Question about HP Compaq Presario V2000 Notebook
Intall the xp sp2 in hp dv 2519tu
I can not install the window xp sp2 in my 2519 notebook
How to instol xp sp2 in 2519tu hp leptop.
Posted on May 29, 2008
    Problem Solver:
  • 9 Answers
Try formating your hdd first before installing windows because you night don't have enough space on your hdd or you hdd is faulty.
Posted on Jan 28, 2008
    Scholar:
  • 112 Answers
Service Pack 2 will not install on XP unless your XP is a legal copy or an OEM. First make sure that your installation is legal. Try and install SP2 from the Microsoft Update Icon on the Start Menu, from here it will check the legality of your installation of XP. Do you have the orginal disk or a restore disk? BPCS
Posted on Dec 24, 2007
    Sniper:
  • 56 Answers
What exact error do you get ?
My computer compaq presario 2816 notebook, in it windows xp home edition sp2 is installed after purchasing. Due to problem person who repair it installed proff. edition sp2. Now in this every settings are...
go to campaq (hp) site and download the drivers you need. Just follow the instruction where as laptop selection is concerned and download the relevant drivers.
As for home edition, you will have to get that cd or download it from various sites, even torrents and burn it to disc.
Best Regards
Oct 27, 2013 | HQRP Kensington 120W AC Adapter...
Audio & video is not working
You downgrade from Vista to XP right?
Installing your audio drivers on XP:- ***important
You have to install the "Microsoft Universal Audio Architecture (UAA) Bus Driver for High Definition Audio (sp33867)" first, before intalling the audio drivers Conexant CX20549-12 Audio Driver for Microsoft Windows XP (sp41836.exe).
If you reverse the procedure your audio won't work.
Hope it helps.
Jul 21, 2010 | Microsoft Windows XP Professional SP2
Windows os
Its true. the Bios or HDD driver wont allow you to install Win XP on it.. This BIOS is compatible with only Win Vista. The only easy way to do it is by creating 2 partitions while installing vista. once vista is installed- install XP with Dual boot and than format the vista partition.
Feb 04, 2009 | HP Compaq nc6000 Notebook
XP on HP Pavilion dv2000
yes
because it's using an AHCI  SATA driver
there 2 ways to install XP on your laptop
  1. If you own an external floppy disk. You can insert the driver before the installation begin. the setup will ask you to insert third party driver by pressing F6 at the first of installation. Press F6 then insert your SATA driver. choose it. then setup will detect your hdd. you can download the SATA driver form here:http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/HP-Pavilion-dv2054ea-SATA-Driver-550.shtml
  2. It's very hard to find an external floppy drive today, unless if you are an OEM or retailler. second way is you can insert the driver to XP installation CD, but it's very complicated. Or you can download a XP installation CD with sata driver here:http://fenopy.com/torrent/Windows_xp_sp3_5512_cdr_october_2008_with__sata_raid_/MTU2MTEzMA==/index.html
  1.
Jan 24, 2009 | HP Pavilion dv2000t Notebook
i think you have a sata hard disk drive.so go to cmos setup and in the cmos setup and please disable the sata drive there
Jan 04, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
For the laptop with no hard drive detected, this is most likely because Windows XP does not recognize SATA drives by default, which the laptop most likely has. To solve this, you will need to enter the BIOS setup utility (most likely Delete or F1 on startup). From there, you will need to change the drive mode to Compatibility mode. I'm not sure where this would be, but if you check in your laptop manual, you can probably find this somewhere.
For the 2519TU, download and install this for the LAN driver: ftp://ftp.hp.com/pub/softpaq/sp30001-30500/sp30264.exe it should work just fine.
Dec 23, 2008 | HP Pavilion dv9000z Notebook
First of all, this Notebook is installed with SATA Hard Drive and the drivers for the SATA Hard Drive will not be available with retail versions of Windows XP by default.
I recommend you to try using different OEM versions of XP to install in your Notebook which should work.
Since the Notebook is preinstalled with Windows Vista, the XP Drivers for this Notebook are not directly available from HP.
I had searched some for you which should work.
Download the Drivers one after the other and save them with the name along with the Softpaq Number like the example given below :
Microsoft UAA_33566.exe
So that it will be easier for you to save them and identify.
Save the drivers in one location in the Notebook and double click them once the download is completed.
Make sure that you install the Microsoft UAA Drivers before installing the Audio or Modem Drivers.
Make sure that you install them in the same order I had provided them below :
You need to download the Intel Chipset Drivers for your Notebook from the link below :
http://downloadmirror.intel.com/16023/a08/infinst_autol.exe
Microsoft Universal Audio Architecture(UAA) drivers for High Definition audio :
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33566.exe
Conexant High Definition(HD) audio :
ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34200.exe
As the Notebook is installed with Intel graphic Card, you need to download the Drivers for the same from the link below :
http://downloadmirror.intel.com/16944/a08/win2k_xp14363.exe
Download the Ricoh 5-in-one Card Reader Driver from the link below :
ftp://ftp.hp.com/pub/softpaq/sp37501-38000/sp37712.exe
Download Intel PRO/Wireless Drivers from the below weblink:
ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34489.exe
As I am not sure whether your Notebook is installed with Intel or Realtek Ethernet card, I am providing both the drivers:
Intel Ethernet Drivers :
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33574.exe
Realtek Ethernet Drivers :
http://drivers.softpedia.com/progDownload/Realtek-RTLRTLRTLRTL-Driver--WHQL-Download-33009.html
You can also try downloading the Marvel Youcon Ethernet Drivers if any of the above provided drivers did not work :
ftp://ftp.hp.com/pub/softlib/software10/COL24713/gs-63707-1/Marvell_Yukon_LAN_Driver_6.36.0.0.exe
Downlaod Conexant HDAUDIO Soft Data Fax Modem drivers from the below weblink :
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33890.exe
Download the HP Quick Launch Buttons drives from the below weblink:
ftp://ftp.hp.com/pub/softpaq/sp38501-39000/sp38688.exe
Download the HP Pavilion Webcam Driver from the below weblink:
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33544.exe
Download the Alps Touchpad driver from the below weblink:
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33751.exe
Finger Print Reader Driver :
ftp://ftp.hp.com/pub/softpaq/sp32501-33000/sp32869.exe
Hope these helps...
Oct 03, 2008 | HP Pavilion dv2000t Notebook
Keyboard Not responding
Firstly your keyboard and sound driver may need to be re-installed using your original HP installation/driver disc or from the HP web site. http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=395749&lang=en&cc=us&prodTypeId=321957&prodSeriesId=395747&taskId=135 Windows XP has probably loaded generic drivers when installed which are'nt always compatable, especially for assigned keys. Also go to your speaker icon on the right corner of your task bar(right click then properties) and check that the volume cursors are set correctly.
Dec 11, 2006 | HP Business Notebook NX9110 Notebook
HP Compaq Presario V2000 Notebook Logo
175 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
