Question about Maytag Neptune MDE5500AY Electric Dryer
Need to connect 4 wire pigtail to replace 3 wire
  • 5,911 Answers
The following link explains how to convert a 3-wire to a 4-wire power cord:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
The main difference is how the Neutral (White) and the Ground (Green or Bare Copper) wires are terminated at the terminal block. In a 4 -wire configuration these wires are independent of each other. In other words, neutral does NOT get grounded.
If you have any questions, please let me know. I hope this helps you.
Posted on Oct 06, 2009
How to connect 4 wire pigtail to 3 wire dryer
connect directly to dryer. There should be a connecting block in back of dryer marked for blk.hot wire,white commen wire,and Green or bare ground wire & add another ground wire from a screw on dryer to green ground wire at the block.To be safe,check your owners manual. PS always be sure your pigtail is unpluged.first.
Sep 27, 2014 | Whirlpool GEW9250 Electric Dryer
Kobalt 60 gal compressor 221565 book saYS NOTHING ABOUT WIRING PIGTAIL 240 VOLT I WIRED IT LIKE I THOUGHT IT WENT AND BLOWS BREAKER WHEN I PLUG IT IN HELP!!!!!!
266549_300.jpg This is the most popular switch used on compressors but may not be exactly what you pressure switch looks like. You will need to determine how the contacts transfer power across the terminals. Lets number the terminals from left to right 1,2,3,4. On this switch notice how power crosses from 1 to 2 and from 3 to 4. You can determin how power is transfered on your switch by using meter. On this switch, leads from motor (load) would be connected to 1 and 4 and line in ()would be connected to 2 and 3. Determine with meter which leads from your pigtail are 115v each. Pigtails have either 3 or four wires depending on your wall plug configuration. You will only need the two 115v lines (connected to 2 and 3) and a ground wire connected to green screw. Under the cap of the pressure switch, there should be a wiring diagram to assist you for your particular switch. Good luck
Mar 18, 2011 | Air Tools & Compressors
I had to replace the pigtail and alternator , the new pigtail has 4 wires, the existing wires in the car are 3, where does the fourth wire connect to ?
The alternator is used on many different models. The other terminal is probably a signal to the computer that your car doesn't use. As long as the connector fits, you are golden. Just tape up the end of the extra wire to avoid a short. OK?
Nov 08, 2010 | 1999 Oldsmobile Intrigue
Similar issue as above. I have a two-switch wall box. I want to replace one switch with a timer. The swtiches control separate lights and are part of a circuit with other lights, but they are not 3 way...
the black wires that are pigtailed are your hot and the red that is seperate is the switch leg. It will not be hot until you have it connected to a switch or the timer
Sep 29, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
How to connect a four wire pigtail
The white wire goes to the middle terminal post on the dryer.
The red and black wires go to the outside terminal posts.Doesn't matter which.
The green ground wire needs to be attached to the outside metal case...anywhere. The easiest way is to put the eyelet on the screw that attaches the terminal cover plate when you put it back on. Sandwich it between the screw head, the plate and the case.
Hope that helps. Let me know if you need more info
Best, G
Aug 02, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Need instructions on wiring for a 4-wire pigtail on a GE Dryer Just moved, the new place has the new 4 prong outlet so I replaced my pigtail with the new 4-wire one. Need wiring instruntions for the colors...
put the white in the middle,red on one side black on the other doesn't matter what side or just copy the old cord,now you need to ground it with the green wire,take off a screw on the back of the dryer near the other three and attach the green ground wire to it and screw it back in,the green wire just has to touch the metal frame to ground it
Mar 14, 2010 | GE Dryers
I am in the process of trying to hook up a 3 prong electrical cord to a 4 prong but dont know which colored cords go where? any advice?
Get an qualified person to do it. If you do not have any idea how to do it, you are better off having someone else do it. If you have a 3 prong receptacle, you need a 3 prong pigtail. And if you have a 4 prong receptacle, the dryer needs a 4 prong pigtail. The green is ground, white is neutral, red and black are both hot (L1 and L2). If you put a 4 prong pigtail on, remove the ground strap between the center post and the case. The green ground goes on the case, white neutral in the center, black or red to the left, what's left on the right. You can interchange the red and black but NOT the white or green. If you use a 3 prong pigtail, the center is the neutral (same as white on the 4 prong) and you will need the ground strap between the neutral (center) and the case. The wires do NOT cross over on a 3 prong pigtail.
Dec 31, 2009 | Maytag Dryers
How do you install the frd03-dvd? mines came with no instructions.
Hello jeffery_armi,
The FRD03-DVD allows you to replace the factory head-unit and retain the audio and power to your OEM DVD player. With the FRD03-DVD, the audio from the OEM DVD player is connected to the auxiliary input of the aftermarket radio to allow the DVD audio to be heard over the vehicle's audio system.
The FRD03-DVD harness consists of a molex-plug, stereo RCA audio male connectors, and red and black wires ending in "pigtails".
1) Connect the molex plug into the OEM harness.
2) Connect the RCA audio connectors into the "AUX" inputs of your aftermarket head unit.
3) Tap the red "pigtail" wire into the "accessory" lead of the vehicle radio harness (also usually red).
4) Tap the black "pigtail" wire into the "ground" lead of the vehicle radio harness (also usually black). Alternatively, the black wire may be terminated with a ring terminal and secured to a metallic ground nearby.
Hope this helps.
May 13, 2009 | Pie Frd03 Aux/S
My mom has a 3 pigtail kenmore dryer her house has a 4 prong outlet we bought a new 4 pigtail cord how do you upgrade a 3 pigtail to a 4?
remove the old cord 3 wire, at the terminal block connect black wire onto the lefet screw, white onto the middle screw, red onto the right screew, and green to the frame of the dryer
Apr 10, 2008 | Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
447 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
