Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
I have the exact same problem on my 7hp briggs for a genny
It will only run fully choked- i was told it was running to rich not, sure how to adjust for it, no matter what i do with the two screws it kills it.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 18 Answers
Your carburetor is dirty. Need to be take apart and cleaned with carburetor cleaner.
Posted on Jan 18, 2010
Briggs and Stratton engine runs rough but good with low gas
YOU ARE CORRECT. sounds like a simple carb. adjustment, probably too rich of a fuel mixture.
Apr 06, 2013 | Measuring Tools & Sensors
Briggs & stratton running rich
Check if the air cleaner is dirty, also check if the choke works freely.
May 31, 2012 | Cars & Trucks
Lt1050 black smoke after 15 minutes
The black smoke and black spark plugs indicate that the engine is running very rich (ie too much fuel). This could be caused by the choke not opening fully after the engine starts and the fuel mixture is too rich OR the fuel mixture setting is opened too far.
Check the choke lever, make sure the choke is fully open when the choke is in the running position.
When the engine is running with the throttle is in the 3/4 rev position then adjust the fuel mixture to get the highest RPM.
Apr 19, 2012 | Cub Cadet Garden
Started engine prior to hurricane season . It seems to run good only in choke , adjust toward run and it quits!! thanks
If it only ran good with choke then that means the engine is running too lean and not getting enough fuel. You need to remove, fully disassemble, and thoroughly clean the carb. Or you could also just install a brand new carb if you don't have experience working on carburetors.
Jul 17, 2011 | Briggs Stratton IC Horizontal OHV Engine ...
I have a 5.5 OHV Briggs & Stratton and it only runs good when it almost fully choked or half choked. There is one adjustment screw on the carb., but when I adjust it , it does not seem to run any...
The carburetor needs to be cleaned. There is something in one of the passages that is keeping it from running correctly. To do this you will need a can of carburetor cleaner (spray) and a very thin wire to probe in all of the holes of the carburetor. First, take the carburetor loose from where it mounts to the engine. Then take the wire and probe all of the holes in the carburetor, and also the holes in the fuel bowl nut (if any are present). Then shoot the carburetor cleaner through the holes to remove any loose particles of dirt or debris and to make sure the passages are clear. After you have done this, then you will need to blow through the holes to make absolutely sure that everything is removed that could be blocking either fuel or air from passing through the carburetor. Re-install the carburetor back onto the engine, and check to see if the unit is running ok. If at this point the carburetor is still not running correctly, you may have to replace the carburetor. When you go to the parts counter you should have the MODEL, TYPE, and CODE off of the flywheel housing. These numbers are stamped into the metal. I hope this helps you out.
Apr 06, 2011 | Briggs & Stratton Briggs Stratton...
I have a 22 hp bs crafstman riding mower and it would fire off starting fluid but would not on its own. I took carb off and cleaned out and got it running but only on choke. It's a v twin and on one side...
running rich will make it run colder.....I wouldn't run it anymore til you find theproblem, it will burn your valves. air leak in your intake/carb is more than likely your problem , check for cracks in the intake manifold , leaking gaskets
Feb 23, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
What's the best choke setting for starting a cold generator
Full choke to start, open choke partially immediately the engine starts to where the motor runs smoothly, continue opening as soon as you can while keeping the engine running smoothly. Be sure to open fully before leaving the unit, running it with the choke partially on can cause a rich fuel condition which tends to wash the oil off the cylinder walls and it also dilutes the oil with gasoline.
lp
Dec 26, 2010 | Coleman Powermate Portable Generator...
Crafstman 22hp briggs and straton engine, I've changed spark plugs, air filter...when engine runs it does so unevenly and at times backfires. What can I do to solve the problem?
Don't use the choke, turn the lean all the way to the right and back off 1 and a half turn, its running too rich, usually find this screw under bowl on carb, don't mess with the other screws, take air breather off and let breath without choking, if you have to use the choke after this start with just a little.
Jul 02, 2010 | Briggs Stratton 020273 Elite Series...
3.5 Briggs with not run at full throttle
same problem, was told it was the jets, are your symptoms as follows
runs at low throttle, will only run at full throttle if fully choked
dies if choke is relieved
Apr 15, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Starts good cold with choke runs bogy until fully
You might be too rich on the pilot jet. (Too large)
Run it for a minute with the choke on, then shut the choke off, and let it run with just a little thrttle till it's warm. If it doesn't "clear" up, your jetting may be off. (The pilot does idle) Pull the plug to see what color it is. Black is too rich. (Too large of a jet)
Dec 08, 2009 | 2005 Suzuki RM 250
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
395 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
