Question about Refrigerators
Frigidair icebox leaks water...condensation pan is dry Model # FP1-19THL-1
  • Refrigerators Master
  • 1,606 Answers
Remove the food and ice maker (if equipped ) from the freezer , and remove the rear inside freezer panel . Below the coils , there is a drain pan which is probably iced over . Start in the middle with a hair dryer , and defrost until you see the drain hole . Use hot water to help defrost the hole . Once defrosted , insert a small hose , to blow any unseen debris , thru the drain line , and into the drain pan .
To permanently "fix" this problem , after defrosting the drain hole , insert an aluminum solid wire ( no insulation ) , or a copper ground wire , into the hole as far as possible , without force , and wrap the black rod above the hole (defrost heater) , about 1-2 turns with the other end of the wire .
When the refrig goes into defrost , the heat will transfer to this wire , keeping the defrost drain from being frozen up again .
Posted on Oct 06, 2009
Water leaking under zanuzzi frost free larder freezer
. There is a condensate pan under the freezer side. When the defrost cycle completes it can get quite full. Usually the water dries up with time. If your water filter is down in the toe kick grille, it may be lealing into this pan.
Oct 30, 2017 | Frost Refrigerators
Model 1068630583. Why is it leaking water on the floor?
Remove the floor grille and check drip pan if full carefully remove and drain water if pan is dry [pan is drip tray from auto defrost water goes to pan than usually dissipates ] if dry look to back at water line for damaged or leaking line or valve
Aug 11, 2015 | Kenmore Refrigerators
Why does kenmore side by side model 596.50004100 leak water from bottom?
1. there is a condensation pan under refrigerators, pull front bottom grill off & you should see pan. if pan is full it will overflow, pull forward to remove & empty. also check to see if something spilled in bottom of fridge & is running into drain hole into pan. most of the time condensation is so slow that it will evaporate before the pan fills up, but I've had them fill up on me in the past, not too often though.
2. if fridge is equipped with ice maker & clod water dispenser, connections on bottom back side could be leaking ( not likely, unless they have been disturbed).
there is not much else that it could be unless it is not the fridge & is coming from some where else & running under the fridge.
Oct 09, 2014 | Refrigerators
Whirlpool side by side full drip pan
The condenser fan should be running whenever the compresser is running. With all of that condensate, I would look at your door gaskets. If they are leaking and you are in a high humidity area you will produce more condensate than what the pan can Handel. Then again. If the compresser is running the heat from the discharge line should evaporate the water with ease. I would look at the seals possibly leaking and ignore the full drain pan.
Sep 08, 2012 | Whirlpool Refrigerators
Model # GSH22VGPC CC water leak
Evaporator condensate should go to pan for evaporation. If the amount exceeds pan capacity during defrost cycle it could overflow to the floor.
Sep 03, 2017 | GE Refrigerators
My handler is leaking. The drip pan has a little water in it, I see a slow drip outside during operation. Near the blower water is coming out of one of the air ducts.
Hello, most likely you have a clogged condensate drain or a cracked or leaking condensate pan. First use a wet/dry vac on the outlet of the drain line, this will usually unclog the line. If the line appears to be clean then the pan will have to be replaced.
Sep 27, 2011 | Heating & Cooling
Water is dripping from the freezer compartment into the fridge compartment.
WATER LEAKING FROM REFRIGERATOR OR INSIDE THE FREEZER OR FRESH FOOD SECTION
You have a blockage in your condensate defrost line or the pipe that fill the tray below the refrigerator is missing the condensate collector pan that uses the heat from the fan to evaporate the condensate back into the air inside your home. Or this sounds like you have a blockage in the drain tube, remove panel back of freezer...you may see ice build-up, melt ice with hair dryer, you will see a pan below evaporator, melt ice in pan, dry water up in pan with towel, now you should see drain hole in pan that leads to drain tube, pour some hot water in pan, wait a couple minutes, wipe up water and repeat this step 2-3 times, once you have done this use a wet and dry vacuum cleaner to vacuum out the gunk or blockage in the drain line. Now it is cleaned out! Put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. Good luck! PS Please don't forget to rate my solution Thanks! Sea Breeze One moment I will send you to a ink and scroll down the page and read and watch movie Click Here=> Sea Breeze Tip's
Mar 13, 2010 | Whirlpool Refrigerators
Bottom of freezer in the side by side builds up with ice, then water leaks on to the floor
We have a defrosst drain problem we will need to work on, WATER LEAKING FROM REFRIGERATOR OR INSIDE THE FREEZER OR FRESH FOOD SECTION
Feb 06, 2010 | Maytag Ice2O 24.9 Cu. Ft. Side-by-Side...
Refrigerator Leaking from underneath
OK I will help but I think if you could find the model number and on some they always seem to be worn off or hard to see, I'm trying to picture in my mind if you have a water and ice dispenser in a side by side or jut a freezer over the fresh food compartment. If you have no water and ice then something like a leak has happened to de condensate collector pan or the drain tube has missed the pan. Without water from another source something is wrong with the pan or the pipe leading to the pan. If you have water and Ice Maker it;s possible you have sprung a leak in the water lines leading to the dispenser near the floor and behind the kick plate. The water lines on those models enter the bottom hinge of the door.Best way to see what is happening with the condensate pan is unplug and pull refrigerator away from wall and remove cover over compressor and condenser area to examine the pan closely. See if you can locate that model number and I will return with some helpful links, Thanks, Sea Breeze
Jan 10, 2010 | Refrigerators
Air Conditioner (RUUD model: UBHC-14J06NFD) is leaking water from bottom. It is causing a major puddle in Air Intake area.
The condensate drain line/pan is clogged causing the condensation to overflow the pan.
The easy way to fix that is attatch a powerfull wet/dry shop vac to the end of the drain line and such out whatever is causiing the clog. Also take off the panel to the evaporator coil and clean out the pan with the shop vac.
To double check that the clog has been removed, pour a gallon or two of water into the pan and ensure that it is draining properly.
Oct 11, 2009 | Heating & Cooling
Refrigerators Logo
166 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
