Question about Indesit W 123 Front Load Washer
WIDl126 - door lock and easy iron flash
A couple of months ago my 126 starting playing up, I could hear the water been taken in, but was not entering the drum, it just seemed to drain back out. The door lock red light would begin flashing along with the green easy iron button ( a draining noise could also be heard). After about 5 mins the nosie ends and I can eventually turn the machine off and open the door.
The machine began working again a week later and has been doing so for the last month or two, but now it has started playing up again. Anybody know what is wrong and should I just invest in a new machine?
  • fritchie83 Dec 24, 2007
    thanks, have checked and definately not the drain hose, think it may the pcb board (don't know if something has come lose as the machine does tnd to jump accross the floor)
  • irene-kong Dec 27, 2007
    I got the same problem for the WIXL 126 Indesit washing machine. The
    washed my cloth and every light turns off. When I press the power
    button again, the door lock led, delay time button led and easy iron
    button led all flash rapidly. Does any one know what wrong with it? I
    bought this machine only one and a half years.
    Champion:
  • 249 Answers
Worth trying this! make sure the drain hose is only down the waste pipe about 6 inchs, and up off ground level about 24 inchs ie. 2 feet.If that don't not work it could be faulty pcb board!let me know.bye,close,ire.
Posted on Dec 24, 2007
  • eamonn close Dec 24, 2007
    did you check out water level switch,If you blow through it you should here it clicking
Washing machine not working
The lid switch/latch has failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 10, 2009 | Washing Machines
Sta-rite heater error code 126
The 126 is not an error code, but it maybe the temp of the water that the heater is reading. If the heater thinks the water is 126 degrees, it will not start at all.
If the heater is reading the wrong water temp, the problem is the Thermister, which is the sensor that is suppose to read the water temp. You will need to replace this sensor in order to correct the problem with the heater. It is really easy to do!
If you have a manual for the heater, if you go to the Replacement Parts Listing for the Electrical System, page 53 in the online version, the Thermistor is Item #9. It goes into the left side of the manifold in the to place, between the first two manifold bolts.
Jun 22, 2009 | Sta Rite Sr200lp Max E Therm Pool & Spa...
Stove flashed F11 and then locked the oven door
HI, this is control failure. the logic chip set is damaged. this is causing these erratic commands and the unauthorized locking of the oven door. you will need ot replace the control in this case.(EOC/clock)
May 29, 2009 | Frigidaire FEB27S5A Electric Single Oven
Dacor ERD36SCH/H will not self clean
Door lock motor suonds like it is bad. Not an easy part to replace. You may need a technician.
May 12, 2008 | Dacor Epicure ERD36 Dual Fuel (Electric...
Indesit 126 washer/dryer
I have had the same problem. I thought it was the pressure switch as this is what the error code means - low or high pressure resulting in cut out. I too thought id fixed the problem but it has returned
Sep 10, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
592 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
