Past this ebay page into your browser and you will find what your seeking there. http://www.ebay.com/itm/Budlight-speaker-tower-/291365770582. It might be cheaper to buy a 2nd whole tower just 2 gain a remote?
take the battery cover off the wii controller and press the red button. then open the cover at the front of the wii and press the red button. do this when you are at the wii menu. this registeres the remote
go to "home". Press connection settings and hit reconnect. Then press 1 and 2 on the remote. Before that though, (if you have not done so) press the red button in the battery slot in te wii remote the same time as you press the red button near the SD slot. If you didn't understand, tell me!
Assure there is no nunchuck connected
Mario Kart Wii has its own Controller booter so;
Go into multiplayer (2, 3 or 4)
Then move to the right and select add Wii remote
Do as the instruction says
I found it odd too that the home overlay cant activate the controller on Mario Kart but that is how you do it.
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide,
that. explains step by step to fix the problem without any technical
knowledge. I hope this guide will solve your problem. It also gives
information on fixing many Wii Related Problems, so its a kind of Wii
Problems Reference Fix Guide.
that explains step by step to fix the problem without any technical
try this: open the cover of the wii's sd card slot. press the sync button for 15 secs. or so and all the sync data will be gone. then try to sync it regularly
