Question about IBM (02R4087) Motherboard
Where the front panel connector located? - IBM (02R4087) Motherboard
  • David Leo
    David Leo May 11, 2010
    Please give me the make and model number from your motherboard.
  • Vladimir Zavodny
    Vladimir Zavodny May 11, 2010
    please send me your model and version number, it is hard to tell from a small picture
I need a wiring manual for a g31t-lm2 motherboard...
Hello here is the drivers site:
http://support.lenovo.com/en_US/downloads/default.page?
Here is the user guide:
http://support.lenovo.com/en_US/guides-and-manuals/default.page?selector=expand
The front panel connector ( F panel) looks like this:
This is located in the down right corner.
The usb connectors look like this:
In your another case, there should be connectors for front usb and audio, what it goes for should be printed in on the connector.
Basicly this can not be connected wrong.
Good luck
Jan 26, 2013 | Lenovo g31t-lm2 - System Board
Need a wiring diagram for a rs780m03g1
http://www.ebay.com/itm/FOXCONN-RS780M03G1-8EKRS2HM0D-DDR2-HDMI-PCI-MOTHERBOARD-/250896178535
1) http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rnv.shtml
2) Product Views;
http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rtc.shtml
B - Processor Core Power Connector;
is the connector on the motherboard for the 4-pin ATX +12 Volt power cable.
Located close the motherboard top edge, left side. Yellowish 4-socket hole square connector.
General example of connector, and power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
2) D - CPU Fan Connector,
The Processor fan connector is white in color, 3-pin, and above the processor socket.
3) F - Main Power Connector,
The 24-pin ATX main power cable connector on the motherboard, is to the Right of the Ram Memory slots
4) N - Front Audio Connector, (Front Panel audio ports)
Red in color, 9-pin header, and is located below the white No.2 PCI slot, at the bottom of the motherboard.
5) P - System Fan Connector, (System Fan = Computer case fan)
White in color, 3-pin header, located below the No.2 PCI slot, at the bottom of the motherboard.
6) Q - IEEE 1394 Connector,
For the front panel Firewire (1394) ports.
Black in color, 9-pin header, located at the bottom right corner, of the white No.2 PCI slot
7) R - USB Connectors, ( Front Panel USB ports )
F_USB 1 through F_USB4.
Located at the bottom of the motherboard, and these four separate headers support TWO USB ports each. Yellow in color.
8) S - Front Panel Connector,
located at Bottom/Right corner of motherboard.
Pin 9 is N/C also.
Not Connected. Used for +5 Volt power for the factory.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 27, 2012 | Gateway E-4300 PC Desktop
How to Change an Ignition Lock on a 2004 Buick Rendezvous.
Please let me know if you have questions, and thanks for using FixYa.
Removal & Installation
  1. Disconnect the battery negative cable, as outlined in the Chassis Electrical Section.
  2. Disable the Inflatable Restraint (SIR) system. (see procedure below)
  3. Remove the steering wheel.
  4. Remove the tilt lever close out plate.
  5. Remove the retaining screw from the lower steering column trim covers.
  6. Tilt the trim cover down and slide rearward in order to disengage the locking tabs.
  7. Remove the lower steering column trim covers.
  8. Remove the retaining screws from the upper steering column trim cover.
    Fig. Lift the trim cover in order to gain access to the lock cylinder access hole.
  9. Lift the trim cover in order to gain access to the lock cylinder access hole.
  10. Insert the Snap-On A173A bent-tip awl or equivalent, with a 3/32 in (2.5mm) tip, and 3/4 in (20mm) in length, into the access hole of the ignition lock cylinder.
  11. Turn the ignition lock cylinder to START .
  12. Use the bent tip in order to push down on the ignition lock cylinder retainer.
  13. Release the ignition lock cylinder to the RUN position.
    Fig. Remove the ignition lock cylinder from the lock cylinder case.
  14. Remove the ignition lock cylinder from the lock cylinder case.
To install:
  1. Insert the ignition lock cylinder through the trim cover in the upper steering column.
  2. Align the lock cylinder retaining tab and the position tab with the slots in the lock housing.
  3. Completely push the lock cylinder into the lock housing.
    NOTE Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  4. Install the retaining screws to the upper steering trim cover and tighten the screws to 31 inch lbs. (3.5 Nm).
