Question about Whirlpool Freezers
Whirlpool refrigerator, Model # ED2VHGXMQ00 suddenly stops coolin
I have a Whirlpool refrigerator, Model # ED2VHGXMQ00. The refrigerator suddenly stopped working and all the ice melted and the air that blows from the freezer compartment is warm. The unit is just shy of 6 years and the only problem that I ever had was a strange smell coming from the back about a year ago which went away gradually after I did a thorough cleaning of the coils, the reservoir pan and anything that I could find.
After the unit failed I opened the back of the refrigerator and started to clean the coils again when I noticed that the compressor was very hot, I could not keep my hand on it for more than 4 or 5 seconds even thought the fan next to it was working perfectly, I also noticed a sticky substance on the floor but I an not sure if it came from any of the components. Does that mean that the compressor has gone bad or does the freon needs to be refilled?
I have a whirlpool chest freezer and the warning light has come on it was stored in the garage but was working fine,then moved into the house.the compressor kicks in for about 10 seconds then cuts out
a refrigerant line may have been damaged in the move, loss of refrigerant or a kinked line has stopped the compressor from working, need to attach refrigerant gages to find the problem and know the refrigerant level
Nov 19, 2014 | Whirlpool Freezers
Compressor runs but fans dont.
If the compressor is running and pumping with no heat produced, you have lost refrigerant.. Most modern freezers have a controlled fan so the coil can freeze before the fan starts.
Apr 04, 2014 | Samsung RFG297AAWP 28.5 Cu. Ft. French...
Infrared reciever ice control
What is your question and model number? Is this a refrigerator that you need information about the infrared reciever? I have Whirlpool Electronic Infrared service information just not sure of your question or model number. Thanks, Sea Breeze
Model Numbers can be found in these locations
Dec 13, 2012 | Whirlpool Freezers
I have whirlpool imperial series refrigerator model et1lfkxkq03, which has freezer on top. Water from freezer is leaking into refrigerator. I cleared out the freezer and can't find the clogged drain.
You will probably have to remove the back panel, which is the evaporator cover. The defrost water drain is always at the base of the coil. **** the drain out and pour some hot water down it
Jun 22, 2011 | Whirlpool Freezers
I have a whirlpool upright freezer,model EVL181NXTQ.There is a buzzing noise and the top half doesn't freeze..When you close the door,uou can hear the suction sound...Please help,freezer is only 2 years...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 01, 2011 | Whirlpool Freezers
Drain stopped up on freezer model evl201nxrq
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 05, 2010 | Whirlpool 20 cu. ft. / 566 liter Upright...
Freezer stopped working suddenly
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 30, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Constant Defrost causing water accumulation problems
Yes! look under you fridge for the consendate drain hose *(usually dangling right over the catch tray) and using a long piece of slightly heavy guage wire snake up the drain hose and see if it's blocked.
If it isn't blocked you might have a crack somewhere in the fridges interior near the fridge/freezer interface. That might be a bit harder to spot since it would most likely be under cover.
Good luck and be careful.
Dec 29, 2009 | Whirlpool Freezers
Freezers Logo
216 people viewed this question
Top Whirlpool Freezers Experts
christian nielsen
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
