Question about Acer Aspire 3000 Notebook
Just asked. hi my acer aspire3000 has a vertical line and lcd how can i solve and what i should i do so that i can fix this problem?
  • 22 Answers
The problem you've got is all about on your video card. This is the common problem. You have to change it with new one! To do this, you're need an expert to open the case on the motherboard. If you, locate the video card, pull it off and replace with same model.
Hoping that this can fix your problem..
Best regards,
Geloaa
Posted on Oct 06, 2009
Vertical lines in the monitor
Vertical lines from the top to the bottom of the screen are due to failing T-CON board (part of the LCD panel assembly). You can try reseating the ribbon cable attached to the T-CON board, otherwise new screen will be needed, these failures are due to cheaply made screen by company such as Chi Mei. It willget worst with more lines.
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Jun 04, 2010 | Acer AL1715 17" LCD Monitor
Blue vertical lines on Vista laptop on Startup
They haven't been able to solve it because it is a hardware problem....vertical lines, whatever color are indicative of a failing lcd panel. The lcd panel will continue to get worse until it fails completely. The only other possibility is a loose data connection on the back of the panel, if the data connection is slightly loose, re: one side of the panel is not tightly connected it can give off artifact in the way of vertical lines or checkered blocks.
May 04, 2010 | Acer Aspire 5920-6727 Notebook
I have a 42JC2D TV. Vertical color bar lines
It is hardware issue related to LCD Panel (screen).
Regarding fixing it, it depends if you are handy with electronics stuff repair and can replace circuit boards in tv etc then please check T-Con (lcd controller board) on top center position at rear of lcd panel, this board would be covered with metal shield. Need to take off back cover of tv to get access to T-Con board. If T-Con board does not solve lines problem of screen then LCD Panel is bad and will be replaced.
If you fee uncomfortable doing so then repairman option is better choice.
Hope this info will help you.
Thanks.
Feb 27, 2010 | LG 42LC2D 42 in. LCD HDTV
Thin vertical line that is multi coloured
hi
just clean the 15 pin connector in the cpu end
Aug 12, 2009 | Acer Televison & Video
I have an acer aspire3000 the keyboard and mouse will only work in safe mode help me please
I pulled out the battery. Cycled the power for 30 seconds ( holding the power button ) plugged the system back in ( with out battery in sysetm )
If not solved let me know.
Thanks.
Jun 04, 2009 | Acer Aspire 5100 Notebook
I wand to install internetcontroller driver because i can't install local area network connection
Find them here, select notebook in your product line box and Aspire3000 in the on the right.
Then look down the list for the Lan driver
http://www.acerpanam.com/synapse/forms/portal20.cfm?website=AcerPanAm.com&siteid=7117&areaid=2&formid=3394#results
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 13, 2009 | Acer Aspire 3000 Notebook
Vertical line white, regular, blinking.
I don't think it's the bulb. Sounds like an LCD panel issue. Maybe one or more of the 3 LCD panels is either not working right or the unit has been dropped/jarred and the panels have moved (All three have to line up right optically to give the right colours). You need to take the projector to a qualified service centre.
I hope that solves your Problem, If so kindly accept it.
Thank You, Arjun.
Apr 01, 2009 | Acer Projector Lamp for PD110, PD110z
Vertical lines in my laptop screen
I had the same problem - sent it in to Acer and they replaced the LCD for 500 bucks!
Aug 18, 2008 | Acer Aspire 9500 Notebook
Acer aspire3000
Hello ccb37s
It's most likely a wireless adapter in a minipci slot.
The problem might not be the adapter it can be that the video or cpu is overheating check if there is dust in the ventalation and clean it.
If this solution was any help at all please rate it as helpfull or fixya.
And if you need anything else let me know, you can ask me 24/7 by clicking
on the ask me button, I will ansver in most cases within 24hours.
Thanks and good luck!
May 04, 2008 | Acer Aspire 3000 Notebook
ACER 3023 SCREEN PIXELATING
Try uninstalling and reinstalling the video drivers. If this doesn't work, it's likely that the LCD control board or cable is damaged.
Feb 13, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 3000 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