  5. Match the tab slots on the lower trim cover with the locking tabs on the upper trim cover.
  6. Tilt the lower trim cover up and slide the lower trim cover until the locking tabs snap into the tab slots.
  7. Install the lower trim cover screws to the steering column and tighten the screws to 13 inch lbs. (1.5 Nm).
  8. Install the tilt lever close out plate.
  9. Install the steering wheel.
  10. Enable the SIR system, as outlined in the Chassis Electrical Section.
  11. Connect the battery negative cable.
Disarming the SIR System
Print
  1. Turn the wheels to the straight-ahead position, then turn the ignition switch to LOCK .
  2. Remove the console accessory wiring junction block access hole cover.
  3. Remove the "AIR BAG" or "SIR" fuse from the block, as applicable.
  4. Remove the left-hand sound insulator, for access to the SIR wiring harness.
    Fig. Driver-s side air bag connector location
    Fig. Passenger-s side air bag connector location
    Fig. Side air bag connector location
  5. Remove the Connector Position Assurance (CPA) device, then disengage the yellow 2-way connector at the base of the steering column.
  6. Remove the right hand insulator panel.
  7. Remove the CPA from the inflatable restraint instrument panel module connector located behind the RH insulator panel.
  8. Disconnect the instrument panel module connector
  9. If equipped with side air bags, remove the CPA from the inflatable restraint side impact module-left front connector located under the driver seat.
  10. Disconnect the side impact module-left front connector.
  11. Remove the CPA from the inflatable restraint side impact module-right front connector located under the front passenger seat.
  12. Disconnect the side impact module-right front connector.
    NOTE With the fuse removed, the AIR BAG or SIR light will illuminate if the ignition switch is turned ON at any time. This is normal and does not indicate a problem when the system is disarmed.
Arming The SIR System
  1. Be sure the ignition is in the LOCK position.
  2. Connect the inflatable restraint side impact module-right front connector located under the front passenger seat.
  3. Install the CPA to the side impact module-right front connector.
  4. Connect the inflatable restraint side impact module-left front connector located under the driver seat.
  5. Install the CPA to the side impact module-left front connector.
  6. Engage the yellow SIR connector, then secure using the CPA device for both the drivers and passenger sides.
  7. Install the sound insulator panel.
  8. Install the SIR system fuse to the fuse block.
  9. Turn the ignition switch to the ON position and verify that the AIR BAG indicator light flashes 7 times, then extinguishes. If it does not go out, troubleshoot the SIR system fault.
  10. Install the instrument panel lower extension.
Jun 30, 2011 | 2004 Buick Rendezvous
Were does the LH mirror on a 2011 f-250 connect. Removed mirror but disconnect is located some were in door or body. need to know what needs to be removed to gain access
  1. Remove the front door trim panel.
  1. Position aside the front door watershield to gain access to the exterior rear view mirror control switch electrical connector.
4.Disconnect the exterior rear view mirror control switch electrical connector
as you see you have to remove the door panel to have access to the electrical connector in case that you dont know how to do it here are the instructions
NOTE: Left front door trim panel shown, right front door trim panel similar.
  1. Remove the sail panel.
    • If equipped, disconnect the electrical connector
  2. If equipped, lift up and remove the exterior rear view mirror control switch panel.
    • Disconnect the electrical connector.
  1. If equipped, lift up and remove the window control switch panel.
  1. If equipped, remove the window regulator handle.
    1. Position the window regulator handle cover aside.
    1. Remove the window regulator handle screw and regulator handle
5.Remove the door trim panel center screw cover
6.Remove the 2 door trim panel center screws
7.Remove the 2 door trim panel lower screws
  1. NOTICE: Do not pull directly outward on front door trim panel as damage will occur.
    • Lift upward to remove the front door trim panel.
  1. NOTICE: Insert the lower panel tabs first or they can break when installing the front door trim panel.
    To install, reverse the removal procedure
Feb 20, 2011 | 2011 Ford F-250 Super Duty
Hello i need to know how to reconnect the computer case wires to a sr1703wm compaq motherboard
Hello.
