Question about Dryers
The dryer has ruined many of my clothes, straps and tank tops get caught on the lint filter and then twist until they tear apart. how can i fix this?
Clean out the hole beneath the lint trap. We had this same issue and were able to pull lint from the hole (a bunch of lint) giving the lint trap enough room to fit in the slot correctly. Good luck!
Posted on Jun 26, 2013
    President:
  • 1,187 Answers
Purchase a lingere mesh bag.
Put delicate items in the mesh bag (has a nylon zipper) and dry.
Purchase two or three at Target, WalMart, etc.
Posted on Oct 06, 2009
Dryer vent broken
there's lint stuck in the side slots where the filter slides down into the ducta dryer should be pulled apart and cleaned out at least once a year more so if it's gas,unplug it,remove the bottom panel,pull out the lint filter,remove the screws that hold the duct in place,take it out and clean it,vac out all the lint inside the cabinet,set the shop vac up to blow and blow all the lint from the back forwards and make sure you blow off the motor and anything else in there and vac it up,put it back together and go to the back,remove the vent line from the back of dryer,if it's a long run stick a leaf blower into the vent line and blow it outside,first go outside and make sure the duct is open,no cage or screen that will block the lint then blow it out.do this once a year and you'll have hardly any problems with the dryer and mostly you won't have a fire.next time send the model number so i can see what you have.
Oct 07, 2013 | Frigidaire Dryers
I have the Frigidaire Gallery Series washer and dryer and I have a problem with both. The washer has accumulated a nasty layer of dirt, mildrew and who knows what else on the rubber seal and window. The...
hmmm...well..sounds like your unit is eligible for a thorough(honey do) episode, if he is so inclined. Otherwise, you are experiencing what's commonly called wear and tear, from most likely faithful service of a valuable appliance.
maybe it's time to consider a new one?
if not, then taking it apart will require patience, tools, and perhaps some cleaning solutions that are not amenable to the human skin.
May 31, 2008 | Frigidaire Washing Machines
Lint filter on LG DLEX2901V sticks up in the corner and catches clothes
Look familiar? LG dryer model DLEX3250W. Lint frame does not fit the slot anymore. NOT BECAUSE OF EXTRA LINT it's because the frame is warping.
Dec 07, 2011 | LG DLEX2901V Dryer
The lint filter does not fit properly in the lint trap. The corner of the filter catches an item of clothing and twists it. I have to check it several times to clear the item away. I assume this...
We have the same model and experience the same thing. The way I fix it is to remove the filter, then with a flash light I look down into the lint trap. You will notice that lint has built up in the track where the lint filter sits. I use a wooden skewer to run along the track and lift out the lent. Hope that helps
Aug 21, 2011 | Samsung DV448AEE Electric Dryer
We have had a consistent problem with our dryer. The lint filter eats any staps in the dryer. I have found straps from bras, tops, and belts twisted around the lint filter. They get caught on the edge...
sound like front felt glide assy # upper felt seal part #134440200 lower felt seal #134134700 u can order these from sears.com
these componets support the front of drum and when felt wears away then clothing slips in gap and when dreyer tumbles clothing gets snagged in gap and tears clothing and leaves black scuffs
Jan 31, 2011 | Frigidaire GLEQ2152ES Electric Dryer
The plastic lint filter does not fit properly anymore. Clothes with straps are now being caught and tangled causing the straps to break. My dryer is only about 1 year old.
if the unit not look damage then the filter hosing need to be replace but bout unit can be replace and the parts can bought in sears parts
Jan 02, 2010 | Dryers
Lint trap doesnt fit in slot completely evenly
Remove the trap and look in the hole and see what is keeping it from going in. If the screen is damaged, replace it.
Jun 04, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Torn clothes
there should have been a plastic gaurd on the lint catcher inside to keep this from happening, at anytime when taking your clothes out did you find something you might have though how did that get in there> could have been it, or look under the dryer and see if it made it's way out past the drum to the floor
May 30, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Our dryer lint trap won't go down all the way and is catching our clothes -- ruining spaghettis straps, bras, etc., twisting everything and catching our clothes on the corner of the trap.
It may be backwards. But the first thing I would look for is if there is lint caught in the shute keeping it from going down all the way. If it is a newer model there is a lint screen sensor that may have come unattached and keeping the lint screen from going down all the way. Good luck.
Apr 19, 2009 | Dryers
Dryers Logo
388 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
