Question about Toshiba Satellite A100-S8111TD Notebook
Toshiba SAatellite 100 Laptop
My USB ports are not accepting any USB drives or Printers. Looks like USB driver is not working. How to load USB driver alone without reformatting the harddisk.
  • shadowzone_0 Sep 06, 2008
    wer can i found the driver for
    *ethernet controller
    *mass storage controller
    *network controller
    pls help me i cant found their driver. for my satellite u400-10l
    thnx
  • 790 Answers
Just update the motherboard driver cd again and try or else indivisually install the drivers from printer drivers
Posted on Dec 23, 2007
Cannot load drivers for printing toshiba e-studio 167
if connect to usb cable, then u need to install usb driver b4 installing printer driver
May 26, 2011 | Toshiba E-Studio167 Copier
Toshiba Satellite P15 Series..disk drive not working
usually when your cd/dvd/burner drive no longer reads or properly write, (when you can't read the cd is when you put a cd in the tray but nothing comes up when you try to open the drive within the folder and you know that the cd is not blank. there's no actual way around the fact of drive may have died, usually this parts may be replaceable but replacing a disk drive in laptop is costly (no much the part which could run for 40-50 dollars but the actual labor replacing it (100-150 dollars), I suggest ebay for part search.
the actual solution is to: 1. accept the loss 2. use a portable cd/dvd/burner unit through usb ports.
unfortunately there's no bios o driver updates that can be suggested that may address the problem your are having but in case you may want to try an driver or bios update this is the website to go to http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=556036&rpn=PSP10U&modelFilter=P15-S470&selCategory=2756709&selFamily=1073768663
good luck!
Dec 17, 2010 | Toshiba Satellite P15-S470 (PSP10U-0GGPGR)...
Got old toshiba laptop to use as portable graphic runs windows98
Your old Toshiba laptop most likely does not have a firefly port.
The only way to use your firefly device on the Toshibe is to purchase a firefly PCMCIA adapter card and plug it into the Toshiba's PCMCIA slot and install the card driver.
Please click on this link for details and prices for this adapter :-
http://www.firewire-1394.com/cards-firewire-laptop-notebook-cardbus.htm
Jun 14, 2010 | Lexar FireFly 2GB USB 2.0 JumpDrive
The USB ports on my Toshiba A135 S2356 laptop are not working. I tried to use my printer and it says not connected. I bought a new cord but it still doesn't work. What should I do?
1. first check ur USB port using any other USB device, like pen drive, mouse, keyboard,etc.
if system detects that device, then ur USB port is OK!
2. if USB is OK, then the problem is with the 'Printer Driver' not the cord!
3. reinstall the printer driver!
4. update the driver!
5. if USB port is not working, then replace it!
if this helps, tell me.......
Dec 30, 2009 | Computers & Internet
I have a Toshiba HDD2190 C DC +5V 0.7A 40 GB Laptop harddisk which when I plugged into USB drive (by using a USB cable), WIndows XP Profesional detect it but I can't find it's Partitions in my computer. In...
In general, you need to install the correct drivers for the enclosure, not for the hard disk. Seeing as you have XP Pro, this is probably unnecessary though.
Also, 0.7A is 700 mA, and this exceeds the USB port maximum current which is 500 mA.
Most (not all!) laptop drives will run even if under a slight undercurrent, but this depends on USB port electronics and enclosure electronics.
Chances are that you won't be able to run the disk unless you plug it into an externally powered USB hub supplying at least 750 mA per port. The 100-500 mA supplied by your PC's USB port is enough to power the enclosure electronics and the host controller, but not enough to get the HD to spin properly. As a result, the HD can not be initialised and the enclosure will report an error.
Some hard disk enclosures come with a "USB Y Cable" or "double power cable" which joins two USB ports to get double the current, and can support HD up to 1.0A. If your enclosure comes with one of them, try that first.
Nov 02, 2009 | Toshiba (HDD2190-50PK) 30 GB Hard Drive
USB drive problem
I had a client with this same issue. However, her issue was that the top left USB port would only accept flash drives. Your external harddrive is probably not getting enough power from your USB port. Try using two USB ports (you can get a connector for this) to power up the external harddrive.
Apr 06, 2009 | HP Compaq nx6325 Notebook
USB drives Not working
this problem seems mostly with the usb mouse, the best solution is to plug the flash drive in one port and usb in other and restart the computer generally this always works but if it wont work then the best thing is i also did that, buy a 4-port usb hub and connect it with laptop and connect your usb mouse with this port not directly to your laptop and when you like to use your flash drive plug it in the laptop.
this is working with be perfectly and i hope it will do the same at your side.
Mar 23, 2009 | Toshiba Satellite A135-S2326 Notebook
Need a USB converter for some serial thing
dynex puts out a usb to serial adapter can be bought at best buy for somewhere around 15.00 you will need the drivers from the cd to make it work and then will probably have to set the port it is looking for that should be all you need
Dec 05, 2008 | Toshiba - Floppy disk drive - external -...
Toshiba Satellite A100-S8111TD Notebook Logo
150 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
