Question about Whirlpool 24 in. GU1500XTLS Stainless Steel Built-in Dishwasher
Does the whirlpool GU1500XTLS1 have a fuse - I do not have any power to the console?
  • 5,911 Answers
Yes, there is a thermal fuse located behind the operator console. The part number for the replacement kit is 8193762. You can view an illustration at appliancepartspros.com. It sells for about $13 and the instuctions with a wiring harness are included with the kit.
NOTE: You MUST follow the instructions and use the wiring harness. There were some noted problems with certain model dishwashersDoes the whirlpool GU1500XTLS1 have a fuse - I do - 2.gif where the wire gauge on the thermal fuse was too small and would heat up causing the thermal fuse to blow prematurely. The replacement kit includes a wire harness with a larger gauge wire that handles current better, preventing the fuse from blowing prematurely. To ease your mind, there were no reports of fire hazard.
If you need to view a diagram of your dishwasher, enter your model number at the website mentioned for some excellent exploded view illustrations. The thermal fuse is listed as item 6 under the "Control Panel Parts" heading.
If you have any questions, please let me know. I hope this helps you.
Posted on Oct 06, 2009
Normal wash and rinse only lights keep blinking on whirlpool gu1500xtls. tried cancel and uplugging and they still blink
Have Whirlpool GU1500XTLT1 with exact same symptoms, even tried power off but the lights resumed blinking when powered back up. Used solution from "kent168" of 17 Nov 2010 for similar GU1500XTLS1 with a different problem, and IT WORKED: "Reset the machine: press control buttons in this sequence: sani rinse, air dry, sani rinse, air dry, clear."
Jan 18, 2012 | Whirlpool 24 in. GU1500XTLS Stainless...
How do you get the Codes? for GU1500XTL Dishwasher. Only buttons that work are: Anti Baterial, Pots n Pans, Delay Start, Air Dry, and Cancel. We normally use NORMAL. Need Codes and Wiring Diag. Thanks Walt
I am having the same issue. Did you find a solutions? Looks like websites I've searched talk about resetting the controls by hitting either high temp wash -> airdry -> high temp wash -> air dry OR saniwash -> air dry -> saniwash -> air dry. I'll have to try that tonight.
Oct 20, 2011 | Whirlpool 24 in. GU1500XTLS Stainless...
My Whirlpool dishwasher was running when there was a power failure, and now there is no power whatsoever. The power failure happened when the machine was on final rinse and drain. Water is still in the...
Most Whirlpool manufactured dishwashers have a thermal fuse, located inside the operator console. When tripped, the dishwasher will not run. A power outage can cause the thermal fuse to trip. It cannot be reset and has to be replaced, if bad. Please post back with your COMPLETE MODEL NUMBER (located around the door opening) so I can determine the configuration of your dishwasher and explain how to access any potential fuses. -->
May 19, 2011 | Whirlpool Dishwashers
Whirlpool dishwasher GU1500XTLS1 displays the number 2 and pumps out no other function works
Reset the machine. Press the control buttones in this sequence: sani-rinse,air-dry,sani-rinse,air-dary then clear! That should do it!
Nov 01, 2010 | Whirlpool 24 in. GU1500XTLS Stainless...
This dishwasher has worked fine for years. Suddenly, no power at all to front controls, won't start. There is power at the plug. Any ideas?
Kenmore and other Whirlpool manufactured dishwashers have a thermal fuse located inside the operator console. If the fuse blows it will exhibit the symptoms you describe. It cannot be reset and must be replaced. If you post back with your model number I can confirm how your dishwasher is configured and maybe provide you with a part number.
Dec 11, 2009 | Kenmore 15879 Built-in Dishwasher
No button will work except "cancel" button on model # GU1500XTLS1 Have tried all suggested troubleshooting tips in manual
I have the same problem. The only temporary solution I have so far is to turn off the circuit breaker and wait between 10 & 30 minutes before resetting the breaker. The the dishwasher will work for one cycle.
Aug 27, 2009 | Whirlpool 24 in. GU1500XTLS Stainless...
How complicated is it to replace the heating element in the whirlpool gu1500xtls1 Dishwasher? It is not drying. Can the element be replaced from inside the unit or does it does the whole dw have to be...
would be easier to remove the dw form the cabinet , at least partially. Hopefully there is enough slack in the electrical line as well as water feed line. sometomes you can walk the d/w out woithout disconnecting them. the heating element can be unscrewed from underneath( 2 white lug screws mount them to the underneath of unit)..
Feb 23, 2009 | Whirlpool 24 in. GU1500XTLS Stainless...
How does pump assembly go back in to dishwasher gu1500xtls1
are we talking about a drain pmp for a whirlpool dishwaser??? if so it simply pushes against the sump houshing and with a quarter turn clockwise "snaps" into place
Feb 16, 2009 | Whirlpool 24 in. GU1500XTLS Stainless...
Whirlpool Gold dishwasher
did you check the thermal fuse in the console part #675813? its mounted on the control board white fuse w/ 2 wire leads
Jan 26, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool dishwasher stopped working...
It sounds like the thermal fuse in the control console has blown.
Turn power off to unit.
Remove the outer door panel and then the console.
Remove the black plastic cover from over the circuit board if it has one.
You should see the thermal fuse clipped to the circuit board housing.
If you have an ohm meter, check for continuity across it, it should read closed.
If you don't have a meter, unplug the wires from it and and hook them together.
Turn power back on to unit, hold door switches down and cancel cycle. The washer should drain the water.
If this doesn't work, check your door switches to make sure they are closing properly.
Nov 17, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 24 in. GU1500XTLS Stainless Steel Built-in Dishwasher Logo
564 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