The Compaq Presario SR1703WM desktop computer, uses an Asus A9AE-LE motherboard.
HP/Compaq's name is AmberineM - GL6E
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00496280&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=1815742
1) I would like to start with the Front Panel wires.
The Front panel, is the plastic front on your computer tower, where the Power On button, Power On LED, and so on is located.
The Front Panel header is the connector on the motherboard, where the cables, (Wires), from the Front Panel connect to.
Looking at the HP Support link above, I would like you to scroll down the page to the illustration of the motherboard, and the photo of the motherboard under the illustration.
Looking at the illustration observe the bottom Right corner.
F_PANEL1 indicates the Front Panel header.
Note there are 4 pins going across the Top, and 5 pins going across the Bottom.
Looking inside your computer, the motherboard will be located in a different position, compared to the illustration.
The Front Panel header will be located Vertically, (Up, and down)
Note that there is a twisted pair of Black, and Red wires.
These wires form the Power On cable.
They come directly from the Power on switch.
There is a twisted pair of Yellow, and Black wires.
These wires form the Harddrive Activity LED light cable.
(HDD)
When the harddrive is active, this LED flashes.
There is a twisted pair of Green, and Black wires.
These wires form the Power On LED light cable.
The wires, (Cables), should be in one Black connector.
Looking at the Front Panel header in your computer, align the Black plastic connector's socket holes, with the pins sticking up out of the Front Panel header, on the motherboard.
Note that the Front Panel header is rectangular in shape. There is 1 pin missing.
The Black connector coming from the Front Panel of the computer, has one socket hole blocked off, to match.
Align the four socket holes in the Black connector, to match the 4 pins sticking up out of the Front Panel header, on the motherboard.
The other 5 socket holes in the Black connector, will match up to the 5 pins sticking up, automatically.
Use care, and you may need a bright light to assist.
These pins can be bent quite easily.
(Also watch your fingers, as the ends of the pins are S-H-A-R-P!)
2) Where it states CLRTC (CLPWD under it), is the Clear CMOS jumper.
Suggest you leave it alone.
3) Where it states F_ USB1, and F_USB2, is where the USB cables from the front of the computer connect to.
(The USB ports on the front of the computer's Front Panel.
F_USB1, and F_USB2 headers on the motherboard, are shown on the illustration to the Left, of the Front Panel header. F_PANEL1)
The plastic connector on a USB cable coming from the Front Panel, has an orientation just like the Front Panel header cable does.
There is 1 pin missing on the USB header on the motherboard.
There is a blocked socket hole in the USB cable's connector.
Align the connector to match the pins.
Doesn't matter which USB cable from the Front Panel, that you connect to the USB headers on the motherboard.
BIOS will find them, and assign an IRQ to each, once you turn the computer on.
All you will see at a first glance is a series of thick Gray insulated cables, coming from the Front Panel of your computer.
If you follow the cables by eye, you can see where the USB cables are connected to the back of the USB ports, on the Front Panel.
You may, or may not, have to remove the Front Panel to see more clearly.
Computer case open, look inside towards the Front Panel.
There is a Green plastic tab towards the Top.
This locking tab is depressed Towards the Inside of the computer, to START to unlock the Front Panel.
Towards the bottom in the same plane, is a Black locking tab. This tab is pulled Towards the Outside of the computer.
There is another Black plastic tab on the opposite side.
At the Bottom are two more Black plastic locking tabs. These are depressed down, towards the Bottom of the computer case.
One on one side, one on the opposite side.
Start by depressing the plastic Green tab, and gently easing the Top of the Front Panel, slightly out.
Then go to the two Black plastic locking tabs located towards the Middle, and depress them.
Ease the top of the Front Panel out a little more.
Finally go to the two Black plastic locking tabs located at the Bottom, and depress them.
Ease the Front Panel off.
(NOTE*
Your computer's Front Panel may not have locking tabs located at the bottom.
Just locking tabs located up from the bottom, more towards the middle)
It's no picnic for your first time, but once you have done it, it becomes easy. (Ummm, Easier!)
4) The Firewire (a1394) cable on the Front Panel, connects to the F_1394 header on the motherboard.
In the motherboard illustration the F_1394 header is located to the Left, of PCI2
Need any further cable connections, post in a Comment.
