Question about Victory Freezer Refrigeration ''Value'' Series 45.4 cu. ft Solid Two Section, Four Half-Door Reach-In Freez...
Aquired 3 door victory in existing bldg. Service
Aquired 3 door victory in existing bldg. Service tech came out and serviced, cleaned machine. Freezer working great for 1 month. Now cannot get it working keeps blowing breaker.
  • 358 Answers
First check for bunrt wires that can be grounded, then you can disconnect the compressor and plug the freezer and if doesn't blow the breaker , the compressor is bad ,if still blows them ,put the compressor back and try the fan , then try the other fan(inside one) or also could be the light switch, or the defrost heaters.
Posted on Oct 06, 2009
Hosizaki ice machne 3 beeps then after i reset it it runs for 7 seconds and shuts off?
the 3 beeps means that the freeze cycle is longer than 60 minutes. This could be because: float switch stuck, water valve leaking water into the sump, low on freon. If not one of those, it is a more technical issue that would require a service tech. Reset button is a small white button on the control board. Press it while the power is on to reset it.
May 21, 2014 | Hoshizaki Freezer Commercial Ice Machines...
My frigidaire freezer upright has an error message door ajar
Sounds like the main control board to the unit needed to be reset and with the resetting it has caused a communication error with the door sensor. Contact a service tech to move forward with a repair.
Sep 04, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Victory freezer VR1 evaporator motor will not run, does not have voltage to it. Fan delay switch checks ok....HELP!!!
Check to be sure the door switch is working. It turns the fan off when you open the door and turns the light on. Also the defrost time has a connection to the inside fan. Check to see that your defrost timer is turning on and off at the right times. If the evaporator coils don't get down to 20 degress the clicks-on fan controller won't switch on. If that is the case you may be low on refrigerant.
Oct 07, 2010 | Victory Commercial Freezer VSF-1
I have a vf-3 freesr, I would like to aquire more,
go to http://www.applaincepartspros.com and you can order them there, the also have a 800 name to call to talk to someone, yo will have to mesure them for the size you want.
Nov 20, 2009 | Victory Commercial Freezer VF-3
Frigidiare upright freezer has just stopped cooling
I was hoping it would be something like a cracked door seal, or a faulty thermostat, etc., but after reading the rest of your info, I've concluded the likely cause is a slow leak in the refridgerant line(s). I've seen many of these fairly new upright freezers with this problem.
Finding the leak is easy for a service tech to find, but the cost of the service tech isn't cheap and unfortunately, the repair cost will probably exceed the cost of a new freezer, but you can try to call a repair tech and see if they can give you a rough estimate over the phone or if they think it's worth fixing, etc.
My advice is to replace it. The cost of food you've lost has probably exceeded the price of a new freezer - and you've had this happen twice now. These days it seems that some appliances are being designed and built as "throw aways" due to the high repair cost.
Wished I had some better news for you, but unless you've got all the specialty tools; (charging gauges, vaccum pump, Freon, etc.) needed to do the repair yourself, along with the technical knowledge, it's likely not worth having the repair service contracted. Best Regards.
Jul 30, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Hubbell plug
Look on the electrical data plate. It should give you the info you need to know. I went to "victory-refrig.com". It looks as if you have a 3 door unit. The condensing unit is rated at 208-230 volts and is single phase. If your data plate confirms this, you need to use a plug that will accomodate 4 wires (4 prongs). Ground, neutral, and 2 power wires. It also shows that the unit is rated for 12.9 amps so a 20 amp plug is o,k. to use as long as you have the correct voltage. Do not attempt to use 115-120 volts on this as it is not designed for it and will most likely damage the unit. The web site has manuals, diagrams, and such. It looks user frendly, just got to look for what you want.
Hope this helps.
Good Luck
Dec 15, 2008 | Victory Commercial Freezer VSF-3
GE Profile side by side refrigerator-freezer PSC23SGNABS
Hi sckk,
ngafm at your service,
Your indoor ice and water keeps getting iced up.
There is an air leak somewhere between the ice and water dispenser on the door and the freezer!
there are many places that this may be. But usually the spring loaded door where the ice drops out to the door ice machine!
It takes a good tech sometimes a couple visits changing a couple of parts till he gets it.
There is no sure fire way to diagnose which part is the culprit thats leaking air.You need an experienced tech that eyeballs it and knows what parts to choose first to be replaced.
The air leak almost microscopic to the eye.
Sometimes you take ice from the door and the crack only closes full some time after wards. Then the tech comes the next day and sees nothing. Or it is intermittent problem!
My advice is only a trained tech can remedy this problem, this time!
If I were there I'm sure I could nail it down!
You need hands on service!
Bless You ,
ngafm,
please give me a goo rating before you sign off.
Thank you.
Sep 09, 2008 | Freezers
What can I do to get rid of frost build-up (more than 8" long & 1/2" Deep) on my NEW FROST FREE FRIGIDAIRE FREEZER GLFU2067F?
contact 1-888-77-lowes if you havent done this call, have them create a case file on this, tell the person that you talk to that if you try this solve and it dont fix the issue I want a new machine if they agree to this do the door replacement if they don't take it back to lowes
Mar 25, 2008 | Frigidaire 20.3 cu. ft. Upright Freezer...
Freezers Logo
78 people viewed this question
Top Victory Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Victory Freezer Expert? Answer questions, earn points and help others
