Question about Mitsubishi WD-52525 52" Rear Projection HDTV
My Mitsubishi Rear Projection 52" TV will not turn on. The repair service thinks a fuse has blown. Yes, it is an old TV, but this repair was made once. When I unplug and then plug the TV back in the outlet, I can hear the set engage power in the back. But when I try to turn on the set, it clicks on and then off within a second. Is this a simple repair? - as I cannot find anyone to repair it at our house.
techman
  • 3130 Answers
SOURCE: Mitsubishi VS-5041 (TV turns on but no pic or sound)
Your problem is one and or 2 differant problems. The power regulator could have went bad because of the convergence IC have shorted. Seen this a thousand(easy that!)Times. All parts in this set are soldered in and are not user serviceable. look in your owners manual or call 800-332-2119 to get an authorized servicer to come and look at your problem . I wish i could tell you what to replace but theres the Extreme Hi voltage inside these sets even when they are not plugged in .. Good Luck
Posted on Jun 16, 2006
  • 109 Answers
SOURCE: 52" mitsubishi rear projection tv model vs6051 sound no picture
Not exactly familiar with this model but sounds like the projector lamp is burned out. Hopefully it's a replaceable type. Try calling these people - http://www.purelandsupply.com
Posted on Mar 29, 2009
rulds2008
  • 3866 Answers
SOURCE: My 10 year old 55 inch Mitsubishi rear projection shuts off.
The main board/switch is worn to the point it will not work anymore after a while, I been in the business for years, These are wonderful TV's, yes there are replacement parts but a quick fix your looking for here will be unsuccessful this is the reason I am providing my advice and take a chance on the rating your going to give me. Try www.ebay.com look for people that is saling parts for these TV's.
Posted on May 03, 2009
Sparko1
  • 167 Answers
SOURCE: Mitsubishi WS-65313 65 in. TV will no longer power up.
You should call a good TV Tech. This problem cannot be solved by a consumer. The one thing you might try is to unplug it from the wall for a few minutes and then try it again.
Posted on Aug 03, 2009
SOURCE: Have a Mitsubishi WD-62327 DLP projection TV. It
if you hold the input and menu button for 5 seconds it will flash you a code 36 is the lamp fan / dmd fan has gone bad. pretty common. not hard to change but will cost 100 in parts and whatever labor may be
Posted on Feb 24, 2010
My 52" Mitsubitshi Diamond series will not turn on. It has a blinking green light that says timer underneath and the system reset button had not effect either. The TV is only six years old and rarely...
Probably a blown pico fuse on the circuit board, convergence amplifier issue, or blown HOT transistor. Could also be a solder connection on the pc board other bad component. Count the blinks and note any pauses in blinking. This could be a trouble code. Type into google your tv and model number and the words "troublecode ## " if you had one or "steady blinking green light" if it just continuously blinks wit no pauses. See where that takes you... Hope that helps some.
Jan 08, 2010 | Mitsubishi WD-52525 52" Rear Projection...
HD 1080 Series (WD-55809) - Color convergence issue
I don't know of illustrated instructions but I can provide you with the service manual for your TV. It does have illustrations of disassembly and components as well as schematics. Your set very likely needs new convergence IC chips. This is a common problem with all projection TVs. The repair is not expensive ($60-75 in parts)  but does involve unsoldering and removing the old chips and soldering in new ones. Some times there are some fuses that need to be replaced as well. If you want the manual provide me with an email address.
Dec 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I had a power outage and now the tv will not power on. This is for a 55" Mitsubishi WS-55511. no green blinking lights.
You may have a blown fuse. Unplug the TV and remove the back. Look for a small fuse near where the power cord goes in.
If it is blown that may be the problem.
Use a magnifying glass to read the AMP rating.
replace the fuse and plug it in. If the fuse blows again you need expert repair services.
If the fuse doesn't blow then try to turn it on.
If it turns on then check the operation of the TV.
If the fuse blows again or the TV won't work correctly then you need expert repair service to fix your TV.
You may be able to have your household insurance pay if it is damaged by lightening or a power surge.
Lee
May 02, 2009 | Mitsubishi WS-55511 55" Rear Projection...
This tv is working when it wants to?
You may have the wrong lamp. The lamp assembly is 915P020A10.
Where do you live?
Ltyler123@yahoo.com
Mar 07, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Shaky distorted picture first 5 minutes when tv turned on.
Those have a problem with the capacitors going bad in power supply. Yes, it's worth having checked out because a GOOD shop will be able to fix the problem and not have to change a board. Very common problem with these sets. Mine did the same thing until I fixed it. Just do your homework when finding a shop. Call around and talk to other people in the area to see who they use etc.. Good luck. Could be a very simple repair. Have it checked.
Dec 03, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Rca tv won't power on
it may need a Flyback Transformer or a burnt capasitor and resistors. there are many posts with this same problem. Some a little different. Check the fuse just inside where the power supply cord goes in . if the fuse is blown you will have to find the reason it burned . But maybe you will be lucky and replace the fuse. And it will turn on. but I think that only a TV technician can fix the problem.I have a background on TV repair and I think it's the Flyback transformer. sometimes you canresolder them and they stay.
Nov 23, 2008 | RCA P52926 52" Rear Projection Television
Wd-52725 mitsubishi please help
Good day, anniedooday;
Your TV's color wheel is bad. Call an authorized service dealer to repair this. It's not an easy job.
Good Luck, big IRISH.
Jul 14, 2008 | Mitsubishi WD-52725 52". Rear Projection...
RCA 52 PROJECTION TV MODEL P52151WK
No , if fuse was blown you would not get the popping. How old is unit ? It sounds like your high volt splitter. common problem with rca. repair should not cost more than 250.00. you will want to have chassis number  and manu date for help
www.classtorations.com
Jun 04, 2008 | RCA P52937 52" Rear Projection Television
Mitsubishi YS-5075
yes, this sounds like a fuse blown or open. What model is this a VS or YS?
Mar 10, 2008 | Mitsubishi VS-50705 50" Rear Projection...
No picture , only sound
Yes, first do self test here in threads or at ctechnicians.com
Dec 28, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
69 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
