Question about Nortel Enet Routing Switch 3510-24T Incl Na Power Cord Rohs (AL1001E08E5) Transceiver
How to change password in nortel 3510 with divice manager iam unable to telnet only i can login with device manager in my nortel 3510 i want change password with device manager.
Iam unable to login with consol in nortel 3510 it is posible with fastethernet port to login give me solution
99598888178
Posted on Oct 22, 2009
I want to factory reset my nortel AP 7220, how do I reset? What would be default IP after reset?
There is probably a reset button somewhere on the device, it is probably a small pinhole that you put a paper-clip into the reset.
If it has its own http web page, there is likely a reset to factory defualts option.
The ip of the computer connecting to it should not change.
On a computer connected to it, open cmd start>run then type in cmd, and type 'ipconfig'.
It will display details about your connection. Where it says 'default gateway' is the ip of the device.
You could try to put the ip in your browser and see if the device has a web page.
May 02, 2011 | Nortel Networks 7220 (NTE350BG) 802.11...
How to reset password of username in 6506e switch through telnet not console plz give reply as early as possible.
login through telnet, remove the current username and password.
configure the username with the new password
config t
username xxxx pass xxxx
1. do not exit the current session, telnet the sw with new session and give the username and new pass. if does'nt work roll back the config.
or
2 excute login in current session and try with the username and new pass
Feb 21, 2011 | Cisco Catalyst 6506E Switch Chassis...
Forgot my Login anyway around that?
The best thing to do is to install a bare fun_plug with telnet capability. If you do not know where this is, one version is available at http://www.inreto.de/dns323/fun_plug. Just follow the instructions in the README file for the latest version.
Restart your DNS-323. Once it starts back up, do the following:
1. Login to your device using telnet. Most OS have this or you can use a free downloadable client like putty
2. You will be faced with a Linux # prompt. From here you can change the password of admin by typing:
# passwd admin
3. After changing the admin password, exit from putty and try logging in to your device via a browser'
You should be able to login using the new password
Please rate our help to keep this free service online
Jan 04, 2010 | D-Link Dns 323 2-Bay Network Storage...
Telnet password
Use this step:Router>enable Router#config t Router(config)#line vty 0 4 Router-2(config-line)#login% Login disabled on line 66, until 'password' is set % Login disabled on line 67, until 'password' is set % Login disabled on line 68, until 'password' is set % Login disabled on line 69, until 'password' is set % Login disabled on line 70, until 'password' is set Router-2(config-line)#password newpasword
Mar 08, 2009 | Cisco 800 (CISCO802) Router
Lanier ld122 503 service unavailable
This can occur if the Web services has been turned off in either the Web Image Monitor or from a telnet command for this device.
To check the status of these services you will need to telnet into the device.
1. From a command prompt type : telnet then the IP Address of the device
2. Telnet will respond back with a request for a login and then a password. Enter the login and password. The login and password used for Telnet are the same credentials that are used to log into the device’s Web Image Monitor (WIM).
3. Type in show at the msh> command prompt.
This will output many lines of information. The information you are concerned with is under the TCP/IP-Mode heading. You may need to scroll up in the command prompt window to see these services. The device’s services will be shown followed by their status. The ‘show’ command will show if the services are enabled (UP) or Disabled (Down).
4. If Web shows a down status, at the command prompt msh> type in set web up.
5. At the command prompt msh> type in logout
6. To make your changes Active you must type yes when prompted to "save configuration data"
Note: Always check with your system administrator before making any changes on a network device.
Aug 19, 2008 | Ricoh Office Equipment & Supplies
Ethernet controller driver
What is the model number and brand of your PCMCIA Card ?
Dec 11, 2007 | Compaq Network adapter
Zoom X6 Password change and Firmware Update
Yes you are right. I agree with you. Real tech support really matters.
 I would like to add information about what you did when you downloaded the firmware, there are certain firmware for its problem. One firmware is design to fix this particular problem . Are there firmware version and short description on the website? You might run accross one that fixes "saving problem on User interface" that might be the solution. But you are indeed on the right track. its just that the website of Zoom maybe is not that detailed and userfriendly.
Oct 12, 2007 | Zoom (5590-00-03) Wireless Router (G66115)
Reset a password for IBM NWAYS Router 2210 Model 12E
Does this mean anything to you Remote Login Names and Passwords During a remote login, the device prompts you for a login name and password. You can display the login name when logged in to the device from a remote console by using a device status command. Logging in Remotely or Locally Logging in to a local console is the same as logging in to a remote console except that you must connect to the device by starting Telnet on your host system. To log in remotely, begin at step 1. To log in locally, begin at step 3. To log in from a remote console: 1. Connect to the device by starting Telnet on your host system. Your host system is the system to which remote terminals are connected. 2. Supply the device?s name or Internet Protocol (IP) address. To use device names, your network must have a name server. Issue either the device name or the IP address as shown in the following example: % telnet brandenburg or % telnet 128.185.132.43 At this point, it makes no difference whether you have logged in remotely or locally. 3. If you are prompted, enter your login name and password. login: Password: It is possible that there is a login and no password. The password controls access to the device. If a password has not been set, press the Enter key at the Password: prompt. Logins are not set automatically. For security, you can set up user names and passwords using the add user command in the CONFIG process. For additional information, see the add user configuration command, on 56. Remember to reload or restart to activate any changes. Note: If you do not enter a login name and valid password within 1 minute of the initial prompt, or if you enter an incorrect password three times in succession, the device drops the Telnet connection. 4. Press the Enter key to display the asterisk (*) prompt. You may have to press the Enter key more than once or press Ctrl-P to obtain the * prompt. Once at this level, you can begin to enter commands from the keyboard. Press the Backspace key to delete the last character typed in on the command line. Press the Delete key or Ctrl-U to delete the whole command line entry so that you can reenter a command. See ?Command Completion? on page 20 and ?Command History? on page 23 for more information. You can also use local Telnet commands on your Telnet client to close the Telnet connection.
Jan 21, 2007 | IBM NWAYS Router 2210 Model 12E
Nortel Enet Routing Switch 3510-24T Incl Na Power Cord Rohs (AL1001E08E5) Transceiver Logo
424 people viewed this question
Top Nortel Computers & Internet Experts
kwiz
Level 1 Expert
Vuk B
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
