Question about Sony Playstation 3 (PS3) Console
Playstation Update was interrupted. Now when PS3 is turned on i won't load the main menu stays on the wavy line screen
    Sniper:
  • 64 Answers
You can turn your system settings back to factory default using the Safe Mode.
Step 1: Turn off the PLAYSTATION 3 by holding the Power button on the front of the unit till the Power light is red.
Step 2:
  1. Touch and hold the Power button, you will hear the first beep, meaning the PLAYSTATION 3 is powering on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep, indicating the video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a third beep and the system will power off (Power light is red).
Step 3:
  1. Touch and hold the Power button, you will hear the first beep, again for the PLAYSTATION 3 to power on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep for video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a quick double beep. At that point release the Power button. If you succeeded in activating Safe Mode, you will see a message on the screen saying, "Connect the controller using a USB cable and then press the PS button."
  4. Connect a USB cable to the controller and the PLAYSTATION 3 and press the PS button to enter Safe Mode.
  5. Then you will see the Safe Mode menu.
Step 4
: We recommending performing the safe mode options in the following order until one of the options works for you. If one of the options work, do not continue onto the other options.
  1. Restore Default Settings
  2. Restore File System
  3. Rebuild Database
  4. Restore PS3 System
Posted on Oct 06, 2009
  • NemisizZ Oct 07, 2009
    I cant see why my solution isnt helpfull..!!?
    its what sony tells you to do if you have this problem,
    and you will find an update option in the Safe Mode menu...
    unless you really feel like unplugging your system and take it down to the store where they gonna do the exsact same.
    If your update dosnt work and it keeps stopping, then try to restore your database, and then the filesystem.
    If nothing of this works, well.... then theres only one thing left... send it to service...
  • DrNova Jan 19, 2011
    Worked for me. I had to go through all 4 options, after I did Option 4, Restore PS3 System, it worked again, though I lost all saved info because if formatted the drive, but at least it works again. Thanks
  • 4 Answers
i had this problem also, i took mine into a sony shop were they connected it up to there pc and redownloaded the software. im not sure if you can do this yourself. my surgestion would be if its under warrenty take it in.
Got a playstation 3 ,you turn it on and doesnt load to the main screen only comes up with ps3 and then the wavy lines can u help
Ok, follow these steps to fix your PS3, unfortunately you will lose your save game data!!
Step 1. Turn your PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep when you first press it, beep again 5 seconds later and then beep once more and turn off. Release the power button.
Step 3. Press and hold the power button. It will beep when you first press it, beep 5 seconds later and then there will be 2 quick beeps together. Release the power button when you hear these 2 beeps.
Step 4. The PS3 will start up asking you to connect a controller via USB and press the PS button. Do this and then go onto the next step.
Step 5. A menu will load. Select option 5 "Restore PS3 system". The console will ask you if you are sure, just accept and then the PS3 will restart. All the original software will be loaded and you will need to enter the date and time and other details.
When you have done all this your PS3 should be fully working again.
Hope this helps and thank you for using FixYa
Aug 25, 2010 | Sony Playstation 3 (PS3) Console
We have a ps3 60gb, and all that comes up on the screen is the wavy lines that is the backdrop for the homescreen. now we did the system reset and now when i turn the ps3 on nothing happens, it just look...
If your PS3 has been restored and the green power light is staying on after you turn it on it could possi bly be the video resolution. If you have been using the PS3 on HDMI you may need to reset it back to standard definition. Do this by holding down the power button for 5 seconds. If that doesnt help try going into the restore menu and "Restore PS£ system" again. If that fails too, download the latest PS3 update and put it onto a USB stick. Using the PS3's recovery menu again, select System update. It will then continue to update from the USB stick. I really hope this helps you out.
Aug 05, 2010 | Sony Playstation 3 (PS3) Console
I have playstation 3 and when i turn the main power on ,then it loads the ps3 logo with sound ,but just after that only some almost blue screen is on backround and some white wavy mooving line or...
It sounds like the system software has become corrupted. If you dont mind losing your save games and all other data you could try a PS3 full restore. Turn the PS3 onto standby (red light on). Press and hold the power button until it turns itself back off. Press and hold the power button again until you hear 2 quick beeps together then let go. The PS3 will boot into the recovery menu. Choose option 5 "Restore PS3 system". Let it do its thing and hopefully that will solve your startup problem.
Hope this helps
Aug 03, 2010 | Sony Playstation 3 (PS3) Console
It turn on and it stay on the main screen
Try these steps below to see if it will fix the problem on your ps3,
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System.
Take care.
Jul 03, 2010 | Sony Playstation 3 (PS3) Console
My ps3 isn't showing a menu, just the wavy line and star screen?
turn your ps3 off then when you touch the power butter hold it iuntil you hear two beeps on the second beep let go and the main system ovveride scree will show up click on restore settings to default and it should go back to normal
Apr 30, 2010 | Sony Playstation 3 (PS3) Console
When i turn it on all i see is a wavey line. no main menu
I had the same problem after loading the latest patch and I resolved the problem.
The ps3 would turn on and just sit at the wavy line.
I initially installed the latest patch directly on the ps3 through it's internet connection. To fix it I had to download it and copy it to a sd memory card (camera memory) and insert that into the sd memory slot on the ps3.
Follow this procedure for proper setup of the update file.
http://www.us.playstation.com/Support/Sy…
Here is what i did to fix it.
-hold down the power button for 2 separate beeps. It will turn on then off. Take finger off button.
-after it powers off (light red) press the power again and hold until you hear a single beep (or 2) then a double beep. After the double beep stop pressing the button. (it took me a couple of tries to get to this point.)
-This will bring you to a menu
-Select install update option
-insert the sd memory card or usb memory card/stick.
-the ps3 will find the update and reinstall.
-let the install finish and let it reboot on it's own.
This worked for me. Hope it works for you.
Nov 20, 2009 | Sony Playstation 3 (PS3) Console
My ps3 screen is purple when you turn it on
I have the same prob, when I turn my ps3 the screen stays on the purple waves and won't load the main menu
Aug 31, 2009 | Sony Playstation 3 (PS3) Console
I downloaded 2.76. Two days later i went to play the system and it froze on the wavy lines won't let me get to the main menu
youu could try to take a card of some kind. put it about half way in the game spot. then blow in the gap between the card and the black rubber on the ps3. It may build up dust. also try restoring
May 27, 2009 | Sony Playstation 3 (PS3) Console
No main menu, just wavy lines with sony entertainment
This is a hard reset of the system, used when there is a catastrophic error etc. I have trawled these kind of sights and the main concensus is to ensure you have a back up of all important data. I experienced the same issue but the method above was advised by my games shop.
Nov 03, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
1,997 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
