Question about Wolfgang Puck Food Processor
Good Evening, I cant get the circular blade to release from the stem. Any suggestions.
WILL NOT STARE
Posted on Aug 23, 2010
  • lrward62 Aug 23, 2010
    WILL NOT START
    President:
  • 3,433 Answers
Good evening to you!!! Two q's? which way are you turning it and are you using your super special blade holder?
Remember, Off will be in the direction of blade rotation. It may be snug because it tightens when the the blade turns. Please make sure it's unplugged. Not funny and don't say it doesn't happen. Good Luck, Ned
Posted on Oct 06, 2009
How do I find out if my Cuisinart blade has been recalled? Model #DLC-7E
The simplest way to check if the DLC-7E blade is one of the recalled blades is to take the blade out and look at it. If there are 4 rivets holding the blades to the stem, it should not be used. For more information, look at https://recall.cuisinart.com/ .
I hope this helps.
(The rivets, if present, will visible when you look at the top of the blade where the two sections of the blade go around the stem of the unit.)
Jan 16, 2017 | Cuisinart Food Processors
Blade of cusinart dlc 7 superpro food processor will not spin when food is in the bowl- works when no food is in it. Is it is the stem? How do I replace it?
It'll probably cost more to fix than replace. If you have a collection of blades, maybe find one in working order on a shopping site and meld the two together. Happy hunting! Happy New Year!!!!
Jan 01, 2015 | Food Processors
How do I attach the slicing blade to my cuisinart food processor
Slide the button down on the white stem. Place the blade on the stem, and turn the blade a few degrees and the button should click into place.
Jun 27, 2010 | Food Processors
Am I missing a part
I overlooked this too. Set into the foam packing material is a stem made just for the shredding disk. It's about 4" long and also has a hex shaft. This hex is just slightly smaller than the hex on the other shaft the drives the blades. The dough hook - Remove the blade assembly and put the dough hook in its place.
Apr 08, 2009 | Black & Decker Food Processors
How to attach Cuisinart blades DLC 8 to DLC7 stem
The DLC-8 blades and the DLC-7 blades are not compatible. To attach the stem, first attach the stem to one of the compatible blades - the stem should day "DLC-7" for the DLC-7 blades - by inserting the first two tabs of the stem into the first two ridges of the blade connector - the left-most tab should be sticking out past the end of the blade connector - then slide the stem into place so that all tabs fit securely into the blade connector. Next, place the end with the blade up and insert the stem into the middle of the workbowl. There is a video for all Cuisinart food processors on the Cuisinart website.
-Tha Mp3 Doctor
Jan 01, 2009 | Food Processors
I can't get the blades on the processor. there is a holder that somehow snaps into the blades before they are put on the processor
The regular chopping blade requires a stem adapter. The other blades require the detachable stem. I would double-check the user manaul to get a visual on it. Cuisinart food processors are great, but they are also the hardest to assemble.
-Tha Mp3 Doctor
Jul 19, 2008 | Cuisinart Limited Edition Metal MP14 Food...
Blade will not release
Our blade just came apart at the seam just above the blade, so we know what's inside. There is a small v-shaped piece of spring wire that is spread apart from the stem that is mounted to the machine. When the button is depressed (it's on a tiny spring, like a mattress spring, and that's what makes it bouncy), it spreads the v-spring wire and releases it. If you can get the seam apart, it will release the v wire and not damage the machine. Replacement blades are available on-line for $13.95, and whole machines are available on e-bay. Good luck.
Nov 16, 2007 | Ultimate Chopper Food Processor
Wolfgang Puck Food Processor Logo
184 people viewed this question
Top Wolfgang Puck Food Processors Experts
richie46
Are you a Wolfgang Puck Food Processor Expert? Answer questions, earn points and help others
