Question about Tefal Irons
Dismantling a Tefal program 8 400
I have a Tefal program 8 400 with heating issues. After being left in storage for a while, it works fine, but after some use, the heater cuts out at progressively lower temperatures until it won't turn on at all (the relay clicks twice when you connect power).
I'd like to get inside to fix the problem (I'm an electrical engineer, it shouldn't be too hard :oP ), but to get inside the case without marring it, I need to know where the clips are - I have the three base screws off, but that's as far as I can get without a better idea of how the shell is held together, without
Did you ever work out how to get the casing off??
I managed to drop my iron on a dodgy angle and some of the plastic casing has popped out and I don't want to force it back in when it clearly needs to be opened and put together again in the correct alignment.
If you know how to open it past the 3 screws, please tell....Thanks
Posted on Jul 19, 2010
Tefal prog 8 500 series iron not heating up properly -
My Tefal Program 8 400 iron will not heat up. Light is on but nothing coming through. I has used it 10 mins before this happened
Apr 05, 2010 | Tefal UltraGlide Easycord FV4256 Iron
Red light on
element is shot,take it back or send it back for repair
May 31, 2009 | Tefal UltraGlide Easycord FV4256 Iron
Tefal iron stopped working
You better open your tefal iron,so you can fix the problem.When open look for the contact bronze in color must them place in the center,use a sandpaper to clean the contacts,when already clean test it if its okey going to hot again if not turn the udjuster to adjust it is a screw liked.
Hope it nay helps you;
Apr 22, 2009 | Tefal Aquaspeed 155 Iron with Auto...
Tefal program 8 500 Iron
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Mar 16, 2009 | Tefal UltraGlide plus 1656 Iron
Tefal Express 1750 has water dripping from it when using steam
That means that water is not heated properly and does not produce steam.
Try a complete descaling, often this happens because the water reservoir and heating element is covered with scale.
Feb 17, 2009 | Tefal Irons
Red light on
Per the owner manual, you shake the iron to "wake it back up".
The safety cycle initiates after it sits over 8 minutes on it's heel, or on it's sole plate or it's side side for more than 30 seconds. The light shoul dbe blinking when it is in the safety mode.
If you can't wake it up, then return it if it is still under new warranty.
Jan 30, 2009 | Tefal UltraGlide Easycord FV4256 Iron
Tefal 400 iron auto shut-off light stays on
TEFAL B.800
AUTO LIGHT ON,BUT NOT TEMP LIGHT.NOT HEATING UP.HAD BEEN USING BUT UNPLUGED WHILE I GOT MOE IRIONING.
Jan 31, 2008 | Irons
How to dismantle a Tefal Aquaspeed 150
no, its not the Aquaspeed 170, but Aquaspeed 150. i succeded to unwrap the housing, but did fail in disconnecting or dismounting the power cord terminal.i could not disassemble the Iron to reach the heater. to dismantle, step 1 unscrew 3 visible screws. step 2 lift the heel cover away, by unsnapping 1 hooks at the right and one at the left side of the heel cover. i used thumnbnail to deform the heel cover for not to wear out the snap-in hooks. step 3 remove the dischalk stick (don't know the right wording in english) step 4 lift the top cover (which covers the spray jet part), 2 hooks at both left and right, use thumbnail or flat screwdriver, start at the top hook. step 5 take off the spray and steam buttons, 1 hook at the front side, 1 hook at the outer back side step 6 take off 2 screws: one keeps the upper half of the handle, the other fixes the water container at the heater plate. Attention: when unmounting the container, and turning the iron upside down, a small (4mm diam, ~10 mm length) silicone cylinder part will fall out, some kind of actor of a bimetal thermo switch in the ground plate, which probably controls water flow (not the electric thermostate) so far so good, i got my problem solved, but would like to know how to disassemble the container from the ground plate and how to replace the cable?
Apr 12, 2007 | Tefal Aquaspeed 170 Iron
Irons Logo
643 people viewed this question
Top Tefal Irons Experts
Billy Detlefsen
Are you a Tefal Iron Expert? Answer questions, earn points and help others
