Upgrade the firmware on the router
see belkins website on how to do this:
http://en-us-support.belkin.com/app/answers/detail/a_id/4497
Apr 07, 2011 | Belkin Play N600 Wireless Dual Band Router...
No Signal Strength
You said that your wireless works fine with other computers. So i think the router must be working fine.
you can try to uninstall and reinstall the adapter.
Or upgrade the drivers of the adapter that will help you.
Click here for more info about the networking
Oct 07, 2009 | Belkin Dual-Band Wireless A+G Desktop...
Belkin mimo G network card
I think in your Pc Wireless lancard is disable,Pls enable the wireless lancard,
1. just check the lan card is enbled
example:my network place --right click---properties---wireless lan card,
2. check the R u getting ip address,
example: start---run---cmd----ipconfig
May 20, 2008 | Belkin Dual-Band Wireless A+G Desktop...
Belkin Dual-Band Wireless A+G Desktop Network Card (F6D3000) Logo
93 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
