Question about GE A730 Digital Camera
My husband recorded himself on my camera and when i go to try and delete it, my camera gets stuck and wont let me do anything
  • unhappyed May 11, 2010
    How ugly is your husband??
Flip video instruction manual
Had the same problem. After trying everything, this worked:
From a command prompt, list directories. You might see one called ".Trashes\501" -- this is the directory where I found all the videos hiding that we tried every trick in the book to delete. If you see video files in this directory, simply delete them using the command prompt. Then exit the command line interface and check your camera. You should have a full 60 minutes of recording time restored.
Hope this works for you!
May 01, 2014 | Video Cameras
My husband has 'lost' all our recordings on our video camcorder. an they be recovered? He thinks he tried to delete 1 recording but they've all gone. They were saved on a memory card. Thanks.
definitely fixable. First off stop using that sd card, when a file is deleted it basically just makes it invisible, and lets the device know that the space it occupied is up for grabs. When you plug the camera into the computer via usb cable, or the flash card into a card reader it is mounted on it as a removable hard drive. Using a recovery program you should be able to un-delete anything, that wasn't written over.
http://majorgeeks.com/UndeleteMyFiles_d5904.html
This seems like a very strait forward free tool, just point it to the drive letter the card/camera is mounted to, and follow the instructions. If this tool does not work out for you there are plenty of other ones out there to try, not to mention pay versions.
Best of luck!
Aug 28, 2011 | Sharp Video Cameras
Olympus SP-550UZ camera will not upload recording to computer
Long videos should be transferred to a folder you create on your desktop using a separate card reader. eaa3d1b.jpg
Jun 15, 2010 | Cameras
My JVC camcorder keeps saying lens cap is on and it wont view any image just plain black. I have had it for about five years first time anything like this has happened. I think it might have been dropped...
That sounds like the shutter is stuck closed. Unless you're highly technical, if will most likely require servicing. Get an estimate first, the repair cost can be worth more than the camera.
Mar 14, 2010 | Panasonic NV-GS11B Mini DV Digital...
My Panasonic pv-gs180 doesn't record.
If you have Head Cleaning Cassette play it at 10 seconds or use new Cassette for 10 minutes play or record. Otherwise Video Head damage
Mar 10, 2010 | Panasonic PV-GS180 Mini DV Digital...
Set button does not work
Hey Christinaaaa,
I had the same problem with same camera. Mine was the instant video button on the upper right was stuck down (had dropped the camera). Took top cover off and shaved the hole that the video button is to make it round again. Set button started working right away after that. Easy fix with an eyeglass repair screwdriver.
I hope this post isn't to late to help you. If so, maybe it will help someone else.
Jim
Dec 01, 2008 | Casio Exilim Zoom EX-Z80 Digital Camera
Recording From Underwater Camera
I have a gs11EB. I don't it's possible to record into this camea from an external source?????
Jul 03, 2008 | Panasonic NV-GS11B Mini DV Digital...
Flip video problem
I have had this exact problem. The Flip Camera read "empty" however if I tried to record something by pressing the red button, the camera read "full." I started having this problem and kept on seeing fewer and fewer minutes available to record. Today, I was trying to shoot and then uploaded three videos. I could use the camera no more. So, I did as you suggested...plug the camera in to my Mac and then emptied the trashcan. It WORKED!! I got all sixt minutes back.
Jun 02, 2008 | Pure Digital Flip Video Camcorder
Help ejecting dvd
I had the same problem and tried for ages (even tried forcing the door open thinking I could just tape it shut) without luck.
Then my very clever wonderful husband had a go (I know i'm crawling and yes my knees hurt).
Any way to the relevant bit. If you hold the eject button down and at the same time slide a knife or similar object round the edge of the door where the screw is near where it says photo/select you'll find that the door opens as this is an override mechanism.
Feb 22, 2008 | Hitachi DZ-GX3200A DVD Camcorder
It keeps making a beeping noise and wont let me record or do anything!
Try taking off the battery and reinserting it to see if it resets mech,If this doesnt work you wil have to bring to service.Dont go at it yourself as you could cause serious problems,
May 23, 2007 | Sony Handycam CCD-TRV68 Camcorder
GE A730 Digital Camera Logo
14 people viewed this question
Top GE Cameras Experts
Steven Wander
Steven Wander
jjanesic
jjanesic
Level 1 Expert
Are you a GE Camera Expert? Answer questions, earn points and help others
