no power, fan not working, stanbye light on motherbord is working.power supply unit is tested and is in good condition..does it mean motherboard problem or processor problem?
buenas noches, temgo una board msi_k9mm_v_ le acabo de cambiar el hd tenia uno de 250 gg y se lo...
(More)
BUENAS NOCHES, TEMGO UNA BOARD msi_k9mm_v_ LE ACABO DE CAMBIAR EL HD tenia uno de 250 Gg y se lo cambie por uno de 320, tambien la desarme totalmente y la limpie, ahora que la volvi a armar, la CPU prende, las unidades de CD abren y cierran, pero el monitor se queda en negro, no da ninguna señal y cuando la reseteo no apaga, he revisado mucho las conexiones que esten bien y no encuentro el rpoblema, me pueden colaborar por favor? gracias LILIANA
Dear sirs I had a hardware defect that can be defined as a component severely damaged by little fire...
(More)
Dear sirs I had a hardware defect that can be defined as a component severely damaged by little fire and smoke and I would like to replace it by it´s substitute. It is a three pin device marked MW5564. I would like to know what component it is and it´s characteristics as it seems to be very easily replaceable. It is located close to the last pin of the memory slots. As I can´t boot it for the moment it seems to be the major problem. Thank you for your attention.
Report abuse posted by lanang22game on Mar 29, 2009 No Sound in Vista Ultimate Mobo P5VD2-MX SE...
(More)
Report abuse posted by lanang22game on Mar 29, 2009 No Sound in Vista Ultimate Mobo P5VD2-MX SE Still need a solution for this problem? Try our Premium Assistance plan Solution #1posted on Mar 29, 2009Asker's Rating asthanarht install sound driver from here http://drivers.softpedia.com/get/BIOS/Asus/ASUS-P5VD2-MX-SE-BIOS-0203.shtml No Sound again !!! Please Help Me
