Question about RCA D52W19 52" Rear Projection Television
Changed the three resisters, checked the small glass fuse, still no power.
Can all three injectors on one side go bad at the same time
Not usually. They use the same power source but are grounded at different times by the engine computer.
Its possible one bad injector could damage the others, but that rarely happens.
An injector is an electric valve with a small coil and magnet inside.
Feb 28, 2016 | 2005 Cadillac CTS
I blew fuse in my Technic SU D7000 .iv open this thing and i cudnt find where the fuse. Where the hell is fuse in this model. Help please somebody
One of two places...either at rear next to the power supply lead usually a small black plastic screw in cap.....or on the power supply board itself which is easily identifiable as it is the glass fuse in the event of not finding what looks like a fuse then it may have a soldered in diode.you need to obtain a schematic for that make and model.and understand how to use a meter to check.
Apr 13, 2015 | Audio Players & Recorders
Fisher & Paykel Aquasmart WL80T65C 5 years old with fault 245, then 49.
Error code 245 is pump stall.
If the 1.6amp glass fuse has blown, the five mosfets on right side have shorted out there legs & blown the fuse.
Also check the pump drive parts for shorted legs.
There are three resistor that burn out near the fuse.
I will up loaded some pictures later.
Feb 08, 2013 | Fisher and Paykel Aquasmart wl80t65c
How can you tell a fuse is blown on a samsung tv model is HP-R5072
Any fuse if glass or not can be tested with a meter that checks resistance, if glass look for the wire strand inside to be black or broken, checking a fuse is like testing a light bulb----two connections and should read a short across them.
Nov 05, 2012 | Samsung HP-R5072 50 in. Plasma HDTV
Hi.. please help me.. my minolta dialta 183 is not working.. there's a code CO5 in the screen.. please help me to fix it.. thanks
C0500: Warm-up failure
Step 1
Check:
Fusing Heater Lamp (H1) turns
ON.
Step 2
Check:
Fusing Heater Lamp (H1) is open-circuited.
<Check Procedure>
Check the resistance across both
ends of the Fusing Heater Lamp
(H1).
The Fusing Heater Lamp is open-circuited
if the resistance is infinity.
Result: YES
Action: Change Fusing Heater Lamp (H1).
Step 3
Check: Thermoswitch 1 (TS1) is operational.
<Check Procedure>
ends of the Thermoswitch 1 (TS1).
The Thermoswitch 1 is open-circuited
Result: NO
Action: Change Thermoswitch 1 (TS1).
Step 4
Check: Fusing Unit Interlock Switch (S2) is
operational.
<Check Procedure>
Check continuity across terminals
when the Fusing Unit Interlock
Switch (S2) is turned ON.
• Across S2-1A and S2-1B
• Across S2-2A and S2-2B
Result: NO
Action: Change Fusing Unit Interlock
Switch (S2).
Result : YES
Action: Change DC Power Supply (PU1).
Step 5
Check: Thermistor (TH1) is open-circuited.
<Check Procedure>
Check the resistance across CN15-2
and CN15-3 on the Fusing Unit side
with CN15 disconnected.
The Thermistor is open-circuited if
Result: YES
Action: Change Thermistor (TH1).
Step 6
Check: The following voltages are supplied
from the Master Board (copier: PWBA).
<Check Procedure>
Check voltage across a Master Board
(copier: PWB-A) pin and GND when
the Power Switch is turned ON.
• Voltage across PJ10A-7 and GND
DC24 V when Fusing Heater Lamp
(H1) is OFF
DC0 V when Fusing Heater Lamp
(H1) is ON
• Voltage across PJ10A-10 and
GND
(H1) is OFF
(H1) is ON
Result: NO
Action: Change Master Board (copier:
PWB-A).
Oct 05, 2011 | Konica Minolta DiALTA Di200 Copier
Minolta dialta 183 help me... theres a code in the screen CO5 .. and automatically turn off.
Step 1
Check:
ON.
Step 2
Check:
<Check Procedure>
(H1).
Result: YES
Step 3
<Check Procedure>
Result: NO
Step 4
operational.
<Check Procedure>
Result: NO
Switch (S2).
Result : YES
Step 5
<Check Procedure>
Result: YES
Step 6
<Check Procedure>
(H1) is OFF
(H1) is ON
GND
(H1) is OFF
(H1) is ON
Result: NO
PWB-A).
Oct 05, 2011 | Minolta DiALTA Di183 Copier
The inner door glass shattered and now no power
There's a safty switch which prevents the unit from operating if the door isn't fully closed. When the glass shattered a small piece may have blocked the switch from operating properly. Check around the door seals for any irregularities.
Mar 22, 2010 | Neff H7871N2GB Convection / Microwave Oven
No power to my PSW110
The fuse may be located in several spots:
- fuse inside the three prong power plug connector on the sub (if there is one) - see if it has a fuse compartment built in - it should slide out kind of like a small drawer - sometimes it has also a separate place for a spare plug in there - the fuses used are of glass type.
- fuse mounted into a fuse holder soldered onto the circuit board - glass type fuse
- fuse soldered directly onto the circuit board - sometimes the type used is glass (it may have a heatshrink tube around it so it doesn't look like a fuse at a first glance, also there are other types of fuses that can be soldered directly onto the board - these are in the form of a small vertical cylinder, usually of a dark reddish colour with white / yellow print on the top - they look somewhat alike to small electrolytic capacitors, but are encased in dark red plastic with the pins located directly underneath the fuse.
Hope you can find it...
regards
3rq8 (Triarcuate)
Sep 10, 2009 | Polk Audio PSW110 Subwoofer
He's Dead, Jim! Died when door opened, but Usual Suspects clear?
May 13, 2009 | GE JE2160 Microwave Oven
My bass guitar amp is blowing fuses
This sounds like the main rectifier diode/bridge is shorted. If you can rpovide the make and model, I may be able to give you more details.
Thanks,
Dan
Nov 25, 2008 | Audio Players & Recorders
RCA D52W19 52" Rear Projection Television Logo
54 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
