Question about ASUS P5GD1-VM Motherboard
Fails to boot, fans and lights on, no bios or anything
Computer gave a "cpu fan error press f1 to continue" error. replaced cpu fan computer booted up once fine, downloaded a windows update and then upon reboot, turned on (fand running) but will not boot
  • 788 Answers
My recommendations would be to remove all connections to the board.
Remove the CMOS battery.
Remove the CPU fan and CPU.
Look at the top of the CPU, if you have a crust over the top of the CPU, you will need to remove it to a clean surface.
Next, your CPU fan should be a 3 wire connection on the motherboard, within two inchs of the CPU holder.
After cleaning the CPU, re-inseart and apply a heat sink lub for good heat transfer.
Re-install CPU fan and plug in to board connection.
Re-install your CMOS battery and power up unit.
With the CMOS battery removed, the time and date will need to be reset.
Also, in the BIOS for that board, you should be able to see temps. and rpm readings. ??
Hope the CPU has not taken a dump on you.!
Before you plug in the drives and other devices, check temps. rpm and voltages.
Have fun, hope this has helped you.
Posted on Oct 06, 2009
  • 700 Answers
Please recheck your RAM card module, maybe it is moved when you change the fan. Unplug and replugged it. or better to clean its contact connector with a soft gel eraser to clean the dirt.
It is a common symptoms that RAM card failed to connect completely or faulty.
Goodluck hope this helps.
  • fougzki Oct 06, 2009
    Do this when unit is off and unplugged to wall socket.
How do I access the BIOS settings for the P5LP-LE motherboard. The startup key says to press F1, but pressing F1 does nothing.
The instructions say:
"Hold down the F1 key during the startup process and enter BIOS setup to re-enter/reset any custom BIOS settings." I would also try hitting the F1 key multiple times from the very turn on of the computer because the key may have to register at some point after turning on.
Try clearing the CMOS settings as explained on this page, it should clear out any passwords and will set the BIOS settings back to factory settings.
HP and Compaq Desktop PCs Motherboard Specifications P5LP LE Lithium
As for "The CPU fan runs normally on boot, but as soon as the Windows flash screen comes up, the CPU fan slows way down."
This is quite normal. On start-up the temperature of the CPU is not being read, when the flash screen comes up just happens to be the same time that the computer recognizes that the CPU is cold and doesn't need to be cooled.
On the "Then the installation program starts running and the CPU Fan speed starts fluctuating wildly from slow to extremely fast."
This could be normal as when files are read from a DVD the CPU doesn't work hard, but when it unpacks the files or does calculations it does work hard. Or it could be that the thermal paste between the CPU and the heat sink is not correct. Either dry , not making contact, or even too much. If the heat is not being transferred that would also explain the shut-down.
Nov 11, 2016 | Computers & Internet
I recently splurged and got a syx-1080, and the first thing that happened when i booted was 'CPU fan error press F1 to continue' i broke down and called support and they told me to shut off the fan...
was this a new unit under warranty
in which case a warranty repair would be in order
possible lack of thermal paste between the chip and the heat sink requiring the fan to run overtime or the fan 1 response
Apr 19, 2017 | Systemax (036052) PC Desktop
I HAVE NOT LOOKED INSIDE MY COMPUTER, BUT THE FAN BEGAN MAKING A LOT OF NOISE A MONTH AGO. TODAY THERE WAS NO NOISE AND A MESSAGE CAME ON MY SCREEN SAYING "FAN FAILURE- PRESS F1 TO CONTINUE. MAY I USE...
First, if the CPU fan is not spinning properly, you should NOT run the system. The fan needs to be replaced.
If the fan is running normally, you may boot by pressing F1.
Before replacing with a new fan, you can first try re-seating the plug for the fan in your computer. The fan's plug may have been bumped or loosed. Re-seat the plug located at J1F1 as shown in the picture below and be sure that it is properly connected.
Hope this helps.
Sep 28, 2010 | Computers & Internet
When booting up the screen displays FAN ERROR
Is the fun running? you can first confirm that before you alter anything in the Bios. touch on the fun air exit point you will feel it if its running.
Regards
May 05, 2010 | IBM ThinkPad T30 2366 Notebook
I installed a new WD hard drive and now upon boot
I would recommend you to change the CPU fan as it may nt be working fine and that should resolve the problem.
Mar 23, 2010 | Dell Dimension C521 PC Desktop
I have a Intel D865GLC and it will not boot! The green led light on the motherboard is lightning and the CPU-fan is rotating but there is no screen on the monitor and the computer is not boot A have tried...
First open cpu cabinet then pull cmos cell from motherbord for 10 minutes.
Refix RAM memory.
Reattch ATX power connector to motherbord.
Reattch power cable and SATA or ide cable to harddisk.
Clean dust from all parts of motherbord.
Open processor fan and processor.
Then reattch both.
Make sure motherbord is not ground with cabinet.
When you power up the computer press F1 or F2 or "del" key then enter in bios .
Make sure in bios your harddisk is detected.
If not then change SATA or IDE cable of harddisk.
Then check .Go to boot menu nof bios then set first boot device as your harddisk.Then save settings and exit.
Let me know if you need further assistance.Thanks.
Nov 13, 2009 | Intel D865GLCLK Motherboard
Amd phenom faulty
Replace cpu fan , failed cpu fan might have caused CPU stoped working. If you are sure about the CPU fails then replace the CPU. If the problem seems continues after that too, then PC might have failed to boot due to other reasons. What shows on the screen once you power on the computer? There could be , motherboard , or harddisk faults too. Try unplugging other parts and see if the computer boots from CD or USD flash or floppy drive!! Once you know that motherboard works then replace the CPU. There could be BIOS setup problem. Did you check the BIOS for harddisk is set properly.
Sep 17, 2009 | AMD 2.1GHz Phenom X3 Tri-Core 8450 AM2+...
Cpu fan
There are usually more than one place to plug in a CPU fan. Only one of them is actually for the CPU fan, and monitored by the system BIOS. Make sure your fan is plugged into the right connector.
Jul 18, 2009 | Zalman Tech (CNPS7700CU) CPU Fan
ASUS P5KPL-AM CPU fan connection.
You should still be able to connect the 3 pin connector of the fan to the 4 pin connector on the mobo, the keying tab is offset so that you cannot connect it to the wrong pins.
If you still don't want, or can't connect it there, simply go on the Bios (press delete after you turn on your computer) and you will find an option to monitor CPU fan speed.
If you need any more help, let me know
Alex
www.CAS411.com
Mar 28, 2009 | Computers & Internet
ASUS P5GD1-VM Motherboard Logo
453 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