Aug 14, 2010 | Compaq Presario SR1703WM PC Desktop
HOW TO CONNECT FRONT AUDIO PINS
the connector is marked F_audio and it is located directly behind the rear facing audio jacks. should be only one plug either marked "hd audio" OR "ac97 audio". some cases are setup for either, but you only need one of them depending on what your motherboard supports.
11) F_AUDIO (Front Audio Connector)
This connector supports either HD (High Definition) or AC97 front panel audio module. If you wish
to use the front audio function, connect the front panel audio module to this connector. Check the pin
assignments carefully while you connect the front panel audio module. Incorrect connection
between the module and connector will make the audio device unable to work or even damage it.
For optional front panel audio module, please contact your chassis manufacturer.
By default, the audio driver is configured to support HD Audio. To connect an AC97 front panel
audio module to this connector, please refer to the instructions on page 72 about the software
settings.
Pin No. Definition
1 MIC
2 GND
3 MIC Power
4 NC
5 Line Out (R)
6 NC
7 NC
8 No Pin
9 Line Out (L)
10 NC
AC'97 Audio:
Pin No. Definition
1 MIC2_L
2 GND
3 MIC2_R
4 -ACZ_DET
5 LINE2_R
6 FSENSE1
7 FAUDIO_JD
8 No Pin
9 LINE2_L
10 FSENSE2
Mar 27, 2010 | Gigabyte GA-945GM-S2 (0818313003065)...
I have 3 wires on my pc and i dont know where to connect them on my motherbaord - the wires have writen on them "HDD LED" "PWR LED" "PWR S/W" can any1 help me?
Hi Dan,
The wires are from the front panel. HDD LED which causes an led (usually red) light to turn on when the Hard Drive is active. The PWR LED turns on an LED light (usually green) when you turn on your computer. The PWR S/W turns on your computer when you press the on button of your computer. The front panel connector riser is usually located on the bottom right of your computer. They fit on little pins. Unfortunately there is no standard, so connections vary. Sometimes the pins are labeled on the motherboard. . Check your manual. For more info do a google search for "Motherboard front panel connectors". Hank
Mar 12, 2010 | Intel Computers & Internet
How to connect the front panel sould device?
Do you mean speaker or front panel audio? The front panel audio connector is located at the rear of the board, behind the PCI connectors - the speaker connections are in the panel connector block (2x10 pin header) located at the front left of the board.
With the board in it's normal position, the speaker pins are on the right hand side of that block, on the pin nearest the front and the one 3 positions behind that
<back of board>
| HD LED + | | Power LED +
| HD LED - | |
| | | Power LED -
| Power SW | |
| Power SW | | Speaker
| Reset SW | |
| Reset SW | | Speaker
Front of board
Jul 03, 2009 | ASUS K8V-MX Motherboard
Where to hookup front panel (PIII-3754LMR - AMPTRON)
Front Panel Connector The front panel header is where the connectors of hard disk drive activity lights, case speaker, reset button, power on/off button, computer power on light, and key lock, are connected to make them function smoothly. In the past days, users always have difficulty connecting the front panel due to a lack of standard location on the motherboard. Today, AOpen integrated all these disorder but essential front panel connectors into one 20-pin connector for easy usage. Connecting the front panel would no longer be the headache of installing motherboard anymore. Below is a view of this user-friendly front panel connector of AOpen motherboard.
please rate this post.
or donate on madridtelecom@gmail.com
Feb 08, 2009 | Intel Motherboard
Where is the FP1 connector on the Foxconn 945G7MA-8KS2?
Hi Sean, FP1 front case connector is located below the battery, bottom right hand corner.
To download you're manual click on this link.
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=945G7MA-8KS2&TypeID=en-us0000001
Motherboard layout is on Pg. 5
Front Panel Connector: FP1
(Please refer to the 18th item of motherboard layout.)
This motherboard includes one connector for connecting
the front panel switch and LED indicators.
Close up of FP1 found on pg. 15
If I can be of more service, just post & let me know how thing go.
Enjoy!
Mike
Apr 29, 2008 | Foxconn (945G7MA-8KS2) Motherboard
IBM (02R4087) Motherboard Logo
83 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
