Question about Linksys Wireless-G WRT54G Router
How do i setup my router to shut down the udp port at a certain time....xbox live is what i'm trying to control
  • Linksys Master
  • 2,263 Answers
If you are trying to control the usage of X-box . Then you can set up access restriction policy on the router.
In this policy you can restrict a certain device from accessing the internet for a particular time.
If you have Linksys router,
open the set up interface of the router. You will find the access restriction tab at the Top.
Here you can set up access restriction policy on the router to block the IP address of the x-box to access the internet.
For more information about the routers Click Here
Posted on Oct 06, 2009
  • Prashant M
    Prashant M Dec 04, 2009
    Click Here for Easy Set up Guide for step by step instructions.
    It will guide you with simple steps to resolve the problem in your network.
  • 339 Answers
Your router does not have the advanced features that would be needed to do this. However, this can be controlled using parental controls on xbox live. Here is a link: http://www.xbox.com/en-US/support/familysettings/xbox360/familysettings-intro.htm
I have sky broadband and need to open up some ports as having trouble signing onto xbox live.
Xbox Live requires the following ports to be open:
  • Port 88 (UDP)
  • Port 3074 (UDP and TCP)
  • Port 53 (UDP and TCP) - should be open (used for DNS)
  • Port 80 (TCP) - this is open already for http traffic
Also - try to turn off NAT firewall off on your router. You can find more information here: Network ports used by Xbox Live
Feb 04, 2015 | Computers & Internet
Xbox360 live setup
You need to forward these ports on both your router, and computer aswell as firewall you got one of those.
  • Port 88 (UDP)
  • Port 80 (TCP)
You might aswell need to open 1863 (UDP and TCP) if you want to use video chat for the kinect.
Listed ports need to be forwarded when connecting to XBOX Live
A more detailed guide to setting it up is available here: http://support.xbox.com/en-us/xbox-360/networking/network-ports-used-xbox-live
Nov 15, 2013 | Netopia 2247NWG-VGx Wireless Router...
I got a Motorola wired modem and it dosn't let me play xbox live why?
you may have to open a port that you xbox can use to connect to xbox live
    • 1 Connect only your Xbox and computer to the Internet. Disconnect all other devices. This is done to easily determine the Xbox's IP address, which is used in the Port Forwarding process.
    • 2 Open the Windows Command Prompt from the Start Menu. Click "Start > Run...," then type in "cmd" and hit "OK."
    • 3 Enter "ipconfig" n the command prompt. A list of IP addresses pop ups. Write down the IP address of your computer.
    • 4 Open your router setup utility through a web browser. Use the given directions from your router manufacturer to do so. Generally, the configuration page is opened by inputting the router IP address into the URL in the following format: http://123.456.7.8/ (where the IP Address number is unique to the router manufacturer).
    • 5 Open the "DCHP Client List" section of the router setup utility. This lists the devices currently connected to the Internet through the router, which is your computer and Xbox. Write down your Xbox's IP address (in this case, the one that is not your computer's IP address).
    • 6 Navigate to the "Virtual Servers" or "Port Forwarding" menu in your router setup utility. Most manufacturers have a side menu on their router setup utility, which is generally a section under your "Firewall" settings.
    • 7 Input the following port numbers and your Xbox's IP address into your router's port forwarding configuration:
      TCP 80
      UDP 88
      UDP 3074
      TCP 3074
      UDP 53
      TCP 53
      Placing these numbers in the port forwarding menu opens up the required ports that your Xbox needs to connect to the Xbox LIVE network. Save this configuration.
    • 8 Start up Xbox LIVE to check your connection. If you have no problem connecting, then you have successfully forwarded the required ports.
Jun 04, 2011 | Video Game Consoles & Games
Im trying to connect to live and I connected to the internet but not xbox live
Xbox live requires some ports to be open on your router. Make sure the following ports are forwarded through your internet router to the IP address of the Xbox.
On Xbox's site below they have some instructions for the most common router manufacturers.
From the Xbox website: http://support.xbox.com/en-us/pages/xbox-360/troubleshoot/kb/xbox-kb.aspx?kbid=908874
Xbox LIVE requires the following ports to be open:
  • Port 88 (UDP)
  • Port 80 (TCP)
Note If you cannot chat with someone using Video Kinect, you might need to open port 1863 (UDP and TCP).
Mar 03, 2011 | Computers & Internet
My Zonet ZSR4134WE Wireless-N router doesn't connect to live. I've checked the MTU setting and everything. It works perfectly, until it gets to the "Xbox Live" part of the test, then it fails. Please help.
you need to open the ports on your router for xbox ports are TCP 88 UDP 88 UDP 3074 TCP 3074 UDP 53 TCP 53
first connect the xbox to the network and get the ip address (like 192.168.x.x) and then use the computer and login to router setup page and under firewall open these ports for the ip address of xbox . If you find a DMZ there , then enable it for XBOX ip address and reboot the router. ** imp: try to make a static ip address on xbox so when you restart the xbox teh ip address should not change -
to check what is the ip address provided from you router :- go command prompt (start ->run- > type cmd and hit enter) a black screen(command) type ipconfig you will find ip address of computer , so you can set the ip address of xbox like that -but just make the last number different (like ip address on computer 192.168.2.5 then make ip address of xbox to 192.168.2.6) perform this will help .. its all about the ports but be sure with ip address
Oct 01, 2010 | Zonet ZSR4134WE Wireless Router
Xbox nat setting
If you have a firewall or network hardware, such as a router, you might need to make a configuration change in order for your Xbox 360 console to communicate with Xbox LIVE. This configuration change is sometimes called “opening ports” or "port forwarding."
Xbox LIVE requires the following ports to be open: • TCP 80 • UDP 88 • UDP 3074 • TCP 3074 • UDP 53 • TCP 53
Mar 07, 2010 | Microsoft Xbox 360 Controller
Change NAT from strict to open
You need to do port forwarding on your router. First, you must setup a static IP address on your XBOX. Then You must open these ports on your router setup page using Port Forwarding feature. 80 TCP and UDP, 53 TCP and UDP, 3074 TCP and UDP.
Jun 01, 2009 | Zyxel P660HW-D1 Router
Belkin + xbox live problems
It's not the MTU problem any more. Its the router's firewall. To resolve it, you two steps to try. First, try to do port forwarding, you must forward the port for XBOX Live to the router's admin page. I believe the ports are 3074 TCP and UDP, 53 TCP and UDP, 88 TCP and UDP. If that doesn't work, try to just disable the router's firewall itself. One of these steps will surely fix your problem
May 06, 2009 | Computers & Internet
Belkin F5D9230-4 router with xbox live
the solution is as such, first log into your router by typing the routers IP (192.168.2.1) into your browser.
The first thing you want to do is set UPnP to be enabled.
Forget about the 88 UDP thing, it's bogus.
Just set the TCP and the UDP to 3074 in virtual server.
I swear to god it will work.
Mar 06, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Optimizing WGR614(v1) for xbox live
the normal port that requires opening in your router for xbox is TCP3074, you should just type the number in as if there are no options, although there should be, it may know that 3074 is a TCP port.
Sep 28, 2007 | NetGear WGR614 Wireless Router
Linksys Wireless-G WRT54G Router Logo
585 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
