Question about Ionic Pro Turbo Air Purifier - Black
Keeps turning off. It's clean and just started doing this. i turn it on and a few minutes later I look and it has turned itself off. What's going on.
My car wont start after I have driven a while and turn off engine. When I try to start it cranks well but will not turn over. If I let it sit for 20 minutes it will start again???
Sounds like you're in tank fuel pump is starting to go bad..happened to my astro van a few years ago..kept doing this until one day it just didn't work. Have someone do a fuel pressure test before and after turning the engine over...Also try this..before trying to start your engine turn your switch to ON for about ten seconds and listen very carefully for the pump running to prime the fuel system and injectors it should run for about five seconds...then try starting the engine...get into the habit of waiting those 10 seconds to insure proper priming of the system..good luck
Dec 14, 2014 | Spectre 2002 Chevy Impala - 3.4L V6 - Air...
Hybrid GP will not operate consistently
Hello Judy D.
As you might be aware the blinking LED indicates that a fault has been detected.
Check that the ionizing wires supports have not started to 'track' this will appear as a hair-like discolouration across the supports surface. The 'track' may be very thin and hard to spot.
This can be caused by dirt that has started to burn into the surface by arcing.
If you find any 'tracks' then try to clean them off with a mild solvent like pure alchohol.
Another thing to try is to run the unit in total darkness and look into the grills to see if there is any arcing or sparking happening.
Let us know the outcome.
Oct 13, 2007 | Sharper Image Hybrid GP (SI724) Air...
My oreck magnesium keeps turning off. Blue. Light keeps blinking
THE PROBLEM SEAMS TO BE WITH THE THICKNESS OF THE CARPET AND THE PAD-ALL VACUUMS NEED TO BE ABLE TO BREATHE IF THE PAD AND THE CARPET ARE THICK THE VACUUM WILL PULL ITSELF TOWARD THE FLOOR SLOW DOWN THE BRUSHROLL ENOUGH TO TRIGGER THE AUTO SHUTDOWN ON THE MAGNESIUM BECAUSE THE VACUUM CANT BREATHE. TAKE IT TO YOUR LOCAL ORECK AND THEY CAN PUT A FEW HOLES IN YOUR SOLEPLATE AND THIS WILL TAKE CARE OF THE ISSUE.
Apr 02, 2013 | Oreck Magnesium Upright Vacuum Cleaner
Electrolux el 500az turns itself off
Did you ever get this resolved? Mine was doing the same thing and I had the main board and accessory board replaced. It seems better but still shuts down every so often.
Mar 03, 2013 | Electrolux el500az air purifier
When you turn it on it does not work it just blinks and blinks
You can try to get it to reset itself by doing the following:
Turn the Master ON/OFF Switch to OFF. Unplug the unit and leave unplugged for 12 - 15 minutes. Then plug the unit back in and turn the Master ON/OFF Switch to ON. Set the controls as you normally do. Hopefully, the 12 - 15 minute timeout, allowed the unit to reset itself.
Generally, this works 90% of the time. I hope it works for you.
Apr 23, 2011 | Sharper Image Ionic Breeze 3.0 Air...
Hi, I have the Ecoquest SynairG4 and I had to replace the RCI Cell due to the bulb going out. The unit digital readout now keeps telling me to perform cleaning. I cleaned the filter and checked the...
Somewhere on the front of the machine, between the manual control buttons on the right, is a tiny black button labeled "reset." While the machine is running, hit that button, then turn the machine completely off for a minute. Turn it back on. This should take care of the problem. (It's actually a timed reminder, like the annoying "check engine" light on your car.). If that doesn't do it, call the company at 1-800-989-2299 for further instructions.
Feb 07, 2011 | Ecoquest Fresh Air Air Purifier
MY IONIC AIR PURIFIER KEEPS SHUTTING OFF; INTERIOR "CLEAN" ?????
Those and ionizing air cleaners like them were panned by CR for producting way more ozone than you want in the room and filtering far less than you would think. If it has failed dispose of it and get one with a filter you can change.
May 28, 2010 | Sharper Image Ionic Breeze GP SI730 Air...
Every time I turn on my Ionic Breeze the "needs cleaning" light comes on within a few minutes. I clean the grid but this keeps happening. What do I do now?
I have a ionicbreeze silent air purifier the "the cleaning light comes on within a few minutes . I have cleaned the grid but this keeps happening. What do I do?
Jan 27, 2010 | Sharper Image Ionic Breeze 3.0 Air...
After cleaning I turn it on and after a few minutes the light
these things are junk. you could also be doing more harm than good to yourself and the indoor air quality in your home with the amount of ozone these appliances omit into the air. throw it away
Sep 12, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Ionic Breeze Quatra Hissing Noise
While the device is turned off and the filter is out, tip the unit itself upside down and back. Do this several times, there is a slider type cleaner inside that moves as you turn the unit. Be sure to do this every time you clean your filter and you will never hear a peep out of the thing.
Aug 13, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Ionic Pro Turbo Air Purifier - Black Logo
96 people viewed this question
Top Ionic Pro Air Purifiers Experts
Paul Cox
Level 1 Expert
Shehu Pro
Shehu Pro
Thomas Perkins
Thomas Perkins
Are you an Ionic Pro Air Purifier Expert? Answer questions, earn points and help others
