I WAS LUCKY ENOUGH TO FIND A BODY SHOP TO RE WELD MOUNT PLATE BY TIG, ALL IS GOOD BUT A DODGY WAY TO MOUNT DOORS? CRAZY COST CUTTING?
Look at the hinges. If they are bolted and the only problem is they are loose. Try to tighten tem. A tig weld in place will burn odff any paint and if welded poorly you will have alignment problems. The welder will be welding heavy metal to sheet metal The bolts that hold the door on pass through a heavy steel threaded plat behind the sheet metal. Good Luck, Ned
