My hp vs19d power button blinks on and off slowly. what does it mean? if i let the computer sit for say 3 hours the monitor will stay blank. even after moving the mouse to wake things up
    Scholar:
  • 83 Answers
The monitor is in sleep mode ... have you tried hitting the keyboard Space bar?
if you disconnect the video cable from the pc does it display ( video disconnected) ? if it does it then is probably the sleep issue
Posted on Oct 06, 2009
HP TouchSmart 310-1125f display is black
Hearing fans and hard drive spin up doesn't necessarily mean system is working - just without video. If you heard a POST beep or the Windows Startup sound that would be different - and good. Is there any video on the screen at all, even just a blinking cursor in upper left of display? If not, your problem is probably hardware such as ram or motherboard. If this system has a VGA or HDMI output to connect to another monitor or TV would be a good check, but AIO system usually don't have that option. Other than that, and this is a shot in the dark: Ensure the system is off, disconnect the power plug, and hold the power button in for 30 sec for a power reset. Then plug in system and try powering it up again. If no go, you may have a hardware problem and will need a PC Tech. Hopefully it is just loose ram.
Apr 08, 2015 | HP Touchsmart 310-1125f Windows 7 4gb Ram...
VS17 Monitor - power light only blinks, but monitor screen stays dark.
Look for bad caps in the power supply first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Also read here: http://boredprojects.blogspot.com/2008/06/hp-vs19d-fix.html
Aug 30, 2010 | HP Computers & Internet
My monitor does not turn on and the power button light keeps blinking ... <my Gateway monitor light blinks blue slowly but the screen is blank
This is usually a sign that there is no signal going to your monitor, check all your cables and then reboot.
Jun 28, 2010 | Gateway FPD2275W LCD Monitor
Vs19d monitor has power but screen is not coming on
You will need to open it and inspect the capacitors in the power supply first, hopefully it does not have bad lamps assembly like the one in my pictures here: http://s807.photobucket.com/albums/yy352/budm/HP%20VS19D/
Post back what you see inside so we can guide you further.
Apr 07, 2010 | HP Vs17 17" LCD Flat Panel Monitor
HP vs19e monitor is blank. Power button is slowly
that is not a monitor problem that is a cpus problem disconnect the signsl cable and connect power cable you will see the post (power on self test) open the cpu draw the ram clean the dust and reinstall the problem will solved
Feb 26, 2010 | HP vs19 (Silver) 19" LCD Monitor
My moniter wentr out.
Hmm, haven't had experience with this exact monitor, but several people have had success with my tutorial on fixing the vs19d and vs19e. Check out the link below:
http://boredprojects.blogspot.com/2009/09/hpvs19e-monitor-fix.html
Sep 28, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
HP L1706- screen is blank when I switch on
First if you have a extra monitor try to plug it in and see if it works. If not then check your video card. or get into the computer and try and remove and reseat the memory. Sometimes by just doing that can solve the problems
Feb 06, 2009 | HP L1706 17" LCD Monitor
My HP vs 19 desktop monitor is on, but the screen is blank. It flashes on for less than a second when I turn the monitor off, and then back on -- but then goes blank. What is the solution?
If you are handy at fixing things.
Here is a link of how to fix your monitor. I had the same problem, and found this link, followed the instructions and it cost me $5.13
to fix my HP vs19 LCD monitor, and its still working great.
HP vs19 LCD Monitor fix
Don't drag out your soldering gun these are too high wattage and will melt the board. Use a 40 to 25 watt soldering iron.
Dec 13, 2008 | HP vs19 (Silver) 19" LCD Monitor
Computers & Internet Logo
195 people viewed this question
David Payne
David Payne
