Hi there ... I'm wondering if you can please help me ... I've switched on an old mobile phone that I haven't used for several months. It asked for a PIN which I had forgotten and after three unsuccessful guesses it asked for the PUK code ... I have no idea what that is ... are you able to please assist?
-   NOKIA N95 LOCK NEED PUK CODE-   terrence_dea
May 04, 2009
-   How do i find my PUK code in mobile-Nokia N70?-   Divyesh Vala
Apr 21, 2009
-   I put in the wrong pin 3 times then it locked and said i need a PUK code.-   Guest
Apr 02, 2009
-   i change with another handphone.I never used this handphone a few month ago.Now i forgot my password.The hand phone say tpye PUK number.I dont know how to slove it.Please email to me. -   linhtet82
for at&t users all u have to do because i have a 2610, is call 611 which is customer care and ask for the puk code. they will ask you for your phone #, and possibly your sim card # or your last 4-digits of your social security just for protection reasons. so just be prepared just incase they ask you.
Every PUK code is unique so nobody can tell you your PUK number, but i will tell you what you can do! 1)
If you still have your packet that your Sim Card came in, you should
find your PUK number in there, if you don't have the packet, please
read bellow.
2) You must get a phone that is on the same network
as your phone and call the networks Customer Care and ask them for your
PUK number, they will ask you for your phone number, then they will
tell you your PUK number. Once you have done this, you will be able to
reset your Pin number so you will be able to go into your phone again.
Please also remember to give me a good rating on my profile.
write down ur sim number which will be on ur sim card and call up to ur
customer care and ask them a puk code they'l ask u the sim no u tell
them thats it ... and if u r thinkin how to call to customer care
without unblocking the phone .. u gotta use other cellphone of the same
network u using to call customer care ... not to worry
Complete information : The SIM card protects
your subscription and not the phone from unauthorised users. If you
change SIM cards you can still use your phone with a new SIM card. Most
SIM cards are blocked at the time of purchase. If your SIM card lock is
on you have to enter your PIN (Personal Identity Card) every time you turn on the phone.
If you enter the wrong password three times in a row the SIM card gets blocked. This is indicated by the message PIN Blocked To unblock this you need to enter your PUK
Note:
card (Personal Unblocking Key). Your PIN and PUK
is supplied by your service provider. You can edit your PIN and select
a new four to eight digit number
If the Message Codes do not match appears when you edit your PIN you entered the new PIN incorrectly.
If the message Wrong PIN followed by Old PIN appears then it means that you have entered the old PIN incorrectly.
To unblock your SIM card:
When PIN Blocked appears enter your PUK > OK
Enter a new four to eight PIN > OK
Re-enter the new PIN to confirm > OK
To edit your PIN:
> Settings > the General tab > Security > Locks > SIM Protection > Change PIN
Enter your PIN > OK
Enter a new four to eight digit PIN to confirm > OK
To turn the SIM card On /Off
> Settings > the General tab > Security > Locks > SIM Protection > Protection and select On or Off
Hi Friends, Having problem with Nokia N95? Don't Worry. There is a site where you can easily fix your problem. Mainly Nokia N95 problem is forUnlock Code, Puk Code and otherLock Codes. If you are searching for such codes you Must Click Here. There are also some problem with Nokia N95. Such as software problem, hardware problem etc. If you having these problem you canClick Here. May you find your solution.
turn on phone...it will ask for PIN code
if you got it wrong 3 times then it will ask for PUK code which means (Personal Unblocking Code) and that is security stuff.to find the PUK code you have to turn the back of your first sim card and there should be an 8 digit number...enter the code...it will ask you for a new PIN code...and i think you have to make one?hope it helped?
My PUK number had been lose,but my sim already lock and want me to use the PUK number.Can you solve this problem for me?I want the PUK number hurry!!!!!
Ok people, I recently posted a help thing for my phone, but it's fixed, and here's how, on your SIM card on the back there are digits try placing those in. ( With PUK you get unlimited tries). OR ( this is the one that worked for me) CALL YOU SERVICE PROVIDER. ( rogers, Bell, Virgin...etc) and ask for your PUK. And they HAVE to give it to you. and if they cant help, call for there manager or somethin. HOPE THIS HELPS.
my n95 started to randomly jumping to random files and phone numbers then when i was able to switch...
(More)
my n95 started to randomly jumping to random files and phone numbers then when i was able to switch it off its now frozen on the pin screen ,which i cant enter the pin to boot it up any suggestion wouls be a great help thank you
trying to retrieve my contacts from n95 to computer as i am unable to see phone screen due to a...
(More)
trying to retrieve my contacts from n95 to computer as i am unable to see phone screen due to a cable problem have tried nokia pc suite with no success
i already bought a Nokia N95 8GB, I know that the phone memory 8gb that show on screen doesn't true,...
(More)
i already bought a Nokia N95 8GB, I know that the phone memory 8gb that show on screen doesn't true, so that i'm trying to insert my micro SD memory card, but i don't know how... where should i put it?
hllo my name is daniel is have a nokia n95 it say ''PIN code blocked. enter PUK code'' how can i find that out if u find out can you please send it to me, thank you
when i was working on my phone for something they told me to enter my PUK code and i do not know what that mean. I try all the number i know but it still does not work. and i try to call the number they have on the phone book but no one picking up.
I got my pin wrong 3 times before I realized that my pin was right in front of me, but when I checked the screen, it wants a PUK code. I've been to SO many websites and none of them can help me. I even contacted rogers, my service provider at Customer Care and they were like, cant help you. I have a Nokia 2680slide phone. Help me PLEASE!!!:D
My phone asked for a PIN which I had forgotten and after three unsuccessful
yuki
Comment by Guest, posted on Jul 04, 2008
I have Nokia mobile phone. It is locked and asking to enter PUK code. i have tried several times.but none is correct. please suggest.
anand
Comment by Guest, posted on Jun 26, 2008
Comment by Guest, posted on Jun 20, 2008
NOKIA N91 8GB
Comment by Guest, posted on Feb 12, 2008
call a custmer care and take it your puk no and inter the no your phone succces on condition
I tried to change the password on my new samsung phone and as i guessed the existing one wrong my phone is no longer in use. I need the PUK code to activate it again. I do not know what this is . Helllpppp!!!!
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
